Question about Intel n440bx - Server Dual Slot1 Motherboard N440bx 686238
Intel server bios
Everything was ok-bios,even installed old windows,but the very next day after installing windows bios disappeared(black screen),no beeps,even floppy is inactive. Now is the same situation,but when when i jumped J2J1 in recovery boot mode(10-11) 4-3-4-3 short beeps sound,the rest was the same,upper cpu is warm (by replacing too),opposite to upper cpu is cold, Is MB is dead or any hope for hobbiest? thank stanislav
johnychel
  • 796 Answers
SOURCE: DX38BT don't boot after a recovery BIOS
hello ...you there....
what happened???why did the chat close??
Posted on Mar 07, 2008
SOURCE: My Intel D845EPI/D845GVSR MB processor does not boot up. No BIOS or POST is dispayed on the screen
vfsfsf
Posted on Oct 23, 2008
  • 10 Answers
SOURCE: D-Link Airplus DWL-G520 problem with windows server 2003
D-Link Airplus DWL-G520 on PCI drivers do NOT support Server 2003. It will only support these OS
Windows 98/Me/2000/XP
If you boot your XP is it still working ?
Posted on May 10, 2009
dlundmark
  • 797 Answers
SOURCE: Intel DG45ID motherboard bricked
Here you maybe should not set the manual setting to 800 mghz.
Use the default setting as you can save and reboot it.
There may be a problem with the way the bios sees the memory. Also examine your manual carefully for indications of how the memory needs to be installed.
Some boards require two or more modules to be installed, and will not run correctly with out the modules required installed. Some of these boards will not allow mixing anything except exact sets. That is to say each module must be the same. Some boards are far more tolerant of kinds and makes of modules.
With out the memory, you will not have anything to run on.
So, I would suggest to let the bios set what it sees.
http://www.google.com/search?hl=en&q=Intel+DG45ID+pdf&btnG=Search&aq=f&oq=&aqi=
"Four 240-pin Double Data Rate 2 (DDR2) SDRAM Dual Inline Memory Module
(DIMM) connectors with gold-plated contacts
• Support for:
. Non-ECC, 1.8 V, DDR2 800/667 MHz memory
. Serial Presence Detect (SPD) memory only
. Unbuffered, non-registered single- or double-sided DIMMs (except double-sided
DIMMs with x16 organization)
. Memory configurations listed below:
• Up to 2.0 GB utilizing 256 Mb technology
• Up to 4.0 GB utilizing 512 Mb or 1 Gb technology
• Up to 8.0 GB utilizing 1 Gb technology
• A minimum of 512 MB of total memory is required"
"NOTE
To be fully compliant with all applicable Intel ® SDRAM memory specifications, the
board should be populated with DIMMs that support the Serial Presence Detect (SPD)
data structure. If your memory modules do not support SPD, you will see a
notification to this effect on the screen at power up. The BIOS will attempt to
configure the memory controller for normal operation."
So, the memory is dependent on the configuration. It appears that this board requires 4 modules at once to be installed, depends on the amount of memory per module as well.
Be careful about flashing the bios. By doing that you can ruin the bios and make the computer completely unusable until you get and install a new bios module, if you do not pick the exact correct flash version.
Posted on Aug 30, 2009
  • 78 Answers
SOURCE: My sound driver is not
Go to the web site of what ever PC you have ( Dell, HP or what ever the PC is ). At the web site you should find section that says drivers and support, or something like that. It will have you select your make and model. You should find the correct drivers there.
Hope this helps.
Good Luck
cookEmonster
Posted on Oct 17, 2010
Stuck at Motherboard splash screen
your stuck at the boot from DVD, you must boot form C to finish installation.
Jul 27, 2014 | EliteGroup P4M800-M7 Motherboard
Intel server MB
Find out which BIOS is installed (websearch on server model) then search for Bios Beep Codes for that BIOS. Check what 4-3 4-3 means, you may find it is something simple. If you can get floppy working you may be able to flash BIOS but again you need to know which one
Jul 17, 2013 | Intel n440bx - Server Dual Slot1...
