Question about Ovens
Eskom Reluctancy To Pay For Damages
Eskom caused a damage on my electric appliance to the value estimated to R 48 000-00 in Febraury 2013. All relevant quotations and information required was submitted. Further more, their investigation department conducted investigation on my connection if i did not forge electricity, tested appliances and took pictures of such damaged appliances. I was promised that the matter will be finalized within 42 days. To my surprise, its now six months and they only respond without truth as and when i enquire. Can I please be assisted. Mcera, WV ( contacts: 072 831 7051)
3 Suggested Answers
  • 236 Answers
SOURCE: Broken cooking appliance :( please help
if the fan is spinning then it sounds as though the element has gone. has your fuse box recently tripped? it may have been the blowing element.
Posted on Jun 11, 2007
  • 139 Answers
SOURCE: oven keeps tripping when switched on
The reason why you oven is tripping is because the oven element is most likely burnt out...
The electricity supply going out should not have affected this... it is easily replaced and is not to costly..
Posted on Jan 31, 2008
Frigidaire gas oven Oven control panel went blank. There is electricity to stove and oven.
sounds like the clock assy. is bad part 316557206 heat usually is the cause of this part to fail,people use the self clean the oven gets up to 1000 degrees and damages the clock assy. or a large pot was on top of the stove and the heat damaged it but whatever the cause was you need to change out the clock assy. if the touch pad is black you can reuse it if it's white for some reason it doesn't peel off without damaging the overlay get a putty knife and a hair dryer,heat up the overlay and peel it off with the putty knife,go here to see the parts
https://www.searspartsdirect.com/model-number/FGFLMC55ECA/1428/0124002.html
it looks like this only comes with the black overlay because it doesn't show any other colors so you can order the overlay or peel it off and save some bucks,go to the sight,put your model number in,go to backguard and look at parts 20 and 20a this is what you need,first i would check all the wires going to the clock assy. to make sure there isn't a broken wire.good luck
Dec 24, 2017 | Frigidaire FGB24L2A Gas Single Oven
If you switch oven on it trips main power. what can cause that
Probably close to 50 things could cause that, but here are a few of the most common: Bare wire in a harness of the oven, causing a short-circuit in the line. Faulty plug on the power cord. Outlet in the wall is damaged. Loose wire in the outlet box, causing a dead short. Bad wire between the outlet box and the main breaker box. Weak breaker, or a breaker that isn't heavy enough to handle the load of the oven. (especially, if you just bought a new oven, it may need a larger breaker to handle start up.) Use a fused multi-meter (voltmeter) to check for these issues, and do not try to fix it if you are not familiar with electrical work. It could cause a fire, or give you a deadly shock.
Feb 12, 2017 | Ovens
NEFF B4562 Oven LED display just stopped working during use yesterday. Oven still works but have to guess what programme I am using. any ideas on fixing it without the Neff 100pounds call out fee and...
Preparing the units - Fig. 1
? The safe operation of this appliance can only be guaranteed if
it has been installed to a professional standard in accordance
with these installation instructions. The installer is liable for
damage incurred as a result of incorrect installation.
? Fitted units must be heat-resistant up to 90 °C, and
neighbouring unit fronts up to 70 °C.
? Cut-out work on the units and worktop should be performed
before fitting the appliances. Remove any shavings or the
function of the electrical components may be impaired.
? Caution during installation. Parts that are accessible during
installation may have sharp edges. Wear protective gloves to
prevent cuts
? The power socket for the appliance must either be located in
the hatched area B or else away from the installation space.
? A gap of 5 mm is required between the appliance and
surrounding unit fronts.
? Secure freestanding units to the wall using a standard bracket
C.
Appliance under the worktop - Fig. 1
There must be a ventilation cut-out made in the intermediate
floor of the surround unit.
Secure the worktop to the fitted units.
If a fitted oven is to be built in under a hob, pay attention to the
hob installation instructions.
Appliance in a tall unit - Fig. 2
The appliance may also be installed in a tall unit.
There must be a gap between the intermediate floors and the
mounting wall of approx. 20 mm in order to provide ventilation
to the oven.
