LCD image problems
Something wrong with my toshiba 40rv525u. I think the backlight and inverter are fine, and the power supply looks fine. Don't know what's wrong. My feeling is its either the tcon board or the motherboard. I feel like its something with the motherboard. Maybe a blown cap that looks fine. I'm not sure any ideas are much appreciated.
    Top Expert:
  • Televison & ... Master
  • 75,417 Answers
You've here with a video of its app settings. I can't see any fault with it. Back-light is OK. But something wrong with its center part. Might be with its back light CCFL lamps. Check it. How old is this TV?
Posted on Jul 17, 2013
  • Robert Schneider Jul 17, 2013
    2008. What's the ccfl lamp?
    Think this tv was a floor model so might have alot of hours on it
If it takes my LCD Westinghouse TV 20 min. to warm up then the picture is fine, do I need to replace the backlight inverter?
Did you fix the tv Patty? I have the same tv and when i turn it on, it screeches really bad, but after about 20 minutes or so, all is well. I don't think its a main board issue, but i already ordered and replaced the backlight inverter - that didn't solve the problem. I read somewhere that the power supply is what the problem is, but i just don't want to start buying all of these components as my trial and error. I bought a new tv to replace this one but it is no where near my Westinghouse. I love this tv more than my 55" LED Samsung in the family room!
Jan 10, 2012 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
My proview 3200 has picture but no sound
Hi gravdar4,
Power on the unit in the dark room then aim the flashlight directly to the screen, you will barely see the images. This is because your backlight is not functioning. The following reasons are the caused.
1. Power supply- missing B+(supply voltage) coming from this board feeding the inverter board. This was caused by faulty transistor, dried/leaky electrolytic capacitor, open fusible resistor.
2. Inverter board- even the B+ was present from the power supply, if the fuse, driver transistor, driver transformer was faulty, no output to the backlight resulting to black picture.
3. Busted backlight
Diagnosing the fault istechnicaland if you don't have necessarytools and test instrumentand can't fix it yourself, I would advice you to look for anexperienced technicianto isolate the problem.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Jun 12, 2011 | Proview PA-32JK1A 32 in. LCD Television
Samsung LNS 325 1D-the screen is blue-no picture but perfect sound-what is wrong? Thanks
Hi m5720,
Power on the unit in the dark room then shine with the flashlight directly in the screen, you will barely see the images. This is because your backlight is not functioning. The following reason is the caused.
1. Power supply - missing B+(supply voltage) coming from this board feeding the inverter board. This is caused by faulty transistor, dried/leaky electrolytic capacitor, open fusible resistor.
2. Inverter board - even the B+ is good from the power supply, if the fuse, driver transistor, driver transformer is faulty no output to the backlight resulting to black picture.
3. Busted backlight - even inverter board is good but if this is busted resulting to black picture also.
Diagnosing the fault is technical and if you don't have necessary tools and test instrument and can't fix it yourself, I would advice you to look for an experienced technician to isolate the problem.
Hope I helped you.
Jdvillanueva
Jun 04, 2011 | Samsung LN-S3251D 32 in. LCD HDTV
Tv has black screen, no picture
Good day!
Please before we go to the further troubleshooting please to play a DVD or recorded shows to determine if the problem is in your TV or cable connections.
If the problem persist please try to replaced this simple procedure on how to fix that problem.
  1. Remove the back cover of your TV.
  2. Check the 24vdc from the power supply going to inverter board using multimeter tester (range on DC)
  3. If you have 24vdc on the input voltage of inverter board,try to check the output voltage of that board,it should have 500vdc going to the cathode light inside of TV (back light)
  4. If you don't have the 24vdc on the inverter it means your power supply got trouble.
  5. You have better chances if you have failing capacitors on the power supply.Just look the image of capacitor if it is leak/bulged on the top.
If the problem is still there and you have other question just add a comment
I hope this solution will be helpful.Thank you for using FixYa.
May 31, 2011 | Akai LCT2715 27 in. LCD Television
The model of my laptop is TOSHIBA SATELLITE U400 MODEL NO. PSU40C-DW208C the problem is the backlight of the LCD is built in and no power on it, thats why i cannot totally see because its very dim color,...
Greetings,
It may not be the backlight, it may be the screen inverter which is a reasonable replacememnt. As a laptop specialist in my town, I always order both the screen inverter and the LCD unless both are sold combined.
Fixing a backlight is one of the most difficult laptop repairs possible to attempt. 1. You're not going to fix it. 2. In replacing it you'll have to do such delicate hand-soldering that even I don't attempt it any more and I'm VERY good with my hands.
So, friend, please order a new LCD and screen inverter and you'll be just fine after having someone spend about 1 hour replacing both.
Kind Regards,
Selk
May 20, 2011 | Toshiba Computers & Internet
Black screen, audio ok
Hope I helped you.
Have a nice day!
May 11, 2011 | Samsung LE-32M61B 32 in. HDTV-Ready LCD...
No picture but sound works
Hi ,
Hope I helped you.
Have a nice day!
May 09, 2011 | Protron PLTV-26 26 in. HD-Ready LCD...
Have sound but no picture screen is black
Hi memom440,
Hope I helped you.
Have a nice day!
Apr 26, 2011 | Sanyo DP32648 32 in. LCD TV
Toshiba P105, backlight dont turn on in my lap
If the LCD, inverter etc works in anothe laptop but not in the original laptop then it looks like a motherboard problem, possibly the power supply to the inverter.
Oct 11, 2009 | Toshiba Satellite P105-S921 Laptop PC...
I turn on my computer but the screen is still black
think you might have a failed screen inverter (FL inverter); this problem is very common with laptops. The inverter board acts as a power supply for the LCD screen backlight bulb, it converts low voltage DC power into high voltage AC. On most laptops the inverter board is located inside the display assembly below the LCD screen and you can get access to it if you remove the screen bezel (LCD mask). When the screen inverter goes bad the backlight will not turn on anymore or it turns on for a short time and then goes off, but you still can see a faint image on the screen and the external monitor works just fine. First of all I would make sure it’s not just a loose connection and reseat connectors on the inverter (it looks like you already done this part). Next, I would try replacing the inverter board. It might fix your problem with the backlight. It’s possible that you have a faulty cable, bad motherboard or even bad LCD screen, but I would try replacing the screen inverter first.
Oct 06, 2008 | Toshiba Satellite Pro 4600 Notebook
Televison & Video Logo
Top Televison & Video Experts
