Question about Axiom IO Wireless Cyclocomputer White
Reset I am having trouble reseting the trip distance to zero.
Fuel tank reserve capacity
Hi Kumud:
On my KLR 650 the reserve is 0.9 US gallons.
There's really not much point in worrying about "non usable" amount.
What I would recommend, especially if you're going to do any remote riding, is to strap a spare gallon (or 2) to your bike, then go for a ride. When you run out of gas, reset the trip meter to zero, turn on your reserve, and ride until you run out of gas again.
You will now know how far you can go on your reserve. That's the first important part.
Now put you spare gas into the tank and ride off to find a fuel station. Fill the tank, set the trip meter to zero, make sure the fuel selector is set to "ON", and go for a ride until you run out of gas again.
You will now know how far you can go on a full tank before you have to rely on the reserve.
If you use this system it won't matter what machine you have, and depending on your riding technique, the distances will vary.
Gotta love riding!
cheers.
Nov 03, 2015 | Tank Motorcycles
How to reset trip meter to zero for every journey on jaguar s type and also where the button to reset is please?
The two buttons that control the trip options are on the dash adjacent to the hazard warning button. Press the TRIP button untill it shows a small A or B in the top left (say average mpg) then press the upper part of the toggle switch marked RESET/CLEAR and hold it for about four seconds, this will display A or " B resetting" depending on which trip you are currently in, then everything on that trip is reset to zero (mileage/mpg/ave.speed etc). I use A for the full tank recording and B for individual journeys that I wish to record.
Jul 21, 2011 | 2000 Jaguar S-Type
I just had a new battery installed yesterday and this morning there is a message appearing on my dash board >>> TRIP B 199999????????
There should be a peg or reset button next to the odometer. Pessimism and hold for 5 second or so. It should re.set to zero. Your car has two resettable odometers Trip A and Trip B. They can be used to measure the distance of a trip. I normally reset A each time I fill the gas tank and B each time I get an oil change. Nothing to worry about. You can cycle through the three odometers by pressing the reset peg for 1 second or less. The third odometer view is the total miles on the car and cannot be reset.
May 27, 2011 | 2006 Ford Focus
THE SIDE TURN KNOB FOR MEASURING DISTANCE ON THE SPEEDO, HOW DO I CHANGE IT. THANKS
Hi, I am assuming you mean the knob for resetting the trip meter on the speedometer? In this case just turn the knob slowly untill you have all four zeros in line, job done.
Aug 13, 2010 | 1987 BMW K 100
How to turn off the maintance required light
Turn the key to the on position,but do not start it. Make sure the odometer is set to the actual mileage and not the trip mileage.
Now turn the key back to the off position then press and hold the trip mileage reset button. While still holding the trip reset button down, turn the key to the on position. Continue holding the trip mileage reset button while the mileage flashes rows of zeros until the actual mileage appears again. Release the button and that should reset your maintenance light.
Hope this helps but if not please let me know.
If it does please give a rating thanks and good luck.
Jun 18, 2010 | 2006 Toyota Camry
I have a blackburn delphi 2.0 bike odometer how
Press and hold the middle button when you are on the total distance screen.
May 11, 2010 | Blackburn 4.0 Bike Computer
2007 Lexus ES350. Mater Warning Light is activated for oil maintenence. How do I shut it off?
if you do not have navigation system.
  1. Turn the engine switch OFF..
  2. While pressing the trip meter reset button, set the engine switch to IG-ON mode. Continue to press and hold the knob until the trip meter displays 000000.
if you have navigation.
  1. Push the "INFO" button
  2. Touch "Maintenance".
  3. Touch the desired button Delete All : To cancel all conditions which have been input. Reset All : To reset the item which has satisfied a condition. If "ON" is selected, the system gives maintenance information with the "Information" screen when the system is turned on. If "OFF" is selected, the "Information" screen is disabled.
  4. Input the conditions. Notice of Date : The next maintenance date can be input. Notice of Distance : The driving distance until the next maintenance check can be input. "Delete" : To cancel the date and distance conditions. "Reset" : To reset the date and distance conditions.
  5. Touch "OK" The screen returns to the "Maintenance screen.
Mar 05, 2010 | 2007 Lexus ES 350
Lexus IS250 2009 - Oil light
While pressing and holding the odometer reset button press the IGN button twice without your foot on the brake. The display will show some dashes and finally 00000.
The service reminder should be reset.
Hope it will help
Dan
Jan 05, 2010 | 2009 Lexus IS 250
Bell f20 resetting trip odomoter DST
Did an obsessive search of this problem and found this: "Right Button" . . . click to display the "DST" (distance) than hold the "LEFT Button" for 2 seconds. YEAH!! Reset trip ONLY!! This problem is simply an error in the instruction manual. ~G~
Jun 01, 2009 | Bell Sport & Outdoor - Others
Trip meter reset in Ford Focus Zetec 2003
You have a blown fuse in the interior fuse block I can't remember the number. Use a test light to check them
Aug 16, 2008 | 2000 Ford Focus
Axiom IO Wireless Cyclocomputer White Logo
73 people viewed this question
Top Axiom Cycling Experts
John Egan
John Egan
Are you an Axiom Cycling Expert? Answer questions, earn points and help others
