Samsung ps50q91hdx xsa
Came home today and turned on the tv it made a click noise like it was gonna turn on but no picture came up and the blue light flashed a couple of times, turned it off and it clicked as if it had been working perfectly all day, i tried unplugging it and turning back onbut still no love, is there a easy fix solution so i can watch the game tonight
ensapp
  • 30 Answers
SOURCE: lg 32lcd2d (tv won't turn on)
It is most likely the power supply. If you see domed caps change them using a higher voltage cap. If it's 1000uf at 15vdc put in a 1000uf at 25 or 35 vdc. If this helps let me know.
Posted on Oct 16, 2008
Fujitsu
  • 29 Answers
SOURCE: Hitachi Plasma TV model P50H401
I think you have problems with the digital main PWB.
If the power PWB failed, turn off and change the pilot ligth to red.
Posted on Nov 28, 2008
  • 63 Answers
SOURCE: 42 inch plasma wont turn on
I may have the fix.... Fixed two of my 50 inch plasmas that stopped turning on 1 year after I bought them. They both wouldn't turn on.... LOL Just gave me the black screen of death and a red blinking LED when I tried to turn on. I have pics and step by step instructions. Your time and under 40 bucks is what you'll need. I fixed both my sets for 80 cents. You can fix yours too.... I too got the it would be better to replace it than to have it fixed lie told to me too. I held out to the bitter end. Glad I did....
Posted on Feb 08, 2009
SOURCE: LG 42 LCD no sound or picture
Did anyone find out the solution for this??????? I have the exact same problem with my LG 32 LCD. I only had it for a year and a half, and the green light blinks a few times and it shows no picture. Not even a red light when the tv is off. The same thing happened a couple weeks ago and by some miracle it started working again.
Posted on Nov 22, 2009
  • 8457 Answers
SOURCE: lg 50 in clicks but won't stay on.
Ur power board need it replaced,LED indicator light not sustaning power.
Posted on Jan 05, 2010
I have a 50 inch Samsung Plasma Display TV PS50Q91HDX/XSA. I would like to know if a USB memory stick will work on this TV to watch movies. Thank you.
If you have a usb input and the set has the correct codecs built in, you will be able to watch a movie. May not work with all files. The usb input on a dvd blue ray will usually work with everything however.
Jun 26, 2016 | Samsung Televison & Video
TV lamp has been replaced, still won't come on, no picture. When turned on, I can see a blue, kind of sparking light and noise starts and does this about three times. TV powers down and does this again....
Samsung DLP TV Repair - No Picture - Replacing ...
? 2:41
https://www.youtube.com/watch?v=pBTgk_C5FVU
Jun 11, 2012 - Uploaded by ShopJimmy.com
DLP TV Repair No Picture Bad Lamp Bad Bulb TV Won't Turn On DIY Samsung DLP TV Repair How to replace Faulty LampTutorial Click Here to ... Rating is available when the video has been rented. ... is a replacement for the following DLP Rear Projection TV models: ... SAMSUNG HLR6167WX/XAA
Samsung DLP problems - Help! - ecoustics.com
www.ecoustics.com > ... > Home Video Forum > Projection TV Forum
Oct 26, 2009 - I have attached a picture of to show where the "Light Tunnel" is located. Upload ... So now I have a Samsung HLN5065W/XAA that I am willing to part out or sell as is. ... I replaced the ballast but the TV still won't turn on. .... The lamp has been sitting on a shelf until two weeks ago, when the TV went dark. Samsung DLP Light Ballast
Apr 10, 2009
Archive through October 26, 2009 - Samsung DLP problems ...
Apr 8, 2009
Samsung DLP Flashing Standby light
Jul 1, 2006
More results from www.ecoustics.com
Jan 19, 2016 | Samsung SELECT HLR6167WX/XAA Rear...
I turn on my Mitsubishi WD-73833 TV and it turns itself off
Lessing of brightness on a DLP set is a sign of imminent bulb failure.
A new bulb is in order.
Nov 23, 2013 | Mitsubishi WD-73833 73" HDTV
Hi I have a Samsung Tv. Model SP50L6HXX / XSA that wont turn on. there was a week buzzing noise for the last week or two, but tv will not start up now. The lamp light flashes on the front of tv. Can you...
I suspect the B+ voltage on the power supply can't regulate the voltage needed for the lamps to run entirely. The B+ voltage regulator looks like a small black box with a tapered top. This is dangerous to replace so be careful. Once you get a new one installed this will fix the issue you are having.
Hope this helps :)
Mar 07, 2011 | Samsung HLP5685W 56" Rear Projection...
LN-T4665F Samsung model will not turn on. It's making a continuous clicking noise as if it's attempting to turn on; however, it doesn't. The blue light at the bottom which usually indicates that TV is on...
You have capacitors in the power supply that need replaced. Not an expensive repair but you should not attempt this yourself. It can be repaired in the home.
Nov 26, 2010 | Samsung LN-T4665F 46 in. LCD Television
Replaced the lamp bulb on my samsung HLP5663. It went on right away. Though the problem was fixed. Turned the tv on a little while ago and the picture is gone. The timer light is blinking. Any ideas what's...
Now tv turn on.Hear alots of clicking or squiling,loud motor noises turn on?Alot of clicking,the Ballast board it dead,this board help ignite the projection lamp.Tv also have a colors wheels.The colors wheel is dead,if hear squiling noises,loud motor noises.
Jul 14, 2010 | Samsung DLP HL-P5663W 56" TV
TV Picture does not come on
Symptoms of a Defective or dying Power supplies on LCD TVs.
1. Light(s) on the front panel are behaving not normal example, blinking, amber color or
not steady, fainting, etc.
2. TV not turning ON properly.
3. TV turns OFF by itself.
4. Needs to be unplug to many times to make it work.
5. Humming or high pitch noise heard through speakers or at the back of the TV.
Dec 15, 2008 | Audiovox FPE3205 32 in. HD-Ready LCD...
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
