How to extend ring timeout on Cisco SPA504G - Computers & Internet
2 Suggested Answers
  • 26 Answers
SOURCE: Cisco SPA504G Firmware update issue
You need to make sure that your laptop and IP phone are on the same network subnet. For instance, if you IP phone's IP address is 192.168.2.24 than your laptop must be on the same network addressing scheme, such as 192.168.2.23.
<a href="http://www.ciscopowercube.com">Cisco CP-PWR-CUBE3</a>
Posted on Dec 13, 2012
Why wont the setting Call foward No Answer Activation connect to cell phone number set
While farwarding the call you need to press the call farwarding option.
Then try to put the number with the ISD code for example +919857012356 Country code must be there before the number.
Jun 25, 2014 | Cisco SPA504G IP Phone
Cisco 504g will not power up
Plug out the cable from this and put in again or reset the device.
May 08, 2014 | Cisco SPA504G IP Phone
Sep 07, 2012 | Cisco SPA504G IP Phone
We cannot get the 504g will not broadcast its caller ID. it only shows 'restricted'. why won't it display correctly.
change the configuration in your IP Phone change the setting to allow broadcast caller ID .
May 12, 2011 | Cisco SPA504G IP Phone
How do you make a background picture show up on a Cisco 504G phone. The online Config Utility asks for a Bitmap URL and I found one online that I liked, the only thing on the page is the picture, but it...
You need to make the bmp file the correct format
128 x 48 pixels 1-bit deep
Simply upload this to a webserver and point the backupground url at the address.
www.mpbtech.com
Oct 07, 2010 | Cisco SPA504G IP Phone
No dial tone on cisco 504G phone
to use an Ethernet phone you will need a VOIP supplier ( You will need to Google this for the country you are in ) . You will not be able to use it until you have these set up. Ethernet phones are not like a standard home phone which use your local exchange to route your calls they use servers on the internet to do that and route your call to landlines.
I hope this helps if so please give me a thumbs up
Jul 23, 2010 | Cisco SPA504G IP Phone
VOIP headset PlantroMX500i 72517-01 to use with Cisco IP spa504G
mx500i.gif MX500i 3-in-1 VoIP Headset Sorry your headset + phone combination is not currently listed in our database. Please contact Plantronics Technical Assistance Center to confirm compatbility
Versatile 3-in-1 Headset for Internet/VoIP, cordless and mobile calls
Part Number: 72517-01
Apr 21, 2010 | Radio Communications
Ploblems with dmz-outside (webpage). pix
Remove this line:
static (DMZ,INSIDE) 10.10.0.0 10.10.0.0 netmask 255.255.255.0
You don't need a translation going from a lower security level to a higher one. You will also need a nat line for the dmz so that pc's on the dmz will be translated outbound. The only connection that will work on the dmz is the webserver when he's sending traffic outbound with a source port of 80. Something like:
nat (DMZ) 101 10.10.0.0 255.255.255.0
Other than that, it looks like it should be working. You've got permission, a route, and a translation. Maybe "clear local-host 10.10.0.2" to get rid of any bad xlates and try again. Check debg level syslogs, run packet captures, "clear asp drop" then "show asp drop" after an attempt?
Feb 28, 2009 | Cisco PIX Firewall 506
Cisco asa5505 problem
You seem to have the last resort (o.o.o.o) set to VLAN1 which is set as an inside interface.
Is VLAN1 connected to the outside router or internet backbone?
If not, change the last resort to the outside Ethernet port.
Apr 16, 2008 | Cisco ASA 5500 Firewall
Computers & Internet Logo
53 people viewed this question
David Payne
David Payne
