Question about HP PSC 1350 All-In-One Thermal Printer
Hp 1350 psc alignment page
I put in a new black cartridge. Now every time I turn the computer on, the printer turns out another alignment page. If I take the paper out it shows E and prints another alignmentpage. I have taken the cartridge out and reinserted it but that does not help.
    Sergeant:
  • 390 Answers
OOh dear your printer has a little confusion gnome!!!, i am assuming it is attatched to pc, you have to start by resetting it. Take out the cartridge. Close printer and turn it off. Unplug it, remove all cables. Now, take 3 deep breaths, replug all cables, turn it on and wait for pc to recognise it. It will reset it for you. Now, try printing normally again. Re-post if this does not fix it.
Posted on Aug 28, 2007
SOURCE:
Hp 1350 does not copy
Hi Steve,
Does the printer give you any error message ? the best you can try on HP PSC 1350 is, Remove the cartridges and clean the electrical contacts ( golden points ) on the cartridge and put the cartridge back in. IT should go thru alignment process. IF it does not go, It should display some error. I hope the cartridges have ink in them.
Regards,
Suhail
May 14, 2012 | HP PSC 1350 All-In-One Thermal Printer
My printer hp psc 1350 keep on blinking check print catridge even after change new catridge both colour and black..how to settle?
Tried removing the cartridges again, then turn off you printer for 2 mins.
clean the print nozzles of the cartridges, turn the printer on
insert the cartridges again, then check if the problem persist.
You can also try to put the original cartridges that came with the printer
to isolate the problem, if it's really the ink cartridges.
Feb 25, 2010 | HP PSC 1315 All-In-One InkJet Printer
HP PSC 1315 Prints test page every time printer is installed
Hi Jay,
This is mike, actually the problem is that that printer has not completed the aligning process, as a result the printer is printing the test page (Alignment page) every time when you turn it ON. So, I would suggest you to let the printer prints the alignment page and check whether the printer prints the page with all colors and it printed fine, once it is done, disconnect the USB cable behind the printer and then place the alignment page on the scanner glass by facing down the printed page downwards and press the scan button. This start the alignment process and the scanning process will be completed once the ON light is stop blinking. This will complete the alignment process.
Once done try to turn off and turn on the printer and check for the result. This should resolve the issue.
However, if the issue persist, then please revert back to me. Be sure that you use the HP genuine ink cartridges, not refilled nor re-manufacture.
Jun 20, 2009 | HP PSC 1315 All-In-One InkJet Printer
Printer prints a test page every time it is turned on.
Hi everyone
After replacing the print cartridges 2 steps need to be done:
1. Wait for the test page to be printed out and
2. Put a page over the scanner glass and press scan button on your
printer.
Turn off the printer and turn it on again to see if the problem was
solved.
Ali Khan
Dec 19, 2008 | HP PSC 1350 All-In-One Thermal Printer
It automatically print a page everytime I start my hp psc 1315
Hi Siddarth
In HP PSC 1315 printer after replacing new Ink Cartridges the printer always prints Alignment test page every time you turn it ON.To resolve this problem you must complete the alignment process.
Steps
1.Turn the printer ON.
2.Once its ON, it will print the Alignment page. Place the page in the scanner bed correctly.
3.Then Press START SCAN button.
4.The power light will start blinking, wait until the power lights turns solid.
5.Now Alignment process is over.Discard the paper from scanner.
6.Turn the printer OFF and then ON, it will not print that page again.
Note:Please follow this steps every time when you replace the Cartridges.
Thanks
Rizwan
[email protected]
Dec 08, 2008 | HP PSC 1315 All-In-One InkJet Printer
Alignment sheet prints---cannot print anything else
u will have to first scan the alignment paper in your scanner this will solve your problem
Nov 14, 2008 | HP PSC 1315 All-In-One InkJet Printer
Alignment page every time
- after it printed an alignment page
- face the alignment page on the scanner and press ok..
- then try to print from the computer.
- try to turn the printer off and on again if still it will print an alignment page.
Sep 05, 2008 | HP PSC 1350 All-In-One Thermal Printer
HP PSC 1300 All in one Printer
  1. Turn on the HP PSC and lower the print-carriage access door.
    The print carriage will move into the access area. Figure 1: Opening the print-carriage access door
  2. After the carriage stops moving, push down on the top of the print cartridge to release it, and then pull it toward you out of the slot.
      NOTE: The black cartridge is on the right side of the print carriage.
    Figure 2: Removing the print cartridge
      NOTE: It is normal to see ink buildup in the print cartridge slots.
  3. Remove the new print cartridge from the packaging and gently remove the plastic tape by using the pink pull tab.
      CAUTION: Do not touch the copper contacts or ink nozzles. Install the cartridge immediately upon removing the tape to prevent ink from drying in the nozzles.
    Figure 3: Removing the plastic tape
  4. Push the new print cartridge into the appropriate slot at a slight angle, until it clicks into place.
      CAUTION: Do not attempt to push the cartridge straight into the slot. It must slide in at a slight angle.
    Figure 4: Inserting the print cartridge
  5. Close the print-carriage access door.
Using a photo print cartridgegtabtop.gif To use the photo print cartridge, remove the black print cartridge and insert the photo print cartridge in its place.
The photo print cartridge can be purchased separately and will optimize the quality of printed photos.
With the tri-color print cartridge and photo print cartridge installed, you have a six-ink system, which provides enhanced quality photos. For printing regular text documents, use the black print cartridge.
Use a print cartridge protector to keep either print cartridge secure when it is not being used. Figure 5: Storing the print cartridge
c00034854.jpg 1 - Inserting the print cartridge
2 - Removing the print cartridge
Aligning the print cartridgesgtabtop.gif After installing or replacing a print cartridge, the HP PSC will automatically print a cartridge alignment page.
  1. Place the alignment page face down on the left front corner of the glass with the top of the page facing the left side.
  2. Press Scan .
    The HP PSC will align the print cartridges. During the alignment the button LED will blink until the alignment is complete.
Aug 04, 2008 | HP PSC 1350 All-In-One Thermal Printer
Ink Cartridge Alignment
On alignment sheet, do you see a line of yellow blocks?
And on next line do you see alternate block and yellow blocks?
(Without these, alignment fails)
If not, change the colour cartridge, re-print the page and repeat alignment.
Good luck...
May 26, 2008 | HP PSC 2110 All-In-One InkJet Printer
HP PSC 1350 All-In-One Thermal Printer Logo
207 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
