Question about Nintendo DS Video Game Consoles & Games
How do I turn on the TV in level 36, of Hidden Objects Mystery Stories
I looked for a remote control, but found nothing. Simply clicking on the TV does NO good.
    New Friend:
    Problem Solver:
  • 12 Answers
  • The yellow dart is on the top left side, next to the Wanted Poster.
  • The dartboard is on the right side, next to the window.
  • Grab the yellow dart and drag it onto the dart board.
  • The dart and dartboard are highlighted in blue in the screenshot.
  • Please look at the screenshot for the location of all the items on this level.
Posted on Jul 19, 2013
Red light goes on and off
Needs the button put back into place. Look under the cabinet to see if there is an access panel below the switch, would go for all external controls. There would be a chassis with all the controls mounted to it.
Pull the plug before doing any repairs.
Look to see what it would look like in it's normal position. Something has moved out of place that holds the switch to the panel. Very tedious if you have to remove the whole housing.
Mar 14, 2013 | Toshiba 36A43 36" TV
Mystery stories..... where is the construction light for battery to go into
It's on the right, it's green & looks like a mango on a box! I hunted for ages. It's like the lights you get on roadworks that hand on bollards.
May 20, 2011 | Knowledge Adventure Hidden Objects:...
How do i get the 03 off the screen
ok this may or may not help and here goes there should be just a simple display button to remove this feature but with these older model tv's i found an hidden trick when you take the remote apart sometimes there is extra pick ups on the board with no holes for buttons provided you would have never been able to access a feature not said to be on the tv? tricky eh? yes that means to get that next model up with more features they simply restricted your features with a limited remote access as my old tv didnt have display feature to have the capability to have the 03 your trying to remove until i drilled the holes in my remote and added in buttons from an old calculator allowing some tv's that never had a sleep feature to suddenly adopt it through this process also allowing you to change color of the channels showing up on your tv
Nov 20, 2010 | JVC AV-36320 36" TV
I have a 36" insignia tv and just bought a sony dvd player and in the user manual for the dvd player there is no code for the remote for an insignia tv which i find wierd seeing as insignia is made by sony...
A variety of remote control codes can be found at InsigniaProducts.com; just search for your TV model number and click Support. Also, try codes for the following brands: Orion, Emerson, Memorex, Sansui, Sylvania, Zenith.
Jun 07, 2010 | Sony DVP-NS55P DVD Player
I'm looking for the manual for a Mitsubishi VCR HSU447 with the remote control RM75502 so I can program my TV to it. Thanks
1.- Turn off your TV
2.- On the remote control, set the VCR/TV slide switch to TV position.
3.- While holding in SP/EP button, press the code button listed below that corresponds to the brand of your TV
4.- Press TV POWER on the remote control. Once your TV has turned on, your remote is set up to operate your brand
TV.
Brand of TV Brand Code Button
Mitsubishi 1,2,3
Fisher 0
G.E. VOLUME UP
Goldstar 2,9
Hitachi 8
JVC MUTE
Magnavox 4
NEC 2,9
Panasonic CHANNEL UP, CHANNEL DOWN
Pioneer 6
Philips 4
Proscan VOLUME UP
Quasar CHANNEL DOWN
RCA VOLUME UP
Sanyo 0
Sharp 3,5
Sony VOLUME DOWN
Toshiba 7
Zenith INPUT
I finnaly found my VCR Manual, and I'm glad to share this info with you, because I was looking for the manual all
over the web and FOUND NOTHING!. Bye!
Mar 15, 2009 | Mitsubishi Televison & Video
Toshiba TV Remote Control not working
i have bought universal remote controls and they do not work. what can i do? i have bought rca universal philips universal remote,
Nov 17, 2007 | Toshiba 36HFX71 36" TV
No picture / No Sound / No nothing
that sounds like the Hi voltage transformer went bad.. If your a tech simply disconnect the horizontal output transistor and see if thats shorted. If it is then it is for sure the HV transformer. If its not shorted look in the main power supply. Its cost is around 40 bucks or so and the transistor is about 15 to 20 bucks. This entire repair should cost ya around 150 to 175. So if you decide this tv is the one you like then have it fixed. Good Luck
Jun 01, 2006 | Sony KV-36FS100 36" TV
36 inch television
your hitting the tv is going to get worse or cause other problems in the future as this is nothing more then a loose solder connection or a loose plug or cable. for you to find a problem like this will take a bit of troubleshooting in the power supply or the horizontal section of the tv. There is no real common problems I've found in the past with this model but if you know how to solder and your very carefull and not afraid to go wheres theres 100s of voltage then take off the back and start to probe around on the Printed curcuit board with a plastic tool and see if you can localize the connection problem BUT I would reconmend that you get a pro to find this for you as Im sure there would be no parts involved and should if he honest a small minimum labor charge But if you go in a mess something up dont expect the repair person to give ya a break. Now with the remote issue. I found that the ORIGINAL remote is available at http://www.remotes.com for $27.77 + shipping. Now thats a deal and a half if you ask me as I found out that from toshiba the want 59.95 + shipping.. Good Luck
May 06, 2006 | Toshiba 36A40 36" TV
Video Game Consoles & Games Logo
128 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Julian Wainwright
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
