Problem aiwa tv an1410nh
NO CHANNEL
    Top Expert:
  • Televison & ... Master
  • 75,178 Answers
Check and replace its tuner.
Posted on Jul 17, 2013
Why my aiwa TV -A209 is locked on one channel?
Main system control IC fault. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Sep 05, 2014 | Televison & Video
Tv error codes
This problem has been answerd a few while ago.
May 17, 2013 | Aiwa Televison & Video
My aiwa tv a 219 remote locked how to open it.
Aiwa television comes with the option of blocking certain channels from viewing, allowing you to control which channels people using the television can view. However, if you forget the code that you entered to block the channels, you might find yourself unable to watch those channels. Fortunately, there are a couple of buttons on the television and the remote that you can press to reset the PIN and customer ID numbers, which unblocks the channels.
Turn the television on.
Press the "Volume Down" button on the front of the TV and press the "7" button on the remote at the same time.
Enter in a new PIN code and new customer ID.
Oct 30, 2012 | Aiwa Televison & Video
I have AIWA A219 TV. No remote functions are working, even manual switches are also not functioning, It got stuck on One channel, The error which is coming on screen is AGING 3CDDH
Hello
Its front panel microswitches are struk. These can be replaced. They are microswitches, which can be resoldered out from the front panel board. For this, you have to open your TV, take out the front panel after unscrewing it from the cabin, desolder one out of it and go with that microswitch as sample. You can bought it from electronic spare part shops at your town. Buy all of them and replace all at same time. This will solve your TVs problem. OK.
Jun 17, 2011 | Aiwa F2000 20" TV
Need to find code for Jumbo Universal Remote to use with Aiwa S2011 MTS television. Thanks for any help!
Hello
Aiwa TV is not lited on Jumbo Universal Remote codes. Anyway try out with these codes. Sometimes may help you.
Three digit codes for Aiwa TV with universal remote are:
195/ 196
Four digit codes for Aiwa TV with universal remote are:
0195 0196 0227 0269
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Code Search If after trying "Direct Code Entry" your device does not respond, or if your brand is not listed, try doing a search of the code library for your code by following these steps.
  1. Manually turn on the device (TV, VCR, etc.) to be controlled.
  2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
  4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
  5. Press and release MUTE to install the code. The indicator light goes off.
Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search.
NOTE: Switch OFF and switch ON your TV with its FRONT PANEL POWER ON-OFF SWITCH each time before trying an other code.
OK
Jan 27, 2011 | Aiwa TV-S2011 20"
My aiwa tv-- A219 is showing message AGING 19DCH in red color and nothing else except dispaly button is working.pls help me
my aiwa tv-- A219 is showing message AGING 2F01H in red color and nothing else except dispaly button is working.pls help me
Nov 11, 2010 | Aiwa F2000 20" TV
Dear Sir, I have AIWA A219 TV. No remote functions are working, even manual switches are also not functioning, It got stuck on One channel, The error which is coming on screen is AGING 1724H Plz...
Dear Sir, I have AIWA c142ske TV. No remote functions are working, even manual switches are also not functioning, It got stuck on One channel, The error which is coming on screen is
Oct 12, 2010 | Aiwa F2000 20" TV
I have an Aiwa cx-nma545 that I just hooked up to a Westinghouse SK-32h640g. The sound is very muffled. The sound is fine if I have it on cd or the radio but when on Aux Video I can barely here it.
On most TV's with speaker control there's a way to disable the TV's volume control effect on the level fed out to an external amplifier. Find it and disable it it or select FIXED for its level, or, while listening through the Aiwa, raise the TV's volume through its own remote and see if that affects what the Aiwa gets for volume.
Or, enable the TV's speakers but find the same interna lAudio setting and make it Fixed, but turn the TV volume down if you don't want to hear its speakers. That way, you could actually listen to the TV on its own speakers if you want, say, for casual watching of the Weather Channel or news, for example.
Nov 28, 2009 | Aiwa NSX-DS55 CD Shelf System
Aiwa TV MODEL No. TV-A149 AGING
I have Aiwa TV MODEL No. TV-A149
The problem that I am suddenly facing is that I can't change channels or volume or use any other function. I can't even turn it off with remote control.
Its stuck randomly on a particular channel that I was watching at that point of time.
Along with that channel it now shows a message in flashing red color that reads :-
AGING
6EDEH
Now when I press ''Display'' button on remote control volume goes off and this code is shown :-
S123 K234 Y
100 000 0
The numbers in the second line can be navigated by ''CH+'' button and changed between 0 and 1 by ''Vol+'' button.
I really don't know anything about this. So, please help me out of this problem.
Sep 14, 2009 | Aiwa TV-S2011 20"
Aiwa Colour Television Model TV-SX2150 KE - Audio Problem
i can solve ur prob by your self but u have to pay for that.
Apr 01, 2009 | Aiwa F2000 20" TV
Televison & Video Logo
14 people viewed this question
Top Televison & Video Experts
