Question about Electrical Supplies
Kipor kde 6500t
Current falling to 110 volts and back to normal at lov load ?
4 Suggested Answers
  • 342 Answers
SOURCE: Iam looking to download a manual for a Kipor KDE
looks very similar to the kde 6700 ta
Posted on Apr 04, 2010
  • 144 Answers
SOURCE: I have a Kipor KDE
Hi, I hope I can help a little bit. The hunting by the governor like can be caused either by governor adjustment or carb adjustment might be the culprit.But before you go into that, have you checked and cleaned the air filter or looked at the carburetor that might need cleaning if it has been awhile since that was addressed? If you figure that is alright try adjusting the carb first. I have never seen or heard about that brand of machine before, so I will give you a general adjust procedure. I will stress again to check everything you can think of first. The fuel tank has to be vented and on most machines this is done by the tank cap so make sure that is OK. Is the filter on the fuel outlet of your tank not obstructing the fuel flow and that the fuel lines are in good shape and not starting to deteriorate inside and slowing fuel flow?
To adjust the carb make small 1/8 of a turn at a time. Before starting the engine turn each one of the low and high clockwise or in until lightly seated so the needle seat is not damaged and remember that setting, even mark it down so you can always come back to that setting. The low or idle mixture screw should be about 1 turn out or counterclockwise more or less. The high mixture screw can be anywhere from 3/4 to 1 1/2 turns out or counterclockwise. Do not adjust the high mixture screw less than about 3/4 turn from the seated position. When you turn these screws in or clockwise it lets in less fuel to air and could make it run too hot.
Start with the high speed mixture screw and turn 1/8 of a turn out and listen what happens. If not better do that again up to one full turn in 1/8 increments. No good results try the low speed or idle mixture screw in 1/8 increments and see what happens. If no good try with the two at the same time.
There is one more screw and that one is on top of the carb and adjusts the idle or low speed of the engine with no load and is also very important to adjust the right idle RPM so that when a load is turned on it has enough RPM so the engine has enough so it does not start to miss and sputter because of turning too slow.
I have given you all this info without knowing if this is the right type carburetor or if this engine is gas or diesel, or is a barrel type carb.so I hope this helps you out even just a bit. All the best and good luck. By the way I will not even try to explain the governor setup as It is too lenghty and I don't want to make it run worse or not at all.
Maybe one of the other guys might have a simple procedure to get it done. Well good luck and all the best to you.
Posted on Feb 05, 2011
  • 93 Answers
SOURCE: Hi, I from Indonesia and I need help... I have
maybe your generator has a problem with the cylinder head gasket.try to remove the cylinder head gasket,grind the valves intake and exhaust it. use the gasket cement to glue the cylinder gasket then assemble it
Posted on Feb 24, 2011
I have diesel generator Kipor kde 19 STA3 . It keeps shoutinng dowen after it starts
First check the oil, A low oil sensor will shut it down if more than a quart low. Then drain your water separator and change fuel and air filters. Anything outside of that is going to be mechanical (lift pump, injection pump)
Jul 17, 2017 | Cars & Trucks
Hi, My KDE 6500T wont start, i replaced the battery and when i switch start, i can hear a tick but no ignition ,and the battery cable become tooo work
Check engine isn't locked down, rotate by hand, then check starter motor, and solenoid. The click you hear is probably the solenoid clicking in.
Feb 24, 2015 | Kipor Electrical Supplies
What could be the problem if KIPOR KDE 6500T Diesel generator turns off when I switch the breaker on?
is it air bound , clear it out , or you have a short but I would go with the latter ,
Dec 03, 2014 | Cars & Trucks
Power went out motor goes no volts why
If the fuses are good, your AVR (Automatic Voltage Regulator) may have failed or (less likely) you may have lost the residual magnetic field in your armature. With the generator off and your circuit breakers closed, plug in a corded 120V drill into one of the household 120V outlets on the generator. Spin the drill's chuck quickly, by hand, several times; This introduces a small electric current to your armature, "field flashing" the generator. Start the generator and check if the generator is now producing voltage. Sometimes this works, sometimes it doesn't. If no voltage, then it's likely your AVR has failed. You can purchase these online at ebay for about $35.00-$50.00. Buy a couple of them; these AVRs have a high rate of failure.
Apr 28, 2014 | Kipor Kde 5000ta Diesel Portable Generator
KIPOR KDE 6700TA 5KVA Generator
forget about the display read the manual and find out how many volts are needed to charge the battery....then
get a voltometer and disconnect the terminals from the battery and connect them to the voltometer while the generator is running...
find out what the reading is...if the reading is zero (0)...then post a problem on (no out put)...
if not.....then there has to be a mistake...
if it reads a voltage thats too low..then you AVR card is burnt out (AVR card is located in the other end of the generator (beyond the stator-side cover)...
Aug 04, 2009 | Kitchen Appliances - Others
Electrical Supplies Logo
48 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