I have a Dim8400 when starting I get 2 beeps then a black screen
Ok to fix that go into your bios when your starting your pc F2, Del are usually the common buttons to get into the bios.
Once in there will be an option somewhere for boot floopy seek, disable it and you won't have that problem anymore :)
Thank you for stopping by Fixya! Feel free to leave positive feedback if this helps.
Feb 08, 2009 | Dell Dimension 8400 PC Desktop
Upgrading RAM from 512MB to 2 GB
.Yes you should update the bios. The asus support website has everything you need to do this also they will have step by step instructions to do so.
Dec 15, 2008 | ASUS P4S533-MX Motherboard
BootBlock BIOS v1.0 BIOS ROM checksum error
Kevin, when you do get this going it is going to be a beast.Nice choices on the hardware. It appears that you are getting text in the bios menu and that is a real good sign. One bit of text you typed might be a clue." You typed Detecting floppy drive A media . . .
Drive A error. System halt" And you said that you had no Floppy. On the first screen were you see your time etc there will be something that says halt on all errors. Change that to halt on keyboard errors only. The wording may be different but you get the gist right?You don't want the bios seeing no floppy and halting on that.I hope this helps you and don't get discouraged. There is usually a simple answer.
Dec 13, 2008 | ASUS A8N-E Motherboard
MY PC START BOOTING BUT DOESN'T FINISH THE PROCESS.....
boot from the cd and format the system and install newly and give some space to c:drive or any drive where u install the o.s
Jun 09, 2008 | Computers & Internet
Shutdown at Windows Log-in or Desktop
Hi kpspero, I gather you can get into you're bios? Once there go to hardware monitor (page 26 in you're manual, which should allow you to watch the motherboard temp & CPU temp. You're CPU may be overheating. (Keep the case closed when checking this). Normal operation. Did you add thermal grease between the CPU & heatsink? Go to page 4 & 5 of you're manual. Check that you have connected number 21, Auxiliary 4-pin power connector.
Two more thoughts. If everything is connected correctly & you're system is not over heating, try updating the bios. Click on this link which will take you to ECS's web site for you're board.
http://www.ecs.com.tw/ECSWebSite/Products/ProductsDetail.aspx?detailid=533&DetailName=Bios&MenuID=44&LanID=0
After flashing the bios, re-check you're bios settings. There are many updates for the 915PL-A2 MB & for windows. Did you hear any beeps from the PC during boot up? Did you connect the motherboard speaker? If you do not have a motherboard speaker you can get one from this site:
http://store.cwc-group.com/casp.html Lastly, since you can get to you're desktop, from time to time. Is this a fresh install of windows XP? Have you installed windows more than once? If you said yes to either. Download the hard drives manufactures bootable floppy disk setup software/tools/utilities & use that floppy to format the hard drive & setup the drive. Do not use windows to perform the format. Install ECS's CD software/drivers after windows has been installed.
If you're system continues to has this shut down problem, post back & I'll go from there.
Good Luck!
Mike
Jun 08, 2008 | EliteGroup (ECS 915PL-A2) Motherboard
Windows Server wont load
You need to install the raid drivers during the OS installation otherwise the setup program will not recognise it. At the beginning of the setup, just after the black screen disappears and the setup screen appears, it will say at the bottom: "Press F6 if you want to install third party RAID / SCSI drivers" or something along those lines. That's where you dive for the F6 button and install the drivers from floppy disk. I'm sure you know where to get the drivers from, if not, do reply and ask. Good luck!
Aug 31, 2007 | Celestica A8440 Server
Motherboard is dead
remove the RAM. boot minimal only (floppy). get to BIOS screen. reset to factory default. try again with boot floppy. if ok, re-install RAM and repeat
May 31, 2007 | Intel SuperMicro SUPER Motherboard - 810...
Intel n440bx - Server Dual Slot1 Motherboard N440bx 686238 Logo
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
