Question about Home
How to open a shower head
My shower head is stuck with water minerals, or whatever is coming along with the water. I want to clean it but I couldn't figure out how to open it. Could you pleas help me open it?
    Master:
  • 966 Answers
Get CLR from walmart or target or Canadian tire etc and apply to remove the build up. once the showehead is out, dip it in the CLR and it will be like new! Good luck
Posted on Jul 17, 2013
  • 171 Answers
SOURCE: shower too hot
Hi sallypenn
I'm Harvey the Master Plumber.
Your question seems to be how to adjust the temperature of a shower valve?
I'm going to assume this is a single handle faucet. Most are adjustable under the handle. This is the responsibility of the installer but sometimes they forget and you can't get them back. Anyway this requires a little mechanical ability and a few tools.
First be sure to turn off the water to the faucet, then remove the handle (allen wrench or small screw driver). Most have a temp. adjustment ring right there. Simply pull out, rotate and replace. With some you have to remove the sleeve or bonnet under the handle to expose the adjustment fitting. Reasemble and turn on. It is not uncommon to have to do this two or three times before the customer is happy with the setting. The adjustment fittings usually don't have tenp. setting numbers to go by so it might take a few tries.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Posted on Sep 10, 2008
  • 68 Answers
SOURCE: Water runs out out both places for spout and shower head in tub!!
One of two issues. Either the shower valve was installed upside down or there is a twin ell ( Old School Diverter) Partially plugged. Odds are the valve is upside down.
Good Luck, Phil
Posted on Dec 09, 2008
  • 7 Answers
SOURCE: The Grohe Movario shower head how do unscrew it to clean the head
On the face of the shower head where the water sprays out of ,their should be a threaded nut to unscrew This is called the aerator.This is the part wher the filter screen is .Once you clean this part you should be up and running.
Posted on Feb 02, 2009
Nomodo4u
  • 863 Answers
SOURCE: shower head is making high pitched whistling nois
The holes are probably clogged from hard water. Take the whole head assembly and dip it in a bucket of CLR for an hour or so. Then rinse off and give that a try. If your cheap, you can use a bucket of white vinegar and a little bit o water, but the smell is most disagreeable.
Posted on Feb 12, 2010
  • 81 Answers
SOURCE: The water comes out of both the shower head and
I will have to assume this issue developed and was not present at first use after the initial installation.
There are generally only two reasons for your problem. The first is that the diverter mechanism is simply wearing out and/or broken. The second it that there is a foreign object preventing it from doing its job correctly. Either way the diverter must come out. I have provided a couple of links below that should help get it out.
Once out, put a wadded up towel over the end of the tub spout opening so as to prevent any water from coming out of it. Then, for just a moment, turn your shower on full and adjust your temperature from full cold to full hot. This process should dislodge any foreign matter and send it out the opening the diverter came out of and also will probably get you wet. I usually plug the tub so I can catch what, if anything, comes out. Having a second person holding a bowl over the diverter opening helps reduce the water splash.
Rinse off the diverter and reinstall it. Turn the shower on and see if there is any difference in how much water comes out the spout while in the shower mode. If nothing has changed then the next step is to replace the diverter.
The diverter assembly part number is A603819
http://www.danze.com/products/pdfs/D113000_ip.pdf
http://www.danze.com/products/pdfs/D500058T_ip.pdf
Posted on Jun 02, 2010
I installed a Moen L2353E tub/shower faucet and water won't come out of shower head
Couple of ideas: If you don't get water at all first check to see if the shut-off valves are open. If so, close them and remove and clean the cartridge. If water comes from the spout and not the shower head, make sure the diverter (the handle on the tub spout) moves up when you pull it. If that works, remove and clean the shower head since there might be debris blocking the water flow. Without
more info this is my best guess.
Apr 07, 2015 | Moen & One Handle Tub & Shower Faucet
How do i disassemble and clean delta a112.18.1 shower head
Over a period of time the minerals in our water can build up when run thru small openings, CLR (calcium, Lime, Rust) remover and cleaner will remove these deposits, mix according to label in a bucket, remove shower head and place in bucket overnight. remove rinse and reassemble with Teflon tape thread sealer.
Feb 28, 2015 | Delta Home
Lincat EB3 water heater
The only thing that comes to mind is that you are on a well. Items like water heaters, heat pumps, sinks, etc are susceptible to mineral clogs. Usually this is solved by cleaning a screen on the inlet or outlet of a device such as a shower head. Thus resulting in more flow and pressure.
I hope this helps.
Oct 21, 2013 | Water Heaters
White stuff coming out of my iron
Spring water has minerals in it.If you want to be sure the water is pure,distilled water is best.(My city water is full of minerals,which means a cleaning with CLR is necessary quite often for my coffee pot and shower head).Distilled water was recommended for topping off car batteries back in the day before they were maintainence free.
Jun 02, 2012 | Rowenta Effective Iron
The pull valve that directs the water from faucet to shower head is stuck. water leaks from shower head and can't turn it off with faucet controls. when main water line is turned off, the valve moves...
it is full of lime and scale from mineral deposits.
either chip it away to clean or remove and replace the spout with a new one which is the easiest thing to do instead
Aug 20, 2011 | Jacuzzi Home
The water comes out very slowly. No pressure.
Check for debris in shower head. Could be calcium or other mineral buildup. Has the water dept. done any recent repairs/upgrades to water meter or mains? Sometimes this can loosen buildup in pipes & send it through the valve itself thus lowering pressure or stopping completely.
Jul 29, 2010 | Moen & One Handle Tub & Shower Faucet
How do i disassemble this shower head to clean out the mineral deposit?
Most often the shower head will be threaded together. Use 2 strap wrenches to take it apart. The strap wrenches will not damage the finish. Do not force it if the fixture does not come apart easily. Soak the head in vinegar overnight to loosen the mineral deposits and make it easier to work with. Good Luck
Jul 12, 2010 | Grohe 27.069.EN0 Relexa Ultra Shower Head...
We have two showers one works perfect the other only cold water comes out when turned towards hot nothing happens..what is this
Sounds like the anti-scald pressure balancing piece is stuck. This happens if the shower isn't used regularly. A varnish from minerals in the water causes it to stick. You can replace the cartridge or try cleaning this one by soaking it in white vinegar. When the cartridge is clean you should hear it rattle when you shake it. To prevent it from happening again be sure to run the hot and cold water at least once a week. BTW, if you are the original owner of the faucet Moen will send you a new cartridge free.
Jun 02, 2010 | Moen & One Handle Tub & Shower Faucet
Flow of water thru shower head is barely a trickle
There is a chance there is mineral deposits in the showerhead openings. You can try products sucha as limeaway by unscrewing the showerhead , soaking in the limeaway for a few minutes and rinsing with water. You may have to repeat this a few times to get it clean.
Jan 20, 2010 | Grohe Integrated 1/2'' Shower Thermostatic...
My Hans Grohe rain shower head is having a lighter spray recently. Is there a way to improve the spray force and/or clean it? Thanks, Therese Terschuren
Rain head showers are a nice thought, but they come with a bundle of problems. This is common one, though, so fear not.
As long as your regular shower head isn't losing pressure (I'm assuming that you have at least two heads instead of just one rain head) I would recommend carefully removing the head with an adjustable wrench and letting it soak in CLR (calcium lime rust) for at least an hour. Often times minerals in water will build up in the small holes on a shower head and greatly reduce efficiency.
Remember to apply teflon tape to the threads before carefully retightening the shower head to avoid spraying water from the wrong end!
Mar 25, 2009 | Home
Home Logo
174 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
