Question about Dishwashers
Hotpoint sdd910 Hotpoint dishwasher stops working error A 8 or A 10 flashes on the display. Any ideas wht this might be
SOURCE: Hotpoint Aquarius DWF50 Dishwasher, cycle
hotpoint dwf50 will not start, the fast wash and prewash buttons are flashing together.
Posted on Sep 25, 2008
SOURCE: Hotpoint DWT10 Dishwasher error codes/lights
food stuck in drain pump remove and clean out or scoop out - soak up all water then fill with 3 or 4 hot litres of water . cancel programme , start new one ( first thing unit does is switch to drain cycle ).
Then rock machine back and forth - this sometimes frees jammed debris thus pumping out of machine.
This works for me i have done it several times and it works
Posted on Feb 24, 2009
SOURCE: dwf50 hotpoint aquarius dishwasher
hi, just found this forum after searching the web 4 a solution to my hotpoint DWF50 problem.
I came down this morning to a machine which base tray was full of water and lights 3 ECO & 4 Fast flashing.
Anyway my solution was as i had seen a hotpoint engineer do once before was to press the start/reset button trip the catch, to fool the machine into thinking the door is closed then put in a program, press start, the machine hums slightly but doesnt do anything then after removing the large filter from the tray at the bottom underneath the lower basket insert a length of wire, with a loop on the end (Tip i used a wire coat hanger from the dry cleaners) poke in ythe hole that the dirty water drains from, after a bit of poking about the pump started working and the water drained away. Tip place a hook at the other end of your wire impliment to put your finger in to stop the wire getting caught in the pump mechanisim. After wards u have to hook back the door catch to the normal position, Tip another piece of the coat hanger with a right angled piece at the end will do this. This worked for me, saved me some money esp as D & G insurance ran out 2 weeks ago.....stu
Posted on Jun 22, 2009
SOURCE: Hotpoint Aquarius SDW60 Dishwasher
i have had this dishwasher sdw60 for 18 months and it just keeps beeping, i have cleaned it ,turned it off at the mains it just dont wont to work. please help.
Posted on Feb 08, 2010
SOURCE: Flashing lights on Hotpoint FDL570 Dishwasher
I had an identical problem with the salt and rinse aid lights on the left and the drying and end lights on the right flashing shortly after switching the dishwasher on. When I pulled it out, as this was the only way to look at the pipework, I noticed a big kink in the water hose. Removing this and obviously sorting out the flow problem has resolved the issue.
Posted on Apr 08, 2010
Hi we have a Hotpoint Aquarius FDAL28 dishwasher. Machine turns on, drains and fills but then 3 lights keep flashing and washer stops programme. Any ideas what problem could be?
Depending on which lights are flashing, there is either a problem with the electronic control module, or the pump is stuck or has a motor failure. You can see which by comparing which lights are flashing with the pattern on this page of error codes:
http://www.ukwhitegoods.co.uk/help/fault-codes/dishwasher-fault-codes/3293-hotpoint-fdl-series-dishwasher-fault-codes
Jul 15, 2017 | Hotpoint Washing Machines
Ihave a hotpoint SDD910 dishwasher. showing error A8 sometimes a10. any help please
Hello Jack Poole,
What I'm getting (here in USA) seems to indicate a UK
appliance ... Really does not matter... The base principles remain the same just the "PARTS" search turns into a "SPARES" search.
Your unit is complaining about the heater element not functioning... which could be the heater or the logic which drives it... and EVERY CONNECTION in between.
Look on your schematic for your heater and logic board
part numbers... and search for those... HOPEFULLY you will also find "helpful videos" from the VENDORS...
The ones on youtube .. VARY WILDLY (from planet to planet).
Hope this helps.
https://www.bing.com/search?q=SDD910+dishwasher.+showing+error+A8+sometimes+a10&FORM=EDGNNC&PC=DCTE
http://parts.hotpoint.co.uk/shop
Hotpoint SDD910 Hoses
http://www.ukwhitegoods.co.uk/forumsphpbb3/hotpoint-fdf780-error-t79703.html
Nov 20, 2016 | Hotpoint Dishwashers
I have a dishwasher that shows error a8 or a 10
We recommend you call our customer service centre to book an engineer on: 0344 822 4224
Nov 20, 2016 | Hotpoint Washing Machines
Hotpoint SDW 60 dishwasher stopped working
The error code is for the 'heater circuit' before getting a new heater check the thermister (on the end of a black wire hanging off the main control board ) as the either dryjoints or comes loose
Dec 30, 2008 | Hotpoint 24 in. FDW60 Free-standing...
Hotpoint Dishwasher not working - FDW60
unplug it for an hour this normally fixes this problem on my machine
Jul 28, 2008 | Hotpoint 24 in. FDW60 Free-standing...
Hotpoint fdw80 dishwasher
Faulty heating element. Had the same error and got Hotpoint to replace the element. Error was also confirmed by their engineer.
Apr 13, 2008 | Hotpoint 24 in. DWF32P Free-standing...
Hotpoint Dishwasher BF1620
ive not worked on hotpoint dishwashers,does the dishwasher drain? at the point it plays up is it supposed to be filling or washing.check the filters inlet valve etc.do you still have the manual for the dishwasher.the flashing lights are most likley a fault code but we dont get hotpoint dishwashers in australia.sorry i cant be of more help.Ian
Mar 21, 2008 | Dishwashers
HOTPOINT DISHWASHER FDW60
I have just had my dishwasher fixed by Hotpoint, as the heater was working and the dishwasher only stopped with the fast and delicate lights just before the drying process he replaced the main control board. This has solved the problem, I suspected the fault to be the thermistor as the heater seemed to be getting to hot but I had no idea where it was.
It turns out the thermistor is attached to the main control board and hangs down behind the front door that gives just a rough temperature level for the main control board.
As it's soldered directly onto the control board I would suggest replacing the whole control pcb for anyone with this fault unless you can find any spec details for the thermistor.
Mar 18, 2008 | Hotpoint 24 in. FDW60 Free-standing...
Flashing Lights
this error code is time out draining, check for a blockage
Jun 05, 2007 | Hotpoint 24 in. DWF34 Built-in Dishwasher
Dishwashers Logo
Top Dishwashers Experts
Owen Barnes
