Question about Samsung HCL4715W 47" Rear Projection Television
HCL 4715W Factory Picture Settings Needed
In the Service Mode - does anyone have the "Picture" settings? I have the Geometric settings, but no Picture.
  • 5 more comments
  • Anonymous Sep 02, 2007
    Turn TV Off
    Hit Mute, 1-8-2, Power
    If you want me to send you the Service Manual, let me know.
  • Anonymous Sep 06, 2007
    post your e-mail address for me to send manual
  • Anonymous Nov 02, 2007
    I have the exact same problem with the my samsung HCL4715W and have made numerous attemps to adjust the convergence with the remote to no avail. Can some one help?
  • Anonymous Nov 14, 2007
    Need a owners manual, Was given the tv with out one. contact me.
    [email protected]- Phone: 330.995.2888
  • Nick Tucker Nov 17, 2007
    It would be very helpful if you could email me a service manual to [email protected]
    thanks
  • Anonymous Nov 27, 2007
    I am in need of a service manual for a samsung HCL4715w tv. Please email it to [email protected]
    Thank you
  • bee65735 Nov 27, 2008
    Please email me the service manual ([email protected]) for the hcl4715w. Any idea where I can get a remote for it?
Warped screen top & bottom...color convergence? hee haa . move some but so what it's warped...must be an easy solution. any help i'll take it 2002 model....thanks
Posted on Sep 02, 2007
SOURCE:
How can I reset only the picture settings?
There are two types of reset to TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Jan 10, 2016 | Televison & Video
How do I factory rest my Lg led smart tv?
To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Sep 10, 2014 | Televison & Video
When I change picture settings from my remote why does it revert back to old settings
Main system control memory IC fault. Contact any service technician to replace it. Before replacing this IC; do a reset to this set and check.
Sep 10, 2014 | LG Televison & Video
How to reset factory preset picture emerson le391em4
To do this, you have to enter its service mode option. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy.
Feb 24, 2014 | Philips 55PFL7705D 55" LCD TV
Reset factory settings
To reset the TV to its factory settings, you have to enter its service mode option. Reset option can be selected in this mode. If you wish to get more details about how to enter, adjust and exit the service mode, check this site. http://electronicshelponline.blogspot.com/ Pull up previous posts or type in the brand name and model number to of your set, to its search box, and press 'Enter'.
Aug 22, 2013 | Olevia LT32HVE 32 in. LCD Television
How can I restore factory settings on my tv?
To set it to its factory settings, you have to enter its service mode option. If you are somewhat sound in electronics, you can enter this mode, and set it into factory settings. By the way, what is the brand name of your TV? Model number? Provide more details please. If you wish to get more, check the site linked here. It has details about service mode entry and adjust methods to many brand TVs. http://electronicshelponline.blogspot.com/ Pull up previous posts there, either by type in the Brand name to your set in its search box, or view it in Mosaic / Timeslide / Flipcard option.
Jul 26, 2013 | Televison & Video
How do i unlock the key--- display on my Provision television that is operated by a beko 12.1 remote control.I also need the service code for some Geometric adjustment.
Service Menu Access Procedure To access the service menu, press and hold the handset sound mute button whilst pressing the TV's front panel 'Menu' button (under the front panel cover on the TV). The up/down channel buttons on the handset step through the options and the left/right buttons change the data values. Turn the TV off to get out of service mode and DO NOT touch any other handset buttons whilst in service mode. Service menu access is also similar for many other Toshiba large-screen TV's so this procedure may work on other Toshiba TV's - even those sold outside the UK.
Maybe this list can help you, click here for a list of each widescreen Toshiba TV Service Menu adjustment with details on the purpose of each.
The factory settings of each service menu option will be entirely different on every TV manufactured, due to component, tube and scan coil tolerances, so don't under any circumstances adjust your TV's settings to my factory default settings or your TV's picture will probably look awful! The factory settings are provided out of interest - the useful part of this document is actually the definition of each service menu option. You will see that some geometry settings are duplicated for each screen mode such as 'Cinema' and 'Subtitle'. This could, for example, help resolve a geometry problem that's present just in one screen mode.
I hope help you with this.
Oct 14, 2009 | Televison & Video
Best Settings for Picture Quality, Coloring, and Lighting
Factory setting. Do a reset to this TV, and then check. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts.
Jun 19, 2017 | Mitsubishi WD-52327 52" Rear Projection...
Samsung LE46F8 picture setting
It sounds like your TV is in Shop Mode.
Shop mode is a set of picture parameters that have been optimized for a store showroom or display floor. Shop mode does not allow you save any picture settings such as brightness or contrast.
To get the TV out of Shop Mode press and hold the Menu button on the front panel for three seconds, the picture will blank momentarily then reappear with “Dynamic Mode” shown on the screen. At this point the picture parameters can be changed and saved.
Feb 16, 2008 | Samsung LN-S4692D 46 in. LCD HDTV
DOWN HILL
Do NOT make any factory mechanical adjustments! Geometric alignment done electronically in the servicer mode needed.Senior tech skill level only.
Aug 20, 2007 | Philips 55PW9363 55" Rear Projection...
Samsung HCL4715W 47" Rear Projection Television Logo
172 people viewed this question
Jerry Greenberg
Jerry Greenberg
Ekse
