Panasonic color tv
No power
    Top Expert:
  • Televison & ... Master
  • 74,185 Answers
Check and replace damaged componet/s at its main power regulator circuit section.
Posted on Jul 17, 2013
TC-P55VT30
Sounds like a panel fault. Contact the authorized service center for Panasonic. Gopakumar Gopalan Google
Mar 01, 2014 | Panasonic TH-42PZ700U 42 in. Plasma...
Color settings for an older panasonic tv
a model number would help to give an informed answer.
Dec 04, 2012 | Panasonic Televison & Video
Hi - we have problem with Viera tv. no sound or pic. switch on green light briefly. then straight to red light flashes 4 times then 3 sec interval then repeat. tv is just over 13 months old. any ideas.?...
Instructions Things You'll Need:
  • Damp Cloth
  • Fuse
  • TV Remote Control
  1. Ensure the power cable is securely fitted to a wall output if you can't get your Panasonic LCD TV to power up. Try testing the wall outlet with another appliance to make sure there is not electrical fault with the outlet itself. If there is still no power, a blown fuse may need replacing.
  2. Switch off the color correction option if you are using HDMI cables and the displayed image has unnatural colors. For instance, if a picture area that should be red is blue or green, then the color correction option may be the issue. Press OK on your remote control. Now access the Other Adjust option and scroll down to the Color Correction option. You can now turn the setting off, which should restore normal image quality.
  3. Press the Mute button if you can't get your Panasonic LCD television to produce sound. This may have been pressed in error, cutting off the sound. Check the volume settings on any other devices, such as a games console or DVD player, that are connected to your LCD TV. If the volume is set to low on such a device, it can limit the sound output on your TV.
  4. Check that the air vents at the lower rear of your Panasonic LCD TV are free of dirt and debris. Dirt can accumulate in these areas, causing the cooling function to under-perform. Panasonic LCD sets come with built-in safety features that shut off the power if your set becomes too hot. Clean the air vents with a damp, rather than wet cloth. Dust and vacuum the room regularly to prevent the problem from recurring.
Jan 24, 2011 | Panasonic Viera TH-42PZ80U Plasma TV
Picture has shadows and blue is a dominant color.
Hello, your Panasonic rear projection TV might be due for some color convergence repair, there are some power amplifiers that overheat and begin loosing the color correction control.
Dec 11, 2010 | Panasonic PT-47WX53 47" Rear Projection...
I need Panasonic CT36SL14 service manual
tv powers up but no picture or sound. DVD works great has great picture and sound.
Apr 02, 2009 | Panasonic CT-36SL14 36" TV
The color converter
Seems to me you maybe experiencing a convergence issue rather than the color converter. (Don't know what he means by that for that I am an a tv repair technician).
If it is what I beleive it to be, you need and experience tech to do the work for you. It usually contains replacing two convergence IC packs along with some resistors and sometimes power supply parts. All wich requires good soldering work.
Jan 09, 2009 | Panasonic PT-47WX53 47" Rear Projection...
I have a panasonic hd tv when you power up it takes a minuate and then you get colored lines through the center of the tv and then goes black again and the power light flashes.
Need the model number and also how many times the power indicator is flashing. Please respond to this same post so I have access to previously posted info
Jun 30, 2008 | Panasonic Televison & Video
Panasonic PT-52DL10 DLP TV
Color wheel bearing can make the noise you describe, and that will also cause color distortions.
Feb 15, 2008 | Panasonic PT-50DL54 50" Rear Projection...
Panasonic ct-36sl13g
Mine did same thing. Found a fuse blown by the power cord inside case. Replaced it and power came back on.
Jan 13, 2008 | Panasonic Digital Video Duplex, Color...
Televison & Video Logo
11 people viewed this question
Top Televison & Video Experts
Electro Med Services...
