Airforce wap35dih Hw do I empty the water tank?
Hi I have problems with my mitsubishi dehumidifier Oasis Elite MJ-E-142NX-A1 The water tank full light stays on even though the tank is empty. I have emptied the water and replaced the container care
Sounds like your float is stuck in the full position, or the sensor that shows full is stuck on full.
If tank is empty but shows full, problem lies where full signal is coming from.
Aug 19, 2014 | Dehumidifiers
Why does my water container fill up even though my machine is plumbed in?
This looks like a fault. The plastic tank has two reed switches that measure 'tank empty' and 'tank half full'. When the tank is empty the inlet solenoids (there are 2 for safety) open and water enters the tank but not so much to fill the tank to the half way level. In normal operation the level water in the tank will drop and then more water is allowed in. In your case it appears the 'half full' reed switch is being activated because the solenoids are not closing off properly and water is leaking in and filling the tank. If you do not empty it then eventually it will fill and leak into the leak. The problem can be caused by either low water pressure (below 145 psi) or sticky solenoid. If is the solenoid then the Miele solution will be to replace both solenoids. Alternately you may be able to remove, take apart and clean. Also check that you have a mesh filter at connection to tap. Also you can temporarily fix the problem by turning off the water at the tap and re-programming machine to 'turn off' the plumed water line. regards
May 31, 2014 | Miele Coffee System
I have a Reliance 501 HWH, 15 yrs old. Nary a problem until now. Yesterday, HW was very hot. Today, no HW. I'm thinking of replacing both elements and thermostats due to the age. Sound reasonable?
At fifteen years of age it would be less cost over time and labor to replace the whole tank. How efficient is your old one and being it runs hot all the time you could have a tank that will not last very long anyway. Mine sprung a leak at 18 years and made a big mess.
May 15, 2014 | Reliance Water Heater #6-50-DJRT 50GAL...
No Hot water Pressure with On Demand
There is an inlet screen on demand water heaters. Look for that and clean it. The tubes in the heat exchanger could be clogged. The manual will tell how to clean it. This is very involved and uses acid. It can be dangerous, so I recommend you have it done.
Apr 12, 2013 | Amtrol 30 Extrol 4.4 Gallon Expansion Tank
My shower water temperature is way too hot. How do I reduce it?
go to the hot water heater and turn it down 1\2 way a start from there
Jul 19, 2011 | Heating & Cooling
It is not draining the water out it is a haier hw-c1460tveme-0
Hi, you can drain the water by disconnecting the grey empty hose putting the end in a bucket and lowering the pipe flat and below the tub level, the water will empty under gravity into the bucket.
When its empty CLICK HERE to follow the instructions ho how to check and empty the filter of any debris, then try the machine again, is it still does not empty then suspect pump failure.
hope this helps.
Feb 12, 2011 | Washing Machines
My Amtrol Therm-x-trol tank has dropped 6 to 8 inches since it was installed, and a few drops of water are coming from the washer where is attached to the water heater. It is very heavy now. Could it be...
Sounds like the internal diaphragm has ruptured. The tank should be replaced immediately. You should disconnect the electrical power to the water heater and close off the incoming water supply to the heater. Open a HW faucet to relieve the pressure and remove the tank. Be careful cause you are going to get wet. Replace with a new tank.
Sep 30, 2010 | Amtrol ST-5-C THERM-X-TROL ASME Expansion...
Changed r/o 3 filters and now water produces 2cups
The pressure on an EMPTY tank should be 8-10 psi. Be sure the tank is empty before checking the pressure. A good way to empty the tank is to connect a small air compressor to the air valve on the tank, open the systems faucet, and turn on the compressor. A bicycle pump works too....Just more of a workout:)
Jul 08, 2010 | Culligan Sales #SY-750S Under Sink Water...
I have an Airforce BQDD122FW Dessicant Dehumidifier. When I bought it last year it worked OK. I have started using it again this year and although the motor appears to run normally it no longer collects...
Hi There, you have faulty heater inside. They are all the same Delonghi, meaco, Logik, ecoair .Airforce
I have done 100s now. If you good you can just twist the wire in the heater and will go again without any problems.
Its just basic steel wire twisted like a spring.
anyon eneeds help sam on 07590 057545
Oct 24, 2009 | Dehumidifiers
Heating & Cooling Logo
57 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
