Question about Toshiba Office Equipment & Supplies
S30 freeze I encounter a problem with my Toshiba S30 when I try to record 2 videos (each approx 2hrs in length) in one day on the same SD card. My SD card is 16GB and based on the file sizes it should not be a problem to record 3-4 videos. However, when I record the second video, and stop the recording at the end, it freezes (the hour glass symbol appears and then the camera won't turn off or anything until I take the battery out). When I try to transfer the files from the camera to my PC, I can transfer and watch the first video, but not the second (the file transfers and is "there" based on the size, but it won't let me watch it). What is going on?! It is so frustrating!! What can I do to stop this from happening? I thought maybe it was something to do with the SD card, so if I changed SD cards for each video that might help??
  • 166 Answers
SOURCE: Sanyo HD1000 exacti
Hello there.
At a first guess, i would say you have the video quality settings on the camera too high. These new cameras and video recorders can store very high definition images and at the highest setting a laptop will have trouble playing the footage back without skipping or artifacting.
I would recommend checking the camera settings and lowering the resolution to something more manageable.
If you are unsure of this please write back.
Hope this helps.
Posted on May 03, 2008
SOURCE: Camera stops recording video
When recording movies in the SHQ image quality mode, I am restricted to 15 seconds of recording time per movie. Why?
In SHQ mode, the FE-230 records movies with VGA resolution (640 x 480 pixels) and a frame rate of 30 frames per second. Recording this much data, this quickly, requires a large amount of camera memory and a very quick write time.
Olympus’ Type M+ and Type H xD-Picture Card media are high-speed cards and are able to process this volume of information with no loss in quality. Other commercially available media, including Type M and Standard type xD-Picture Card media, are not able to do so. For this reason, this model limits movie recording in SHQ mode to 15 seconds when using media other than Type M+ or Type H cards. The 15-second restriction guarantees that the camera will be able to process the data properly and produce a smooth, error-free movie during playback.
Keep in mind that there is no restriction on movie recording length, other than the capacity of the storage media, when recording in the HQ (320 x 240 pixels) mode.
I'm not sure if you are recording in SHQ or not. Try switching to HQ (press menu, then select image quality). It solved the problem for me. Btw I got the solution of the Olympus FAQ page on their website.
Posted on Jul 09, 2009
  • 108 Answers
SOURCE: computer wont play a video i recored with my camera on my sd card
I understand, if you are able to record on the SD card, make your computer to recognize it and lastly if you can transfer it successfully with no errors, we can make it to work by choosing an appropriate media player. I personally would recommend VLC player. Latest version of this software can be found in:
Still if you are not able to open/run the media file. Let me know the type of file. I ll then according do a research and suggest a specific codec or a player that will support the file type.
File type can be found be right-clicking on the file and selecting Properties.
Posted on Jan 15, 2010
  • 11967 Answers
SOURCE: i hv Canon A470 digital camera...i tuk a video
Use a card reader to transfer it to a folder you create on your desktop.
Posted on Feb 18, 2010
  • 1140 Answers
SOURCE: Hi, I own a Nokia 5230.
check if the phone memory is still at large and so on the memory card to,might so many files from your phone or card that's why the operation took some errors or buffer...
otherwise if this problem took on and so on,better reset your phone or restore it to it's factory default to refresh the memory of the phone and can do the operation smoothly...
if this solution helps....please rate me...thanks
Posted on Jun 03, 2011
Camileo s30 not charging
I had this same problem! Scoured the web and found no solution. This is what I did to fix it...
Remove battery. Unplug charger. Press and hold the power button for 20 - 30 seconds. While still holding the power button, re-insert the battery and/or plug in the charger. Voila! Came back to life and worked like nothing ever happened.
I also did the same thing with the record button, but it was the power button that got the result.
Hope this helps!
Mar 15, 2012 | Toshiba Camileo S30 HD Camcorder -...
Try This:
  1. Connect our S30 to your PC and format
  2. Unplug, let it restart, then plug back in
  3. Reinstall software from NavDesk software
  4. Recover the keys
  5. Reinstall the maps
Feb 19, 2011 | Navman S30 Car GPS Receiver
Toshiba TLP-S30 loses calibration/alignment with whiteboard.
there are phisical adjustments for the projector itself. is it on a smartboard? hold down the 2 buttons on the pen tray until the 9 point callibration screen appears. the points react to stylus release, so put the stylus near the point and "draw" a line to the center of the point then release. do the same for the other 8. that should do it.
Dec 11, 2009 | Toshiba TLP S30 Multimedia Projector
Transferring pictures from phone to computer
do you have a micro-sd in your samsung? if you do have then use a card reader and plug it in your pc. Bluetooth receiver for pc will do the same thing, but i prefer card reader.
Sep 29, 2009 | Computers & Internet
Vista Drivers for Sony DSC-S30 Camera
No updates for Vista available for DSC-S30
You can see details on Sony Support, please check bottom of page.
As suggestion, You can use "memory card reader" to transfer pictures in PC.
Feb 23, 2009 | Sony Cyber-Shot DSC-S30 Digital Camera
Kodak 4 GB SD card (brand new) shows "card error" in Pentax optio
The problem is your camera doesn't work with the 4gb card, its too big. Sorry!
Your stuck with 2gb cards. Id suggest to echange the card to two 2gb cards.
Let me know if you need anything else.
Feb 17, 2009 | Pentax Optio 30 Digital Camera
Service manual needed for canon PoweShot S30
This isn't exactly a service manual, but something I had prepared for a friend who had a similar problem as you. Would recommend instead of fitting a new switch to replace the entier assembly. You can get broken S30's from ebay relatively cheap. Anyways, here's the file:
Jan 09, 2009 | Canon PowerShot S30 Digital Camera
Frozen screen on Gigabeat S30
I left the Gigabeat on until the battery ran out. It then turned itself off automatically and allowed me to re-charge the battery. When I turned the Gigabeat on, it again worked perfectly,
Jun 23, 2008 | Toshiba Gigabeat S30 MP3 Player
Toshiba gigabeat MES30VW
i'm thinking the hard drive is messing up... you know when i dropped my gigabeat S30 it wasn't working n it was freezing and the video files weren't playing at all. it would freeze when i turn on or play video. then i turned it off and then back on using the battery switch. it said "contact the manufacturer for repair" with a yield sign. i really thought i killed it...but i still had my hopes high to fix it myself somehow n i really thought it was from the hard drive. so i took it in my hand and gave it a shake on my palm. like i actually hit it on my palm for once n then i turned it on and it worked =D fineee.... i was so happy n now it still works fine ;)
i hope that helps
May 26, 2008 | Toshiba Gigabeat S30 MP3 Player
Toshiba TLP s30 projector identification part
Mar 28, 2008 | Toshiba TLP S30 Multimedia Projector
Top Toshiba Office Equipment & Supplies Experts
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
