Question about Asko 24 in. D3350 Dishwasher
My Asko D3330 dishwasher won't load water
The dishwasher is brand new, the water runs for a few minutes and then comes up with a F4 error related to the water inlet. I've had a plumber look at it, water is going into the dishwasher.
  • Anonymous Mar 29, 2014
    It turns on appears to be running but no water coming through. Let it run for few seconds but started smelling of burning.
  • 725 Answers
Sounds to me like you have abad water valve. but your warranty should take care of it.. please let us know if this is the problem.
Posted on Aug 29, 2007
  • 641 Answers
Since your dishwasher is under warranty you should contact to the appropriate factory service center for repair your problem !!!!!
Posted on Aug 28, 2007
ASKO XXL WASHER gives EO error on large loads only on normal wash load setting. Smaller loads and other loads no issues. All water lines and pump are clean.
What model number is the machine? That error is related to the amount of time it is taking to drain. There could be something blocking the pump on the intake side. It could also be the pump itself.
Nov 13, 2017 | Asko Washing Machines
W6441 Error message
google this with the model # and the brand along with the F4 error code
Jul 25, 2015 | Asko W6441 Front Load Washer
Getting an F4 fault code after about 1 -2 minutes of operation. There is actually water in the bottom of the unit. Have put a vacuum on the inlet feed tubing and also have blown compressed air through the...
Hello & Welcome to FixYa
F4 error in your Asko Dishwasher is a water fill fault and this indicates and over fill fault. To check and solve this problem please follow these steps:
1. Disconnect the power to the unit
2. Remove the lower access panels and check the tray under the dishwasher (you will probably find it is full of water)
3. Use a towel or a sponge to remove the water
4. There is a float that should stop the operation of the dishwasher and run the pump if water is in this tray. Check this pump to see if it is functional
5. Test the dishwasher
6. If there are no leaks from the dishwasher into the pan, check the drain hose under the sink
7. THE DRAIN HOSE MUST RUN UP TO THE TOP OF THE UNDERSIDE OF THE COUNTERTOP THEN DOWN TO THE DRAIN. (If the hose is not set up like this, water from the sink drain will flow into the dishwasher and overfill the tray
Please get back to me if you have any other questions.
Kevin
Jan 01, 2011 | Asko 24 in. D3350 Dishwasher
Have an Asko D3330 dishwasher that is totally "dead". No red lights, no sounds.
It may sound silly but, is it plugged in switched on and connected to water. (Lots of people have fallen to this oversight)
Oct 10, 2010 | Dishwashers
Hi,\r\n
yes you need to reset dishwasher to time fill.turn off the power button wait 10 sec,push and hold the programme and start buttons then turn power back on.hold buttons down until display lights up then release them.press programe button until 4 shows in display,then press start.test dishwasher. F4 is an inlet fault.
Jun 07, 2010 | Asko 24 in. D3350 Dishwasher
F4 error message. Cleaned out screen at water inlet and still get error message.
There may be excess water in the water reservoir. Empty the washer Turn it off at the mains, and unplug it, then put some old towels on the floor, tip the washer forward until the excess water comes out, Reconnect and try again. Hope this helps it works for me and saves ££££'s in repair fees
Oct 04, 2009 | Asko W6461W 24" Front Load Washer w/ Delay...
Water in drain pump for ASKO D5122XXL dishwasher
Yes, Asko dishwashers can leave a small amount of water in the sump after a cycle completes. At the beginning of most cycles the sump is pumped and new water added.
Mar 12, 2009 | Asko D3152XLSS Stainless Steel Built-in...
Asko D3330 F2
there is water in the pan below the unit. You will need to take apart the lower section of the dishwasher behind the toe kick and suck out the water, or just wait for it to evaporate (few days) Good Luck!
Oct 28, 2007 | Asko 24 in. D3350 Dishwasher
F4 Fault indication
F4 is a water inlet fault. It doesn't make sense if you have this fault indication with water flowing into the unit. Does the dishwasher drain properly? Usual suspects for an F4 indication would be a clogged inlet line, water supply turned off, bad fill valve, or a control board failure. Let me know if this helps, or give me a little more information on what you have done to correct so far.
Jul 09, 2007 | Asko 24 in. D3350 Dishwasher
Asko 24 in. D3350 Dishwasher Logo
588 people viewed this question
Top Asko Dishwashers Experts
John Tripp
John Tripp
Jose Pino
Marvin
Marvin
Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
