Question about Refrigerators
BEVERAGE AIR model # MM14GE is not cold temperature at 41* on the highest cold level 9. they replaced the compressor ,thermostat switch and added freeon but still not very cold. Why
Bob Gemmell
  • 209 Answers
SOURCE: Beverage Air UR30GE Won't Get Cold.
If the thermostat has been bypassed it sounds like lack of refrigerant gas in the system. The level cant be checked visually, it will need to be checked by an engineer with pressure gauges.
Posted on Sep 28, 2007
SOURCE: Marvel 6bar-bd gets too cold - explodes soda can
I also have the same problem. Our Marvel 6BAR runs continuously until the beverages freeze. A technician came out and replaced the thermistor under warranty. It was a simple repair that anyone could do. This solved the problem for about another 18 months, but it has returned. I will now search for this part and do the repair myself. It only takes a few minutes to do.
Posted on Dec 10, 2008
jumptrout51
  • 3361 Answers
SOURCE: My Beverage air model # mm14ge blows hot air.
Check the start relay and capacitor on the compressor.
Check the fan motor on the compressor.
Posted on Mar 19, 2009
  • 1144 Answers
SOURCE: beverage air model UR30G, not cold, fan still running
check the thermostat for proper setting, evap could be frozen up, the condenser fan could not be running, unit could be low on freon. start check some items and let me know.
Posted on Nov 28, 2010
  • 492 Answers
SOURCE: Refrigerator only 2 years old. Today the interio0r
is the freezer compartment cold or iced up
Posted on Jan 22, 2011
Adding freon to a commercial beverage air mm14ge cooler
If it needs gas it has a leak. These coolers generally don't come with gauge access ports and need to be silver brazed into place. These systems have a critical charge and will not operate right unless the exact ounces of refrigerant are in the system. The temperature controls measure coil temperature instead of cabinet temperature. The wrong charge makes them run and run and they cant control temperature. Hope this helped.
May 25, 2014 | Beverage-Air Refrigerators
I have a beverage air MM14GE cooler that hasnt been on for over a year when i plug it in it turns on but doesnt cool, what can be the problem?
Verify that the compressor is actually running. You should feel it vibrating. If the compressor runs with no cooling most likely the refrigerant level is low.
Oct 12, 2013 | Beverage-Air Refrigerators
Refrigerator runs and will not shut off, keeps getting colder and colder no matter what setting I put it on?
I have the same problem. My 7 yrs old Beverage Air model MT27 got very cold even with temperature control set to almost off position. It froze all the water and pops in it. Somebody have the solution?
Oct 12, 2011 | Beverage-Air MT27 Beverage Cooler...
My Beverage Air mm14ge wont cool. IT sounds like it's running, then after about 25 seconds it will click once, then once again a second or 2 later, and keep repeating that cycle. The fan is working. Is...
could be the start relay. could also be the compressor itself. need to either check continuity of compressor or use a compressor analyzer to see if shorted or open.
Apr 05, 2011 | Carrier Beverage-Air MM14 Commercial...
My Bev Air UR30G runs, but only warm air comes out...how can I fix?
make sure the compressor is running if not check the thermostat. or could have leak and lost coolant
Sep 27, 2010 | Carrier Beverage-Air UR30GEFD Beverage...
My Beverage air model # mm14ge blows hot air. why, and what must i do to fix this please.....thank You
Mar 19, 2009 | Refrigerators
Beer Not Cold!!!
There is a temperature control knob on the back side of the ref. it is on the bottom by the compressor
Have you adjusted this?
clayfoot
Aug 09, 2008 | Frigidaire PLKU1267DS Stainless Steel...
Beverage-Air DD50 Commercial Keg Fridge Not Cooling
The starting components on the compressor could be going bad. You need to turn off the thermostat and then after about five minutes turn it on while listening to the compressor to hear if it kicks in, if it doesn't then you might have faulty starting component, more likely the overload.
Jun 26, 2008 | Beverage-Air DW49 Stainless Steel Beverage...
Refrigerator Keeps running
Replacing the thermostat should correct the problem. Be sure to install the thermstat exactly as the one you are removing, assuming it hasn't been changed prior. Hope this helps
Jun 10, 2008 | Beverage-Air Beverage Air KR48-IAS 44.9...
Refrigerators Logo
37 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
