Question about Dryers
I have xp-2 motor with a broken fan 1/2 shaft 5 1/2 wide 5 blade does anybody where i can get new or used fan? dry side of motor. ...
    Genius:
  • 1,617 Answers
What make/model?
Posted on Jul 17, 2013
Noggin
  • 944 Answers
SOURCE: Pedestal fan motor
Go to this link and find the dealer local to you; http://hamptonbayinfo.com/Product.aspx?pid=9eb435cd-4f97-4074-bdf3-630f1efd7a83&cid=791075 They should be able to either supply parts or tell you where to get them. Hope this helps, sorry for the delay but there are more problems than experts available at the minute :)
Posted on Mar 22, 2007
Buffalo12980
  • 625 Answers
SOURCE: blade is loose
on the inner part of the motor [fan side] look for an external snap ring and a fiber spacer. the armature fits all the way into the rear part of the housing, the other housing goes over the motor shaft and must press against the snap ring and fiber washer.
Posted on Sep 07, 2007
  • 244 Answers
SOURCE: broken mount attic exhaust fan
buy new blade or keep soaking shaft.collar with rust penetrant,
Posted on Jan 16, 2009
  • 5 Answers
SOURCE: lasko fan
I can tell you how to take the fan blades off your Lasko Model 3723 fan, but you might not be able to use it on your other fan. The reason why is that the motors, although similar, may not have the same diameter shaft.
Of course, you should have the power cord unplugged from the AC outlet before removing the front fan grille and placing your hands on the blades. Safety first!
The fan blades and hub are a single unit that stretches to fit onto the motor shaft. There is no setscrew at all. Take any sort of metal bar or tool such as a screwdriver or pry bar and carefully lever the hub off the shaft by pressing your lever to lift the hub a small fraction of an inch on each side, working the hub slowly upwards against the long vertical bars that support the motor. If you have reasonably strong hands, you may be able to pull the hub toward you by placing your fingertips under the edge of the hub and pressing with your thumbs against the vertical support bars as needed. It's not too difficult to do.
Posted on Jun 11, 2009
SOURCE: I have two (2) 16 in Stand Fans (AECS16W) Both
Hello Pjhenger,
Please call the Wind Chaser assistance number 800.
If you are directed to send in your product, send it postage prepaid to:
WindChaser Products, Inc
4130 Del Rey Avenue
Marina Del Rey, CA 90292
Attn: Customer Service
Please make sure you include your name, address and phone number.
You can also call toll free phone number is 1-800-405-2943. You will be directed to a Customer Service Rep. Monday thru Friday, 8:30 am - 4:30 pm PST.
Posted on Jul 04, 2011
Only one fan working
There are two causes of your problems:
1. The fan needs you to manually turn it to start running.
Problem: The motor bearings both ends are dried out.
Solution:
1. Remove the motor/fan from the motor housing (there are two screws that hold the motor to the housing. The only way I know how to get to the screw is to bend one of the fan blade up and use a long screw driver to get to the screws.
2. Remove the two screws that hold the bearings to the motor.
3. Detach the bottom bearing (opposite of the fan end.) You might have to use a flat screw driver to pry the bearing off.
4. Use a Q-tip and soak it with motor oil or grease then lubri- cate the fan end shaft/bearing.
5. Use a Q-tip + alcohol to clean up the bottom bearing hole, then lubricate it with grease or motor oil.
6. Put the motor and bearings back together and make sure that the fan can turn freely now.
7. Install the motor/fan back into it housing.
The fan should turn on its own without you helping it.
If the fan won't turn, you have a bigger problem. See below.
2. The fan won't turn at all and is really tight even when you try to
turn it by hand.
Problem: The transformer coil(s) is/are burnt out. Chances are you let the fan run dry to a point that it squealed and started to smell like it was burning before it quit all together.
