Question about Refrigerators
GE gss25wgph bb
Freezer cold, refrigerator warm... have changed thermistors, defrost thermostat and main control panel, also check defrost heater and damper checked ok. Everything else seems to be working fine... system work fine for a few days and then go back to same cold/warm issue.... what else should I check
  • 49 Answers
SOURCE: Freezer is cold, main food compartment is warm
the evap fan probably stopped working because of the shorted defrost thermostat. if you remove the freezer drawer you will probably see frost build-up on the back wall. what you need to do is remove the back wall and manually defrost the coil with a hair dryer. have some towels handy. once the ice is melted you will need to replace the thermostat or this will happen again. you should buy a new thermostat before the repair so you know what you're looking for. hope this helps
Posted on Aug 20, 2009
SOURCE: GE refrigerator won't keep cool
check the voltage going into you fan w/ the old main board and also w/ the new board. You might be getting a low voltage w/ your new board or the fan you replaced is for a diferent voltage. Have you tried to put the old fan back w/ the new board??
Posted on Jan 18, 2010
  • 58 Answers
SOURCE: My GE Refrigerator Model No.
yes any one of these
Posted on Sep 26, 2010
  • 2468 Answers
SOURCE: i have a GE Adora
it sounds as though you have had a fan short out,be it an evaporator fan inside the freezer or refrigerator or the condenser fan down in the rear area,if one of these shorts out they will definately ruin this control board,before you replace the control find out which fan it is or it will ruin the new card immediately,the board is G.E. # WR55X10942 it is a new improved version of any other board now
Posted on Nov 30, 2010
  • 5370 Answers
SOURCE: have kenmore 253.54622402 side by side--from the
" waited 1 hour freezer 20 degrees // cold food side 45 degrees and no air flowing from damper " As per this it indicates that the ventilations are getting blocked after few hours.First the air was flowing from damper but after one hour it stopped flowing air from damper.Check the damper if there is too much water collected in the damper then press the damper and remove the water collected in it.------------ The working procedure of this Kenmore side by side refrigerator is as follows: --- The compressor starts then it cools the freezer section. When the freezer reaches its cooling level the defrost cycle starts functioning. In this cycle the fan in the freezer section starts running and the cool air in the freezer section is passed to the fridge section and the fresh food section gets cold. The air from freezer to fridge passes from the section, in that section the damper is located. Now this problem which you mentioned. In this problem the freezer thaws, this happens if the thermostat is not functioning or the heater is not heating. Then the ice starts getting collected on the evaporator coil. The evaporator coil is at the internal section of freezer. If too much ice gets collected then this ice blocks the fan in the freezer section from functioning and this blocks the damper section with ice getting collected there. This all procedure is controlled by the main defrost board of the unit. Now if the damper is not got blocked with too much water or if the ice is not got collected on the damper area then check the evaporator coils. If there is too much ice got collected on the coils, then takes a hair dryer and melt the collected ice. Then see if the problem returns again. But if there is little bit ice collected on the coils and fan is running properly then it's not a problem. In that case main board is faulty and it has to be replaced. The main defrost board is working but its not controlling the functions as required so the freezer thaws after few hours.
You can get required parts from sears part direct online site or from repairclinic.com site.
To test defrost thermostat you can test this way:---
The defrost thermostat is difficult to test since many refrigerators use different fixed temperature settings and unless you have a very accurate temperature test device the test will not provide proper results. Now you can take the defrost thermostat out of the unit and place the element only in a glass of ice water. When the element is cold it should have continunity between the two wires.------ The meter should not show a reading if the thermostat is turned off. If a reading appears, replace the thermostat.
When the thermostat is turned on, the meter should indicate "0" ohm or .3 or .2 on a digital readout. If it does not appear as "0" ohm or .3 or .2, replace thermostat.Turn the thermostat on and place each probe on either side of the thermostat so meter reads "0" ohm or .2 ohm digital. Put water and some ice in the cup. Temperature should be 32 degrees. If, after four minutes, the meter does not reflect infinite or .0000 on the digital meter open circuit, replace the thermostat.----If thermostat checked out ok then check defrost heater connection.The defrost heater is connected to the side of evaporator coil in the freezer section.If this defrost heater is faulty then it will not melt the ice getting collected on the evaporator coil and due to that defrost system will not be able to function as required.Remove the wire for one side of the heating element from the wiring and measure it for continuity, usually around 20 ohms or so.-----------
Now to see where defrost heater is located.Please click on this link below and see part number 14 on the diagram.And part number 15 is evaporator coil.And part number 21 is thermostat.
http://www.searspartsdirect.com/partsdirect/partsdirect/showSubComp.pd?imageUrl=http://c.searspartsdirect.com/lis_png/PLDM/R0405135-00006.png
This will help. Thanks. Helpmech.
