Hair 5000 BTU Airconditioner room
My ON/OFF BUTTOM WONT WORK AND ITS ONLY BEEN A YEAR SINCE I BOIGHT IT SO I WANT TO KNOW IF IT HAS LIKE FUSES OR SOMETHING
Hi have you checked the fuse on the plug itself because if the on/off switch does not work then it would either be the fuse and if you see any dust inside the best thing to do would be to brush the dust out with a paint brush or hoover it lightly and that might make the on and off switch work. hope this helped you
Posted on Jul 31, 2013
3 Suggested Answers
heatman101
  • 43501 Answers
SOURCE: I am thinking of buying
This means that they only want one outlet on that circuit, the one for the A/C....but if you are only running the A/C on a circuit and nothing on the other outlets you will be okay...they just do not want you to overload the circuit and cause a fire...
heatman101
Posted on Sep 07, 2010
  • 251 Answers
SOURCE: air conditioner cools good but
System Inspection
Although the A/C system should not be serviced by the do-it-yourselfer, preventive maintenance can be practiced and A/C system inspections can be performed to help maintain the efficiency of the vehicle's A/C system. For A/C system inspection, perform the following: The easiest and often most important check for the air conditioning system consists of a visual inspection of the system components. Visually inspect the air conditioning system for refrigerant leaks, damaged compressor clutch, abnormal compressor drive belt tension and/or condition, plugged evaporator drain tube, blocked condenser fins, disconnected or broken wires, blown fuses, corroded connections and poor insulation.
CHECKING FOR OIL LEAKS Refrigerant leaks show up as oily areas on the various components because the compressor oil is transported around the entire system along with the refrigerant. Look for oily spots on all the hoses and lines, and especially on the hose and tubing connections. If there are oily deposits, the system may have a leak, and you should have it checked by a certified air conditioning specialist.
Fig. 1: Run your hand along the underside of all hose connections and check for leaks. If you find a leak, have it fixed by a certified air conditioning specialist.
check%20ac%20leak.jpg KEEPING THE CONDENSER CLEAR Periodically inspect the front of the condenser for bent fins or foreign material (dirt, bugs, leaves, etc.). If any cooling fins are bent, straighten them carefully. You can remove any debris with a stiff bristle brush.
Fig. 1: The position of the condenser in front of the radiator makes it particularly susceptible to collecting debris. Periodically, remove the accumulated bugs, leaves and other trash from the condenser. ac%202.gif
CHECKING THE REFRIGERANT LEVEL There are two ways to check refrigerant level. On vehicles equipped with sight glasses, checking the refrigerant level is a simple matter. Many late model vehicles, however, do not have a sight glass, and you have to check the temperature of the lines to determine the refrigerant level.
With Sight Glass The sight glass is normally located in the head of the receiver/drier. The receiver/drier is not hard to locate. It's a large metal cylinder that looks something like a fire extinguisher. Sometimes the sight glass is located in one of the metal lines leading from the top of the receiver/drier. Once you've found it, wipe it clean and proceed as follows:
  1. With the engine and the air conditioning system running, look for the flow of refrigerant through the sight glass. If the air conditioner is working properly, you'll be able to see a continuous flow of clear refrigerant through the sight glass, with perhaps an occasional bubble at very high temperatures.
  2. Cycle the air conditioner on and off to make sure what you are seeing is clear refrigerant. Since the refrigerant is clear, it is possible to mistake a completely discharged system for one that is fully charged. Turn the system off and watch the sight glass. If there is refrigerant in the system, you'll see bubbles during the off cycle. If you observe no bubbles when the system is running, and the airflow from the unit in the vehicle is delivering cold air, everything is OK.
  3. If you observe bubbles in the sight glass while the system is operating, the system is low on refrigerant. Have it checked by a professional.
  4. Oil streaks in the sight glass are an indication of trouble. Most of the time, if you see oil in the sight glass, it will appear as a series of streaks, although occasionally it may be a solid stream of oil. In either case, it means that part of the charge has been lost.
  1. Fig. 1: Oils streaks (A), constant bubbles (B) or foam (C) indicate there is not enough refrigerant in the system. Occasional bubbles during the initial operation are normal. A clear sight glass indicates a proper charge of refrigerant or no refrigerant at all, which can be determined by the presence of cold air at the outlets in the vehicle. If the glass is clouded with a milky white substance, have the receiver/dryer checked by a certified air conditioning specialist. ac%203.jpg
Without Sight Glass On vehicles that are not equipped with sight glasses, it is necessary to feel the temperature difference in the inlet and outlet lines at the receiver/drier to gauge the refrigerant level. Use the following procedure:
  1. Locate the receiver/drier. It will generally be up front near the condenser. It is shaped like a small fire extinguisher and will always have two lines connected to it. One line goes to the expansion valve and the other goes to the condenser.
  2. With the engine and the air conditioner running, hold a line in each hand and gauge their relative temperatures. If they are the same approximate temperatures, the system is correctly charged.
  3. If the line from the expansion valve to the receiver/drier is a lot colder than the line from the receiver/drier to the condenser, then the system is overcharged. It should be noted that this is an extremely rare condition.
  4. If the line that leads from the receiver/drier to the condenser is a lot colder than the other line, the system is undercharged.
  5. If the system is undercharged or overcharged, have it checked by a professional air conditioning mechanic.
Fig. 3: Checking the refrigerant charge if the system has no sight glass. ac%204.jpg
Posted on Jun 07, 2011
Tip
Tips on chosing air conditioners and why thy are not cooling
some one was asking why their airconditioner is not getting cold. here are soome tips.
1. low on coolant
2. tubular temperature unit is not functioning.
3. temperature of room is beyond the capacity of the unit. overworking
the unit beyond its capacity
4. a unit should be working to cool the room. It is not good for the size of the unit in btu's to be to large or too small. It is better to over work than under work an air conditioner.
on Jun 20, 2010 | Air Tools & Compressors
I have had a MWK-05CMN1- b17 5000 btu window mounted air conditioner unit that i bought last year. It was only used a couple times. It never cooled down the room. And when i finally used it and relized it...
From what you are saying, it sounds like the air conditioner is a lemon.
Unfortunatly, these small room size air conditioners are not worth the cost of reapir.
May 12, 2014 | Heating & Cooling
AC was cooling fine. Now, won't cool room even though cool air comes out. Exhaust hose is extremely hot.
Check filter, if you have a 5000BTU unit (small) and it is extremely hot, then it wont work great for a big room. BTU is the rate of what the AC will put out. 5000 BTU is good for a small single room. 10,000 will cool a bigger room and 18,000 btu is meant to cool a home.
Jul 07, 2010 | Whirlpool ACP102PS Portable Air...
What is the power draw (in watts or amps) of the Kenmore 5300BTU room air conditioner? The unit is being powered off the grid by an inverter, and I think the user chose too light weight an inverter for the...
5.8 amps. see page 9 (5300 btu is considered a 6000 BTU, 4800 is considered 5000 btu, sorta like a 2x4 ain't really a 2x4 LOL)
You cannot run an ac on an inverter, not enough juice to get it started.
May 28, 2010 | Kenmore Single Room Air Conditioner
5000 unit working great, moved and it wont come on, yep got power at plug in. just dead and tripping breaker.?
Probably the breaker is not big enaugh for that a/c unit ,read the tag it sohuld said what's the maximun circuit breaker for that unit ,usually with a 20 amp breaker works.
Aug 25, 2009 | Haier America Manual-Control Room Air...
Heating & Cooling Logo
96 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
