Question edited for correct spelling of the maker.
Question moved to maker category.
Check the temperature of the fridge with a digital thermometer. I should be 5' centigrade. It may be set too cold and freezing condensation running on the rear wall. Also make sure the circulation fan is working. It looks like it is the round disc at the top rear.
Push a flexible net curtain wire down the drain until it appears above the compressor pan.
You can also try cleaning the drainage trough, dry it and spray it with dry silicone spray or even WD40 if you don't mind the smell. That will stop water sticking.
https://mediamarkt.pl/agd/lodowka-liebherr-cbnes-39560