Posted on Jan 20, 2011
Have a ge model # GTH21KBXAWW. The freezer works fine. The bottom half does not keep cold.
Freezer is cold but refrigerator is warm
  1. Evaporator coils are frosted over
If your issue is that the freezer is cold but the refrigerator is not as cold as it should be, the first step is to check the defrost system for problems. A key indicator in determining if perhaps you have a refrigeration defrost problem is visible frost on the evaporator coils. If your unit has frost you will need to check your defrost heater assembly, the defrost control, and the evaporator fan motor for a malfunction. Replace any erroneous parts as necessary.
  1. Damper
If your issue is that the freezer is cold but the refrigerator is not as cold as it should be, the damper door could be broken or jammed. The damper is a door that opens and closes to allow cool air to flow from the freezer into the refrigerator unit, and if it fails to operate correctly, not enough cold air will enter the refrigerator to keep it cold. The damper can be replaced if it is no longer operating properly.
  1. Thermistor
If your issue is that the freezer is cold but the refrigerator is not as cold as it should be, the thermistor connected to the control board might be defective. The thermistor is a sensor that examines the temperature inside the unit. If the part is defective, the refrigerator could not cool properly.
  1. Temperature control board
If your issue is that the freezer is cold but the refrigerator is not as cold as it should be, the temperature control board could be at fault. The temperature control board distributes voltage to the fan motors and compressor to keep them functioning. This board is very often misdiagnosed as the culpable cause and it is recommended to proceed with the troubleshooting process of elimination prior to replacing this part.
  1. Defrost thermostat
Another issue that can cause your freezer to be cold while the refrigerator is not as cold as it should be is the defrost thermostat. In order for the defrost heater to activate to melt away any excessive frosting on the evaporator coils, the defrost thermostat must sense that the temperature is cold enough to activate the defrost heater. Without this continuous cycle, the frost will excessively build up on the coils and prevent proper air flow inside the unit. The defrost thermostat can be checked for continuity with an ohm meter; if it's not present, the thermostat will need to be replaced.
  1. Main control board
A possible cause for a freezer that's cold but refrigerator that's not as cold as it should be is the main control board. The main control board acts as a "brain" for the unit, controlling the defrost cycle, compressor, and run time. However, it is an uncommon cause for this issue. This board is very often misdiagnosed as the culpable cause and it is recommended to proceed with the troubleshooting process of elimination prior to replacing this part.
Feb 25, 2015 | GE Refrigerators
My ge profile regrigerator is not cold in the refrigerator section, ice breezes on the back wall of the freezer and it will make ice at times. I think it is a defrost issue as I will shut off for a while...
Pull the refrig out and remove the 8 " x 10 " panel . Behind this panel , is the main control board . Unplug the refrig . Remove the BLUE plug from the board , with 3 larger wires going to it . Looking at the blue plug , the sequence will be wire1,wire2,space,wire3 . Get a short piece of insulated wire , and strip about 1/4 inch from each end . Insert 1 end into wire2 , and the other into wire3 . Plug the refrig back in . After about 3 min , look in the freezer , at the bottom , behind the crisper , look for a red glow . If no red glow , unplug the refrig , and reassemble the plug and cover . This no glow , indicates a shorted defrost heater WR51X10101 . It is also advisable to replace the defrost thermostat ( pt. number WR50X10068 ) when replacing the heater . To access these parts , you will have to remove the inside rear wall of the freezer . The heater , is at the bottom of the coils , held on with 2 screws , and the thermostat , is the 1 " cylinder , with a blue and pink wire going to it , clipped on the top left of the coils .
If you do get a red glow , then the # 4 thermistor is bad . This tells the main control board , the temp of the coils , if they need defrosted , when they are thru defrosting . This thermistor is the 1 " long , torpedo looking piece , clipped on the top left of the coils , with 2 white wires going to it . Part number WR55X10025 . It would be advisable to also replace the # 5 thermistor , located at the bottom of the freezer , slightly in front of the drain , also with 2 white wires going to it , slid into a housing . This thermistor , is the freezer thermistor , which tells the control board , the freezer temp and when to cycle off due to selected temperature .
Jul 18, 2010 | GE GSS20IEPWW / GSS20IEPCC Side by Side...
GE side-by-side not saying cold
If you do get a red glow , then the # 4 thermistor is bad . This tells the main control board , the temp of the coils , if they need defrosted , when they are thru defrosting . This thermistor is the 1 " long , torpedo looking piece , clipped on the top left of the coils , with 2 white wires going to it . Part number WR55X10025 . It would be advisable to also replace the # 5 thermistor , located at the bottom of the freezer , slightly in front of the drain , also with 2 white wires going to it , slid into a housing . This thermistor , is the freezer thermistor , which tells the control board , the freezer temp and when to cycle off due to temp setting .