Solution 1:
1. Remove the filters and their housing on the bad fan side.
2. Duct tape a piece of plastic over the bad fan opening.
3. Run the humidifier with one fan. It works just as well.
Solution 2:
1. Buy a new humidifier.
2. Make sure you lubricate the bearings as soon as the motor begins to squeal.
Solution 3: You need knowledge of electricity
1. Take the motor/fan out from the housing.
2. Use a vote meter to check the resistance in both coil of the transformer; should read about 17 ohms. The coil(s) that has a high reading or if the meter shows 'OL' is bad. Remove the Yellow tape from the coil to see if you have a loose soldering joint between the coil wiring the electrical cord. If yes, solder the joint back together, check the resistance again to make sure you have about 17 ohms. If the answer is yes, put the yellow tape back on the coil and use electrical tape to secure the tape. Hopefully, the fan should work now. Good luck!
Feb 03, 2013 | Kenmore 14417 Humidifier
Motor stopped working. I need aloha breeze phone number
Aloha Breeze fans are manufactured by Litex. You can contact them at:
3401 West Trinity Blvd.
Grand Prairie, TX 75050
Phone: 800-527-1292
Jul 20, 2011 | Tower Aloha Breeze Fan
I have a model 5BS520C. The light works but when I pull the chain for the fan, I hear the sound of three speeds but the blades do not turn. ed.pfohl@gmail.com
Here some toubleshooting:
Problem 1. Fan will not start.
Probable Cause
1. Fuse or circuit breaker blown.
2. Loose power line connections to the fan, or loose wire connections in the switch housing.
3. Reversing switch in neutral position.
Suggested Remedy
1. Check main and branch circuit fuses or circuit breakers.
2. Check line wire connections to fan and switch wire connections in the switch housing.
3. Make sure reversing switch position is all the way to one side.
WARNING: Make sure main power is turned off.
Problem 2. Fan sounds noisy.
Probable Cause
1. Blades not attached to fan.
2. Loose screws in motor housing.
3. Screws securing fan blade flanges to motor hub are loose.
4. Switch housing binding against the blade hub.
5. Wire connectors inside switch housing rattling.
6. Screws holding blades to flanges are loose.
Suggested Remedy
1. Attach blades to fan before operating.
2. Check to make sure all screws in motor housing are snug (not over-tight).
3. Check to make sure the screws which attach the fan flanges to the motor hub are tight.
4. Check to make sure that the switch housing does not bind against the blade hub.
5. Check to make sure wire connectors in switch housing are not rattling against each other or against the interior wall of the witch housing.
6. Tighten screws securely.
Problem 3. Fan wobbles
Probable Cause
1. Setscrew in motor coupling is loose.
2. Setscrew in the hanger ball/downrod assembly is loose.
4. Fan blade flanges not seated properly.
5. Hanger bracket and/or outlet box is not securely fastened.
6. Fan blades could be out of balance.
Suggested Remedy
1. Tighten the setscrew in the motor coupling.
2. Tighten the setscrew in the hanger ball/downrod assembly.
3. Check to be sure screws which attach the fan blade to motor hub are tight.
4. Check to be sure the fan blade flanges seat firmly and uniformly to the surface of the motor hub. If flanges are seated incorrectly, loosen the flange screws and retighten.
5. Tighten the hanger bracket screws to the outlet box, and/or secure outlet box.
6. Interchanging an adjacent (side-by-side) blade pair can redistribute the weight and result in smoother operation.
WARNING: FOR YOUR OWN SAFETY TURN OFF POWER AT FUSE BOX OR CIRCUIT BREAKER BEFORE TROUBLESHOOTING YOUR FAN!!!
Hope helps.
Sep 02, 2010 | Monte Carlo Dryers
How do i do it myself to install outdoor bower motor condensor motor 1/4 hospower 350 rpm and also the 5 amp capacitor. If i keep the 10 amp capacitor is that a problem?
Turn off power in all cases. If you are replacing the orignal motor for the 1st time. It might be easier if
you cut the wires near the control box and then wire
nut them together and wrap with electrical tape.
Remove the fan cover and unloosen bolt that hold the
fan to the frame or whatever it might be. After fan is out spray some WD40 that holds the fan blade to
the motor shaft. Measure the distance from the fan
blades to the motor.
