Question about Coleman 7990-319p Evcon Gas Furnace Control Board
Coleman Evcon furnace. Can i make it circulate air?
Its so hot here, and i was wondering if i could somehow get it to where just the blower would kick in to circulate the air. I tried putting it on the cold air setting on the thermostat, but it wont kick in. It doesn't have AC installed, just trying to figure out a way to just run the blower. Any sugestions?
    Top Expert:
  • Coleman Master
  • 34,781 Answers
Your thermostat should have a "continuous blower" setting. Use that instead of fooling around with the A/C setting
Posted on Jul 26, 2013
Coleman Evcon model DLAS075ADC, glow plug lights, fire starts, then the blower comes on,..after ten minutes the whole system shuts down and will not re light, what is causing this?
Check to see if the pressure switch is sticking...it wont restart the furnace if it is already pulled in before the inducer motor is called to kick on.
Dec 17, 2013 | Heating & Cooling
Coleman evcon furnace
How old is your furnace? Does it have a circuit board that controls everything, or are there separate controls for each function?
Nov 19, 2013 | Heating & Cooling
I have a Coleman Evcon Elec Furnace with the added AC Unit. The blower works great with the AC but only on & off with the heat, what could this be?
Replace the sequencer...which is just a series of snap disc relays that are staged. The first snap disc should kick on the first element & low speed of blower. Depending on how many elements you have, determines how many snap discs are on the sequencer. It could be a 2,3,4, or 5 stack. Generally the coil is 24 volts.
Dec 01, 2012 | Coleman Evcon Furnace Control Circuit...
When the furnace shuts down, blower kicks on and off
Probably residual heat kicking the fan limit control on and off. Readjust the settings on the fan limit control.
Nov 15, 2012 | Coleman Evcon Furnace Control Circuit...
I have a coleman evcon model dgat070bdf furnace. As soon as the furnace fan kicks on the burner shuts off. Any ideas?
Hi check the flame sensor is clean also check out the pressure switch , and check air filter is clean
Feb 05, 2010 | Coleman Propane Forced Air Heater...
Coleman evcon Dgato7obdc
Small blower motor? Are you talking about the combustion blower if so then check your vents for blockage.. if the vents are blocked won't work... if it has a control board init it will give you a diagnostic code. Flashing light on the board... count the flashes and look up the fault on the chart in your owners manual ot on the furnace door..
Jan 13, 2009 | Coleman Propane Forced Air Heater...
is the air filter clean afc could be dirty
Dec 22, 2008 | Coleman Propane Forced Air Heater...
I have an coleman evcon furnace when i turn a/c on the outside unit will run but the inside wont run
put the just the fan on turn off the ac and the heat and just fan on make sure the blower motor works cause thats really the only thing you utilize from the furnace in the summer and let me know
then if so does your heat work fine
May 30, 2008 | Heating & Cooling
Coleman 7990-319p Evcon Gas Furnace Control Board Logo
124 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
paulcarew
Dan Webster
Dan Webster
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
