Question about Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC
How booting time can be reduced?
My comp takes a lot of time to boot,first it shows d mother board name powered by mercury,then takes time to load the settings even after reducing the no of icons in the quick launch using ms configuration.
    Brigadier General:
  • 6,966 Answers
Hi, Since you have already lessen the startup programs and still you find the PC booting too slow for your liking, it may be that you need more RAM or your processor needs an upgrade. In any case, you can still further reduce booting time by not allowing some services of Windows XP not to load during boot. You of course have to initially determine if you need them or not. An example - if you are connected to your LAN by your networking card then Wireless Zero Configuration is not need and need not start, other are Windows Time, Uninterruptible Power Supply just to name a few. Another utility that helps improve booting time is constant and regular defrag of the HD. Still removal of unwanted, no longer used programs will also aid speed up your boot time. These are of course end run methods and shortcuts, nothing beats more memory. Good luck and kind regards.
Posted on Aug 28, 2007
    Problem Solver:
  • 11 Answers
Just check the BIOS settings whether everything is correct in that , Clean your RAM and refix it, Delete the Temp files used to load the PC
SOURCE:
My Gigabyte Mother Board shows some time Load Optimized Defaults then boot / Load Optimized Defaults then reboot / enter BIOS. How to fix it?
Two things come to mind first. Number one would be making sure you have the most up to date bios. Number two would be that maybe the motherboard battery is dying/dead and isn't holding enough charge to after being shut down to save the option you selected.
Apr 11, 2014 | Gigabyte Technology Gigabyte GA-H61M-S1...
CANNOT FORMET THE C PARTITION IT WILL SHOW THAT WINDOWS UNABLE TO FORMET ? WHAT IS THE PROBLOM & HOW TO RESLOVE CAN BE BOOT FOR MOTHER BOARD KOBP4266 NDFSMX -P4M266ISU IF SO MOTHER BOARD CD/SW?...
You cannot format the C drive or System drive with opened OS. But you will be able to format the drive on Boot, through A bootable CD/DVD or Any Other device!
Sep 01, 2011 | Mercury KVM266PM-U (KVM266PMUD1600)...
When I start the machine it is only showing mother board name further it is nor processing also no cursor coming
Your system is not booting
You remove all HDD/ DVD/and any other device
Power on with only mother board,
It will initialise all and rest with a message "BOOT FAILURE"
It means the M/B is good
Then connect the HDD and power on.
If not proced then try to re-load the operating system.
please vote for me if your problem sort out .
Let me know
Alex
May 21, 2011 | Mercury P4VM800M7 Motherboard
I have asus M2N68 am-plus mother board. When I switch on the comp. It takes about 10 seconds to show the boot screen. Want to know the reason behind this
hi,
it could be something is slightly loosen up in there. to check your load up time, go to start then right-click on my computer. click on properties. there you will see advance system settings, click on its tab.on the startup and recovery category, click on settings. there you will see how much time does your pc takes to load. if you can open up your pc and make sure that everything is hooked up properly, then switch it back on.
Jun 15, 2010 | ASUS M2N68-AM SE2 Motherboard
If i enable the USB drive in CMOS.after booting the system is hanged.only mother board name mercury is shown.
The problem is with the Installed USB Devices. Check whether you are using any of the USB slots in your system. If any printers or any other USB devices are installed the boot will check with these devices, so your system is getting hanged. Try to disable the USB booting or else remove the usb device and then boot. This will resolve your problem.
Oct 19, 2009 | Mercury P4VM800M7 Motherboard
PI845Z board shows usb1.1 cntrlr instead of usb 2.0.....
return it, it under warranty.. dont loss your money.. or change another board ther are a lot of board.... all motherboard 1 year warranty if you found some problem or factory defect return it dont broke the warranty..
Sep 05, 2009 | ASUS P5N-E SLI Motherboard
Problems with my mother!
PUT YOUR OLD COMP BACK THE WAY IT WAS .IF IT BOOTS AS ALWAYS,GO TO CONTROL PANEL.SELECT "SYSTEM",SELECT DEVICE MGR,SELECT DISK DRIVES.RIGHT CLICK ON YOUR SLAVE,SELECT UNINSTALL,FOLLOW INSTRUCTS.TURN OFF COMP AND REMOVE YOUR SLAVE.REBOOT.HOPE IT WORKS FOR YOU!
BUME
Mar 07, 2009 | Intel D865GLC Motherboard
System not booting
Fiend your solution direct from mercury. Here is your solution.....
http://www.mercury.com/motherboard/prob676ijt65/solution
aamknr-23
Feb 03, 2009 | Mercury P4VM800M7 Motherboard
AK75
my mother board is mercury. Some numbers is there like p19 45gcm v1.0a 15-v33-011098
Apr 19, 2008 | AOpen AK75 (91.89X10.001) Motherboard
Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC Logo
73 people viewed this question
Top Microsoft Computers & Internet Experts
Ekse
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
