Philips 160E lcd monitor resolution set to lowest
4 Suggested Answers
  • 526 Answers
SOURCE: AOC 771S monitor always appear
the lowest resolution is not always supported. by the range maybe referring to the frequency. change that, that should work. if you are not sure, look at your monitors manual, it will tell you resolution as well as frequency optimal settings
Posted on Apr 20, 2009
kamal1984
  • 1383 Answers
SOURCE: problem of resolution in my lg lcd.
when u power up the computer press F8 key then enter in enable vga mode then change screen resolution to 1024*768
thats it.
Posted on Jun 10, 2009
WinstonMeyn
  • 141 Answers
SOURCE: I have an Acer G185H LCD monitor that I just
Update the Graphic Card driver
Posted on Jul 04, 2010
My NEC MultiSync LCD 1765 monitor boots up to the lowest resolution available. When I attempt to correct the resolution through the Display Options in my Control Panel Settings, I set it at the highest...
Try connecting the NEC to a different computer, to see if it correctly accepts 1280-by-1024.
If so, then there's nothing wrong with the monitor, and the fault lies with either the video-adapter in your computer, or something messed-up with your installed copy of Windows.
Try replacing the video-adapter.
Dec 29, 2010 | NEC MultiSync LCD1765 17" Flat Panel LCD...
Using HDMI : PC - TV picture isn't clear?
Check the resolution you have that port (monitor) set to. Most likely you have it set at a resolution that the TV doesn't like, or perhaps it is set at its lowest possible resolution. Just make sure it is set at whatever the highest your TV handles, 1920x1080, 1280x720, etc.
Nov 15, 2009 | Philips TV Tuner Video Capture PCI Card -...
AOC 771S monitor always appear "not support out of range even if i already set my resolution to lowest.
Apr 20, 2009 | Computers & Internet
Monitor not working
You will need to change the display settings for the type of lcd monitor you have, it is a wide screen I am assuming, you can change this by right clicking on the desktop select properties then settings the screen resolution should be on the middle left side and change this until you get a screen that you like There is also an advanced setting then select monitor at the top tab and change to refresh rate to the lowest setting (60 hz) this should get the HCL monitor up then change the setting until they dont work the operating system will revert to the previous settings if you cant see anything after a change. you may also need to use the automated setup on the lcd monitor select auto from the menu (osd). Now if you can not do this on the HCL lcd you may need to use that other Samsung monitor and then set up on that at the lowest resolution so that the lcd can be changed with a working screen. Lastly you may need to uninstall the samsung monitor drivers if you installed those, and leave the generic drivers in for the monitor (plug and play monitor).
I am making some guesses here as you did not tell me if the 1st Samsung monitor was a lcd also , and if the second HCL monitor is a wide screen etc what type of operating system are you running is also important 98 is fussy and 2000 is much more simplified as is XP , vista would be garbage (if you could get it to run on a pIII),
As for reasons for resolution problems, way too many variables to discuss in a short answer forum like this, sufficed to say that the resolution is different because in the past there were lower resolution (less pixels) on monitors, the refresh rates were different by manufacturers and the way the lines were scanned could be different, so setup of the monitor with the video card was also very important interlacing etc was also handled differently until that industry decided on a common standard.
I hope this helps you to get the monitor up and running.
Jul 17, 2008 | Computers & Internet
Reducing resolution
Set the resolution you want to use in the GAME. Under the Settings heading, when you go into the game!
damnor01
Jul 14, 2008 | LG Flatron L1515S 15" LCD Monitor
ViewSonic VG900 and Raritan Paragon KVM won't play.
hi there, yes, go to safe mode first, then adjust the resolution to the lowest and restrat the unit. then you will boot up for a lower resolution and adjust it to your desire resolution. note that don't set it to higher resolution it will go blank again. ty
Feb 18, 2008 | ViewSonic VG900 19" Flat Panel LCD Monitor
Annoying Nuisance on the monitor
Run your system in 'Safe Mode'. Go to Display settings and set lowest possible resolution. Then restart computer and run windows again in normal mode. Should have normal screen. If this will not work - then under safe mode uninstall graphic card. Then run windows with standard ones and in LOWEST possible resolution install drivers again. I have had it many times and it made swear first time.
Oct 28, 2007 | Acer AL1916W 19" LCD Monitor
No signal on monitor
As I write to some other question:
Oct 25, 2007 | Acer AL1916W 19" LCD Monitor
How to Adjust the sceen ratio from 16:9 to 4:3
Since it's a widescreen monitor, the streching is likely from using a 4:3 ratio resolution on a 16:9 ratio monitor. Try setting the operating systems display resolution to 1440x900, since that's your monitor's native resolution (LCD monitors only really have one resolution). In Windows, resolution settings are found by right-clicking on the desktop, click properties, and go to the Settings tab.
Aug 05, 2007 | Philips 190CW7CS27 Monitor
Computers & Internet Logo
57 people viewed this question
David Payne
David Payne