Unloosen the screw that holds the fan blade to the
motor shaft.Take sand cloth and try to clean up
the shaft below the blades. Try to tap the fan blade
down towards the motor.If it moves sand the shaft above the blades. Take channel locks and grip the shaft below the blades, try turning the fan blade while
holding the shaft until it spins freely and the remove.
If the motor came with a 5mfd capacitor use it.
Jul 01, 2010 | Heating & Cooling
How to remove fan motor
Fan
When a fan malfunctions, the problem is usually loose or dirty blades. If the fan won't operate or if it's noisy, cleaning and tightening will usually fix it. Here's how to repair a room air conditioner's fan:
Step 1: Open cabinet and locate fan.
Step 2: Clean away any debris with vacuum and soft cloth.
Step 3: Check fan blade on motor shaft for looseness. Blade is fastened to shaft with setscrew at hub of blade.
Tighten setscrew with screwdriver or Allen wrench. If air conditioner has round vent fan, tighten fan on motor shaft by inserting long-blade screwdriver through port in fan.
Fan is installed in its housing with bolts, and vibration can loosen these fasteners. Then tighten them with wrench.
Step 4: If fan has oil ports, apply several drops of 20-weight nondetergent motor oil (not all-purpose oil) to each port at beginning of cooling season. Step 5: If you suspect fan motor is faulty, test it with VOM set to RX1 scale. Disconnect terminal wires from terminals, and clip probes of VOM to wires.
If meter reads between about 3 and 30 ohms, motor is functioning properly. If meter reads either zero or an extremely high number, replace motor.
To remove the fan motor, remove the fan, the power wires, and several mounting bolts. Install the new motor with the reverse procedure. However, if the condenser coil must be moved to get the fan out, do not try to remove the motor. Call a professional service person.
Mar 30, 2010 | Heating & Cooling
Have a kenmore electic dryer just changed out the heating element about 2 months ago dryer is not heating up properly taking 2 times to dry a load of clothes
check for a blockage in the evacuation hose (four inch tubing)
also, check to make sure the blower blades are turning (they can wear out and slip on the motor shaft). assuming the new element is still good, it is probably a blocking of air flow which will inhibit drying properly. or the blower fan blades are broken or worn. good luck. jay
Jan 04, 2010 | Kenmore Dryers
I have a HotPoint side by side refrigerator. Model # CSX22GAS, my ice is melting and in the freezer section there is a loud noise. as if the motor is running hard.
Below is a link courtesy of www.repairclinic.com, that shows the evaporator fan blade. This may have come loose from the fan motor shaft and may be striking the fan shroud or rattling on the motor shaft
A loose fan blade cause elevated temps. If the fan blade is loose, replace it, not repair it, to avoid further problems.
1. Evaporator Fan Blade:
http://www.repairclinic.com/SSPartDetail.aspx?s=t-CSX22GAS-%3d%3di2611&PartID=2611
2. Evaporator Fan Location: Mouse over parts for illustration.
http://www.repairclinic.com/Refrigerator-Side-By-Side-Appliance-Diagram
Aug 13, 2009 | Hotpoint Refrigerators
Noisy
Hello janeknows. The shaft of the fan motor may have a bearing gone bad. Follow these steps to locate problem. #1-turn power off by tripping the breaker, place your fingers on the shaft surrorting the blades & SLOWLY rotate the blades feeling for a catch or bump. A bump felt I suggest replacing the motor. No bump #2- remove the screws holding the cover supporting the control switches. Located among the wiring is a box with 2 or three wires. This is a capacitor. Note the info on the capacitor (1.4mf125v). Contact the fans Mgfr they may send you one for free if not visit your local hardware store and ask. Replace the unit using the wire caps in the unit or snip & strip the wire using new wire caps. Note witch wire went where. Turn power on and test operation.
Oct 13, 2008 | Hampton Bay 54 In. 5-Blade Fan, Chestnut,...
Lasko fan
Aug 15, 2008 | Lasko 3723 Floor / Box Fan
Dryers Logo
20 people viewed this question
Top Dryers Experts
