Question about Louisville Slugger MLB Prime Josh Hamilton Maple Wood Bat GH359JH Adult
Im confuse
If i put fiberglass on lower part of my bat would it be less likely to break ?
Mid 90,s custom harley build w. 32 amp sys new everything stator puts out 48 v. 2 new regs both ck ok. only bat v. at bat. simple 1 wire to bat. puts out 12.3 at 3000 rpm. sugestions?? anybody???
check for a missing wire to the battery as the voltage regulators are not controlling anything
if you have a 32 amp alternator and it is producing 48 amps , the voltage regulator is not controlling the out put of the stator so it will burn out from overload
voltage from the stator has to be 13.2 volts DC minimum and no more than 14.5 v DC at 2,000rpms
suggest that you get an accredited bike electrician to check out the circuits and system
Jun 28, 2017 | Harley Davidson Motorcycles
Do i need a certain antenna?
The fiberglass provides no ground plane area for the antenna and radio waves. Your Standing waves (aka: SWR or Reflect) are probably very high. I suggest mounting the antenna on the cab of the truck. You "could" try aluminum tape on the cap and mount the sheilded side of the coax to it somehow. Without a ground plane much of the RF Power of you CB will be reflected back to the Final Output Transistor(s) (Final or Finals), overheat it and possibly damage and burn it/them out. If you are just running the CB without an amplifier(Linear or sometimes called a box), a magnetic mount antenna should work fine and be less of a problem than permanently mounted antennas. That's a plus when going into a parking garage. Even if you decice to get an amplifier at a later date, you should be able to use it with the magnetic mount antenna as long as the antenna you but is rated for several hundred watts, you Standing Waves are Low, and the amplifier doesn't put out more power than the antenna is rated for. I hope this helps.
Apr 17, 2014 | Midland 1001Z 40-Channels Base CB Radio
Moter turns over but wont start. and windos stops working after moter start.
02 ford/?
wont start, then starts. im confused.
check all fuses. first.
Dec 18, 2013 | 2002 Ford Explorer - XLT - Speed Grille
What are jumping stilts springs made out of?
The springs are either made out of carbon fiber or fiberglass. the carbon fiber springs claim to be lighter, stronger, and more durable, but the fiberglass is generally less expensive
Dec 25, 2012 | Sport & Outdoor - Others
Problem with dlc not reading
- Check Voltage on pin 16 (BAT) and chassis (or body) ground. Always 12 Volts.
- Connect the Multimeter and check continuity between pin 4 (CG) and chassis ground. Less than 1 Ohms.
- Connect the Multimeter between pin 5 (SG) and chassis ground and check the continuity. Less than 1 Ohms.
- Check the fuse named OBD2 in the lower finish panel, under the dash on passenger side.
Thank you for visiting Fixya.
Dec 09, 2012 | 2005 Toyota ECHO
Cannot get obd2 scanner to read my 2005 toyota echo at the dlc
Problems with weed poppers
Garden weasel has metal handles and fiberglass. Fiskars have wooden handles and fiberglass handles. and i beleive garden weasel have more options such as handle lenghts, size. ect..
Jun 04, 2012 | Garden Weasel Weed Popper Original
My Hayward Sand Filter Tank has sprung a leak on the side of the tank not near where it looks like the tank might have been molded together. What can I use to patch the tank that will hold and not leak?
They are fiberglass ... fiberglass repair kit should do it ...
Im not so sure I would fix it ... if it is broken ... there are probably problems you cannot see ... might be cheaper to replace the tank when you consider what might happen if it breaks while you are not around.
Aug 29, 2010 | Hayward SAND FILTER, PRO SERIES
How to remove the fiberglass cap under the vinyl roof on my car?
The car has the entire vinyl roof attached not to the roof but a fiberglass sub roof. To remove well that's the upholstery people secret and why they charge 700. To remove and replace after the glass co. Comes in and replacing e's the rear glass. There is a patent on it and different mold for every car.
Feb 10, 2010 | 2001 Lincoln LS
Put a new alternator in 2000 Jeep Grand Cherokee engine light on
well , the ECU runs the alternator. (DG wire "dark green")
the alternator field is controlled 100% by PCM reg , inside PCM.
so..... if the running engine has 13.3, to 15vdc the alt is working
if lower, its not. (rpm on engine 800 or more)
not scanning the PCM a the CEL glow, you missed the boat.
why not scan it. see why the PCM is upset (DTC errors stored)
see the 2 lower pins below , those go to PCM.
in theory if the field in the old BAD ALT, was shorted.
that could in fact, burn up the PCM regulator.
shorting outputs of PCM , does that in most cases.
im the poor sod that fixes PCM's.so....
Apr 07, 2009 | 2000 Jeep Grand Cherokee
Louisville Slugger MLB Prime Josh Hamilton Maple Wood Bat GH359JH Adult Logo
443 people viewed this question
Top Louisville Slugger Baseball & Softball Experts
NOEL
NOEL
Thomas Perkins
Thomas Perkins
Are you a Louisville Slugger Baseball and Softball Expert? Answer questions, earn points and help others
