Question about Dryers
Pro Standard Desk Fan Model FT5-30
Quit working is it warrantied?
My new guest ocillating cabin quit working (ocillating) after approx 7 hours of use. It worked intermitently for a few more hours in the fixed position. It then quit running altogeather. I need to get it...
If you have the receipt, take it back to the store with the receipt. They may give you an exchange. Otherwise, follow the directions in the fine print in the warranty statement in the back of the instruction manual or on a separate card included somewhere in the packaging material.
May 17, 2011 | Dryers
Have upright Frigidaire freezer, about 2 yrs old, that quit running. Local repair guy replaced part with "3 n/1 Start" solid state relay overload capacitor combination. Worked great for 2 weeks then...
Good day,
That's a no-no. Your compressor carries a 5 year warranty from the factory. However, if anything is altered on it the warranty is voided. You've got an issue with this guy.
Jun 04, 2010 | Frigidaire 20.6 cu. ft. / 583 liter...
My MFI2568AES ice maker quit working and is still under warranty. Water dispenser is working. I checkd the "off-On" switch and it is on. I checked the arm in the basket that tells when it is full and it...
If it is under warranty, call Maytag service and they will repair the icemaker free of charge. Then if you would please let us know what they did to repair it.
Dec 30, 2009 | Maytag Refrigerators
Microwave quit working
Check your plug , fuse...Failing that take it back under warranty
Sep 29, 2009 | Microwave Ovens
My new (less than 7 months old) JVM1540 microwave just quit. It was working multipLe times earlier today. The main breaker does not show as being 'tripped' and appears to be working. Help..??
Take the microwave back to where you got it, whatever is going on it should still be covered under warranty. it may just be a fuse but a warranty is a warranty. Make sure to take your manual with you just in case they give you any ****. Warranty is located on pg. 15?
Jul 17, 2009 | GE JVM1540DM Microwave Oven
Compaq presario v5000 won't start or post
It's the motherboard. Check to see if yours is still under warranty even if you've had it for over a year.
HP / Compaq has recently extended their warranty period for certain models.
Warranty Check
Let me know if you have any other questions.
Mar 04, 2009 | HP Compaq Presario V5000Z Notebook
Infinity PS-10 quit working
I think the electronics have a 3 years warranty and the drivers have a five years warranty for this product, maybe you can have it replaced. Maybe the auto on/off signal detector is the culprit.
Dec 09, 2007 | Infinity PS-10 Subwoofer
Mavica FD95 Flash Quit Working???
My flash went out twice on my FD-95. The first time it was fixed under warranty and it was the bulb. This time I haven't fixed since I have my 707 now. It still works with the external flash like yours did before you dropped it. If possible I would try and buy another external flash since your time is short. When I had my camera fixed under warranty it was just about to run out and they, the camera shop, told me I should get it fixed now instead of out of warranty because the cost could be hundreds just in labor alone. Good luck.
Sep 13, 2005 | Sony Mavica MVC-FD95 Digital Camera
Dryers Logo
112 people viewed this question
Top Dryers Experts