Only fit the appliance at a height where removing baking trays
does not present a problem.
Corner installation ­ Fig. 3
To ensure that the appliance door can be opened in the case of
corner installation, take account of dimension D. Dimension E is
dependent on the thickness of the unit front under the handle.
Connecting the appliance to the power supply
Only allow a licenced professional to connect the appliance.
National regulations apply as well as those of the local electricity
supplier.
The appliance must be disconnected from the power supply for
all installation work.
The appliance corresponds to protection class I and may only
be operated with a protective earth connection.
Power cord: Type H05 VV­F or higher rated. The yellow/green
wire for the PE connection must be 10 mm longer than the other
wires on the appliance side.
During installation, an all-pole isolating switch with a contact gap
of at least 3 mm must be present, or the appliance must be
connected via a three-pin earthed plug. This must be accessible
after installation.
Contact protection must be ensured by the installation.
Identify the phase and neutral conductors in the socket.
Incorrect connection may cause damage to the appliance.
Only connect as per the connection diagram. See the rating
plate for the voltage.
Position the appliance in front of the units in readiness for
connection. The connecting cable must be sufficiently long.
Securing the appliance ­ Fig. 4
? Fully insert the appliance and centre it.
? Screw the appliance into place.
? The gap between the worktop and the appliance must not be
closed by additional battens.
Removal
Disconnect the appliance from the power supply. Undo the
securing screws. Raise the appliance slightly and pull it out
completely
the only contact info that I found is the info below:
http://www.neff.co.uk/contact-us.html
Dec 08, 2014 | Neff Ovens
How can I get my oven temperature to come on? A power outage caused the "lock" light to flash and no temp is appearing.
Are you sure that you have 220 volts to the oven. It is possible for a breaker to go bad and conduct power only on one leg and some things on the appliance will still work.
Electronic controls on ovens can be damaged by power surges caused by lightening strikes. That could be the problem but after looking at the circuit diagram of the panel it doesn't look like there are electronics that should be damaged by a surge.
Here is a link to the user manual.
Download Manual Pdf
Link to Maytag Same as Whirlpool
Search Results for Appliance Models matching CWE4800A
Good Luck.
Sep 20, 2014 | Maytag CWE4800A Electric Single Oven
Smeg Wall Oven SCA504X Repair Manual
minimum repair is the clearance side wall of at least 110 mm. but never attempt to repair the appliances by your self. it has so many things which need skilled person but proper cleaning and lil bit maintenance for small damages is quite safe.
Dec 12, 2011 | Ovens
After a lightning storm my bosch single 30" wall oven displayed an F03 err. I turned the power supply off at the breaker for one minute as directed by the oven's manual. This action did not...
Find out what the F03 error is for and then check out the appropriate area. If there was a strike of surge the most likely place to look for damage is the area where the electricity first enters into the device.
Sep 07, 2017 | Bosch HBL 5036 Electric Single Oven
Bread (biscuits/rolls) burn on top and raw on bottom.
there are two elements in the oven one on top..one on bottom...the top one is also used for broil functions...the lower element may have burned out...to remove it there will be a screw holding a plate with the lower element attached to it...you may also need to turn the oven around and in the back there may be a cover where the electrical connections are...you may need to unscreww 2 screws to remove the element...if you have a multitester or can get one ..you'll want to check the resistance of the element..it will be a low value(not sure what value exactly). If it won't give a reading or shows nothing on the meter then you'll need to replace the element...you can get elements at appliance parts stores or on the internet..you can even try an appliance repair shop for parts.
Dec 22, 2010 | Whirlpool RBS245PDS Electric Single Oven
I have Maytag ECWE550 How do I operate the self cleaning (never did it) or can I get a manual online?
When you use self clean the 900 degree temperature damages the electronics. I do not advise using that feature. Get some oven cleaner and do it the old fashioned way. My opinion.
Oct 25, 2010 | Maytag CWE5800A Electric Double Oven
How to self clean the oven?
Get some easy off oven cleaner and go by directions. Using the self clean function damages expensive oven controls. My opinion. Electrolux stove service manual
Oct 13, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
Ovens Logo
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