May 26, 2010 | GE GSS22JF Side by Side Refrigerator
Freezer cold, refrigerator wont get cold what can be the cause of this
lack of air flow from freezer to the refrigerator, since you have a side by side, this narrows it down a little. it could be not automatically defrosting, visual sign is thick frost on back wall of freezer, due to either a bad: main control board; defrost heater; evaporator thermistor; or safety bimetal thermostat. could also be a bad evaporator fan motor, due to a bad motor; bad main control board, or both. air damper is stuck closed, preventing air from entering fresh food side. or ice build up due to an improper door seal or other warm air source.
Mar 17, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer working but refrigerator is not cooling
if freezer is close to zero, top to bottom, and fridge is warm(ing), then you likely have a defrost problem, you will notice an abundance of snow/frost on back wall of freezer. it could either be your heater, thermistor, defrost safety thermostat, or your defrost control/main cpu, depending on model. if either or both sides are warm at the top, and cold at bottom, then your freezer fan is out. again depending on your model, it may just be the fan, or a combination fan/main cpu board hope this helps
Feb 15, 2010 | GE Profile PSW26P Stainless Steel Side by...
My refrigerator the evaporator keep freezing , i had clean out the ice ,but after 2 , 3 week it freezing again , can please let me know . my refrigerator model-gsh25jstass
Pull the refrig out and remove the 8 " x 10 " panel . Behind this panel , is the main control board ( you already know , since you changed it ) . Unplug the refrig . Remove the BLUE plug from the board , with 3 larger wires going to it . Looking at the blue plug , the sequence will be wire1,wire2,space,wire3 . Get a short piece of insulated wire , and strip about 1/4 inch from each end . Insert 1 end into wire2 , and the other into wire3 . Plug the refrig back in . After about 3 min , look in the freezer , at the bottom , behind the crisper , look for a red glow . If no red glow , unplug the refrig , and reassemble the plug and cover . This no glow , indicates a shorted defrost heater ( pt. number WR51X10055 ) . It is also advisable to replace the defrost thermostat ( pt. number WR50X10068 ) when replacing the heater . To access these parts , you will have to remove the inside rear wall of the freezer . The heater , is at the bottom of the coils , held on with 2 screws , and the thermostat , is the 1 " cylinder , with a blue and pink wire going to it , clipped on the top left of the coils .
If you do get a red glow , then the # 4 thermistor is bad . This tells the main control board , the temp of the coils , if they need defrosted , when they are thru defrosting . This thermistor is the 1 " long , torpedo looking piece , clipped on the top left of the coils , with 2 white wires going to it . Part number WR55X10025 . It would be advisable to also replace the # 5 thermistor , located at the bottom of the freezer , slightly in front of the drain , also with 2 white wires going to it , slid into a housing . This thermistor , is the freezer thermistor , which tells the control board , the freezer temp , when to cycle off , associated with the fan speed also .
Dec 04, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrig. is about 4-5 years old and regrig side stop getting cold then the freezer followed suit-not getting cold. what should i do
Look inside the freezer on the back wall. If there is ice on the back wall the defrost heater and defrost thermostat are the usual suspects. They are both in the freezer behind the back panel.
Look for a deformed defrost thermostat. The glass heater will look burned. Both can be checked with a meter set for continuity. No continuity equals a bad part. Remove the wires from the parts before checking or a false reading will occur.
Nov 09, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
It will not defrost..the mother board ,the defrost thermostat,and the heater have all been changed..
Sounds like the # 4 and # 5 freezer thermistors need changed . The # 4 , is the 1 " torpedo looking piece , clipped to the top of the coils . The # 5 thermistor , is located at the bottom of the freezer section at the bottom of the rear panel , with 2 white wires going to it . Still a 1 " torpedo looking piece . The # 4 , tells the main control board , the evaporator temperature . The # 5 , tells the board , the freezer temperature .
Sep 17, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Side by side not cold changed mother/selionoid/defrost bulb /water valve still not freezing all the time
You changed the main control board (?) , what solenoid , defrost heater (?) , ?? Does the freezer still frost up in back ? If it does , then the defrost thermostat is probably bad ( the little 1" disk clipped on the coils with a red and blue wire attached to it ) . Also , there are 2 white thermistors ( 1" long torpedo looking piece with 2 white wires) . 1 clipped to the top of the coils , the other located at the bottom left rear of the freezer , slid into a holder . These thermistors relay to the main control board , the temp of each area . Top ; the evaporator temp , bottom ; the freezer temp . Sometimes , they lie to the control board , in which case , they should be replaced .
Aug 19, 2009 | GE GSL22JFPBS Side by Side Refrigerator
Refrigerators Logo
81 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
