Question about Acer Aspire Computers & Internet
Acer Aspire One D250 need to open to resolder the ac jack.
    Top Expert:
  • 12,223 Answers
Download the owner manual from your manufacturer suspplier and follow the steps for open the case,and resolder.
Otherwise you must call and get support via ONLINE chat with ACER GO http://www.acer.com/worldwide/support/
God bless you
Posted on Jul 17, 2013
MPetro302
  • 298 Answers
SOURCE: Need to open Advent 7072 case to resolder power jack socket...How?
This is something that should be left to a professional. A local repair shop should be able to handle this task easily. but if you insist you can try here
Posted on Apr 17, 2009
callonafo
  • 174 Answers
SOURCE: how to enable bluetooth
First of all you need to connect bluetooth device to the laptop because most Acer laptops don't usually come with bluetooth device but they have the software/driver that will make bluetooth to work on it. So, I will advice that you get an external bluetooth device connect it to your laptop, the bluetooth application will make the bluetooth device to work. Thanks
Posted on Sep 30, 2009
parrotheadpc
  • 2600 Answers
SOURCE: I have an acer Aspire one d250 and I dont know the
Here is the link for the service manual, check out page 113, it goes over the procedure for jumping the motherboard and clearing the Cmos.
http://tim.id.au/laptops/acer/aspire%20one.pdf
Posted on Oct 03, 2009
Geekman
  • 32281 Answers
SOURCE: Acer Aspire One D250 - Weak network signal
There are a few things that can cause you to lose wireless connection with your wireless router.
1. Weak signal strength, check the signal strength on your wireless card. If it is weak move the wireless router away from brick or concrete walls and if possible locate the wireless router higher up.
2. Have you secured your wireless router from people near your from unauthorized access? ie. change the default password, setup encryption use WPA2 or WPA, change the default SSID, and turn off SSID broadcast, and for added protection, enable MAC address filtering which allows only the MAC address/es of your wireless card/s to connect to your wireless router.
3. You could be getting interference from electrical sources such as air conditioners, arc welders, washing machines etc. If so, the power supply to the wireless routers and computers etc should be connected to a surge protection power board, better still connect your computer equipment to an UPS (Uninterrupted Power Supply).
4. Check the channels of the wireless routers and access points in your area and change the broadcast channel on your wireless router to an unused channel or one that is currently used but has the weakest signal strength. This will minimize interference with your wireless router from other wireless routers and access points in your area.
Posted on Dec 26, 2009
varun_engr
  • 516 Answers
SOURCE: ace aspire d250 wireless switch is not working
Read these carefully and do as the manual describes..
http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man
Posted on May 30, 2010
My acer aspire 4730Z is not turning ON....battery is down....when am connecting dh charger pin to dh lap, dh green indicator of dh charger goes on blinking. Lap top is like completely dead dat even dh...
Here below are possible causes and troubleshooting steps of laptop that can't power on, hope it may help:
Possible causes:
1. AC adapter failure.
2. Power jack failure.
3. Motherboard failure.
Possible troubleshooting steps and repair solutions:
1. Test the AC adapter with a digital multimeter. It's possible that you have a failed AC adapter. If you don't have a multimeter, test your laptop with another known good AC adapter.
2.It's possible that power jack (socket where you plug the AC adapter) is broken. Remove the motherboard and take a closer look at the power jack. In some cases you can fix the jack by resoldering it on the motherboard. In other cases you have to replace the jack with a new one. Using a multimeter, test if the power goes to the motherboard through the jack.
3. If replacing the AC power adapter and jack on the motherboard doesn't help, most likely you have a bad motherboard. Replace the motherboard.
Replacement Acer Aspire 4730 AC Adapter 65Watt 19V 3.42A
Intocircuit Acer Aspire 4730 AC Adapter 65Watt 19V 3.42A
Nov 19, 2012 | Acer Computers & Internet
Does this computer have a dc power jack plug or cable
Acer Aspire One D250 AOD250 has cabled dc jack, do not need to solder, plug in and your laptop will work, view this page for reference: http://www.lapdiy.com/acer-aspire-one-d250-aod250-wire-harness-power-jack-dc-in-cable-p-26502.html
hope this can help you!
Dec 27, 2011 | Acer Laptop DC Power Jack for Acer Aspire...
My acer aspire 4740g does not power on. i have removed the battery and directly connected to the power supply but still does not turn on.
Problem description:
The laptop is completely dead. When you plug the AC adapter and press on the power button, nothing happens. The laptop has no signs of life at all. None of the LED lights is working.
Possible cause:
Possible troubleshooting steps and repair solution:
1. Test the AC adapter with a multimeter. It's possible that you have a failed AC adapter. If you don't have a multimeter, test your laptop with another known good AC adapter.
