Question about Briggs Stratton IC Horizontal OHV Engine 305cc 1450 Series 145 Gross Torque 1in x 3 2132in Shaft Model 2053320537B1
NISSAN 1.6 k7mf tORQUE SPECS
NEED TORQUE SPECS ON NISSAN NP 200 1.6 2006
I need the torque specs for flywheel bolts on a Nissan NP 200 bakkie. It has a Renault K7M engine - 1600 cc
you will need the torque specifications for the renault engine not nissan
the bolts may be different sizes and incorrect torque readings may snap off the bolts
Dec 17, 2016 | Nissan Cars & Trucks
Tip
Nissan altima 2.4 L torque specs.
Torque sequence ---------------- | 9 3 1 6 8 | | 7 5 2 4 10 | ---------------- Step 1: Torque in sequence 22 Ft/Lbs Step 2: Torque in sequence 58 Ft/Lbs Step 3: Loosen all bolts completely Step 4: Retorque all bolts in sequence 22 Ft/Lbs Step 5: Retorque all bolts in sequence 54-61 Ft/Lbs recheck final torque in sequence *** CAUTION *** engine uses Torque To Yield head bolts (TTY) that permanently stretch during the initial installation. New head bolts must be used when cylinder head is replaced or re-installed to obtain proper torque. 0900c15280265395.jpg
on Jul 08, 2010 | Nissan Altima Cars & Trucks
2010 nissan versa 1.8L spark plug torque spec
Never have used torque specs. Keep in mind. If the plug has a metal gasket, snug it down, add 1/4 turn. If the plug is beveled, snug it down add 1/16 turn. But I believe the torque is 17 foot pounds.
Mar 08, 2015 | 2010 Nissan Versa
2004 nissan frontier head torque specs
You should have torque to yield bolts there. That means single use - you need to buy new bolts. Then, you would torque to spec (maybe 10-12 ft. lbs.) then an additional 65 degrees of tightening rotation.
Call your local auto parts supplier.
Repair Guides Specifications Torque Specifications AutoZone com
Feb 26, 2015 | Nissan Frontier Cars & Trucks
Torque specs for Nissan Sentra 1300
Torque specs for what part? the entire car has factory torque specs for each bolt installed on a car. Need details on what part.
Sep 27, 2013 | Forum Snowboards Forum Body Bag 1 Piece...
Torque specs for 2005 nissan altima 2.5
According to Haynes Manual, 2005 Nissan Altima, using BRAND NEW cylinder head bolts:
1 - Tighten in sequence (as pictured) to 37 ft-lbs.
2 - Tighten an additional 60 degrees.
3 - Loosen all bolts completely.
4 - Tighten in sequence 26 - 32 ft-lbs.
5 - Tighten in sequence an additonal 75 degrees.
6 - Tighten in sequence an additional 75 degrees.
Mar 23, 2012 | 2005 Nissan Altima 2.5
Torque specs,rod bearings,2003 nissan altima 2.5
I need the torque specs for the connecting rod and main be
Sep 10, 2011 | Nissan Altima Cars & Trucks
Wanting to know rb20det engine torque setting
  • Head torque settings
    These are the specs I used on my own last rebuild
    Head is torqued down in 5 stages
    1. 22ftlbs
    2. 72ftlbs
    3. slacken off
    4. 22ftlbs
    5. 75ftlbs or 90o
  • Engine torque setting
    Main bearing torque 40ft/lbs
    Big end bearings..... also 40ft/lbs
  • Oct 12, 2010 | Crystal Decisions NISSAN SKYLINE GTR R32
    Need to know torque spec. on main & rod bearings 4 cycl.
    1997 Nissan/Datsun Truck Pickup 2.4L SFI 4cyl
    The Main Bearing Cap Torque:
    38 Foot pounds (Final torque)
    The Rod Bearing Cap Torque:
    Torque sequence:
    Step 1: Torque to 10-12 Ft/Lbs
    Step 2: Torque to 28-33 Ft/Lbs
    Hope help with this (remember rated this post). TY for using Fixya.
    May 19, 2010 | 1997 Nissan Pickup
    I need the Torque Specs for a Nissan Q-R 2.5 Engine?
    Nissan QR 2.5 engine produces a torque of 180 ft·lbf (244 N·m) of torque at 4000 rpm .
    Oct 11, 2009 | 2003 Nissan Sentra
    Briggs Stratton IC Horizontal OHV Engine  305cc 1450 Series 145 Gross Torque 1in x 3 2132in Shaft Model 2053320537B1 Logo
    47 people viewed this question
    Top Briggs Plumbing Experts
    John Trevino
    Randy Schumann
    Randy Schumann
    Are you a Briggs Plumbing Expert? Answer questions, earn points and help others