Acer Aspire 4740 AC Adapter
2. It's possible that power jack (socket where you plug the AC adapter) is broken. Remove the motherboard and take a closer look at the power jack. In some cases you can fix the jack by resoldering it on the motherboard. In other cases you have to replace the jack with a new one.
Apr 21, 2011 | Acer Aspire 4235 4240 4535 4535G 4540...
No power at all, tried a new charger still no power and replaced the battery.
Hi
After the battery and AC cord replacement and still not getting power there's only once culprit there and that is the motherboard of the laptop. I recommend you call Acer and have them replace it for you. Thanks
Feb 21, 2011 | Acer Laptop DC Power Jack for Acer Aspire...
My Acer aspire 4935 is not recognizing the AC adapter. When ever I shutdown the system and connects the AC adapter, it works and the charging LED lights up. Once I press the power button to boot the...
Problem description:The battery charges only when the laptop turned off. The battery charge LED lights up as normal and the battery gets charged to 100% while the laptop is off.
When the laptop is turned on, the battery charge LED goes off even if the adapter is still plugged in.
Possible cause:1. AC power adapter failure.
2. Battery failure.
3. Broken/loose power jack.
4. Motherboard failure.
Possible troubleshooting steps and repair solution:1. This problem could be related to a faulty AC power adapter. It's possible that the AC adapter doesn't provide enough power when plugged into the laptop. To find out if this is your problem, you'll have to test the laptop with another working adapter.Replace the adapter if needed.
http://www.chargerbuy.com/replacement-acer-aspire-9400-ac-adapter-19v-3-42a.html
2. There is a slight chance that you have bad battery. Test the laptop with a know good battery and replace the faulty one if needed.
3. The battery charge problem could be related to the power jack. Maybe the jack is broken or not making good contact with the motherboard. It is necessary to remove the motherboard and take a closer look at the power jack. Resolder or replace the jack if needed.
4. If the power jack is in a good working shape and new power adapter with battery do not fix the problem, most likely you have a faulty motherboard. Replace the motherboard if needed.
Feb 09, 2011 | Acer Aspire 4730-4947 Notebook
We bought in the USA a KAV60/AOD250 and use here in the UK with an adaptor for the different electricity. Unfortunately something has gone wrong with the leads as it sometimes shows up the notepad is on...
Here is the link to a company in Canada that has replacement AC adapters for Acer. The AC adapter for the Acer Aspire One D250 has a DC output of 19 volts at 1.58 amps which is what the AC adapter at the following link has. The price is C$12.99 so it is relatively inexpensive.
http://www.battdepot.ca/model/acer/aspire+one+a110-1295/ac19v30u.aspx
If you are handy with a soldering iron, you might try wiggling along the wire from the adapter to the plug on the D250. You might find one point where the wiggling consistently turns the D250 battery led on and off. If so then you can cut the offending section out and resolder the pair of wires back together. Make sure you don't switch the wires around. The plug has a negative shell and a positive tip. Should check with a voltmeter before you solder the wires and also recheck afterwards at the plug itself. Also make sure the wires at the solder point are well insulated so as not to short out across the pair. If you have in any doubts about doing this kind of repair, it would be better to just buy a replacement adapter.
Finally, you may be able to find an AC adapter retailer in the UK so as to possible have lower shipping costs. All I did was just google search "acer aspire one ac adapter"....
Feb 01, 2011 | Acer Laptop DC Power Jack for Acer Aspire...
How do I connect my acer aspire 5050 to TV?
Since the Acer Aspire One D250 only has VGA output for its video, you will need a VGA cable to connect between the D250 and a TV that accepts VGA input as a video source. The sound is separate. A mini-stereo jack on an audio cable with two RCA phono plugs on the other end would be used to connect the D250 audio output (usually used for headphones) to the left and right audio inputs on the TV. You may need to use the TV setup screens to select the proper video and audio sources. With the TV on and proper video source selected, you now should be able to press Fn and F5 to get a menu in the middle of the D250's screen that allows you to select the video destination by holding down Fn key and pressing the F5 key repeatedly. The single large screen icon (3rd one from the left) is the one to select video output to VGA port only which would send it to your TV. The sound on the D250 does not need to be selected but you may wish to adjust its level and/or properties to be more suitable for TV.
Jan 19, 2011 | Acer Aspire One D250 Netbook
How do you remove the keyboard from an Acer Aspire 5810tz-4657? Trying to resolder the ac jack and can't get it to disassemble
HI There,
Below is the link to your Service Manual download. The download is done through Rapidshare which has a Pay or Free choice. Sometimes you need patience to get the system to get you the free choice but it's worth the wait.
http://printer1.blogspot.com/2009/01/acer-aspire-3690-service-manual.html
Best Regards,
Marcus
Sep 22, 2010 | Acer Aspire 3690-2196 Notebook
Computers & Internet Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
