13.03.00 paper jam in tray 2 hp 4250 - Office Equipment & Supplies
Printerguru
  • 10 Answers
SOURCE: hp 4250 paper jam erro
Is it a new or refurbished fuser? Where exactly does it jam. By trays, registration or before fuser? Problem can be with various sections. Need to know more.
Posted on Feb 13, 2008
  • 7 Answers
SOURCE: hp m4345 printer tray 2 paper jam
Clean the rubber intake rollers with alcohol and allow to dry for 10 minutes. Take the tray out and you should be able to see the roller inside. Also check to make sure that the printer is default to tray 2. Use the Menu option on the LCD screen of the printer. Set the default tray to tray 2 in the windows driver as well. You should be able to easily get to this by hitting "ctrl+p" when you are ready to print a document.
Posted on Jun 12, 2009
  • 130 Answers
SOURCE: Paper jam
Try taking out the toner cartridge and seeing if you see any more bits of paper. Also open up the back panel and see if you see anything there.
  • 1684 Answers
SOURCE: hp lj 4250 tray 1 stoped feeding automatically.
Here is the info from the service manual about tray configuration.
The value corresponds to the media size that is currently loaded in tray 1. ANY: If both the type and size for tray 1 are set to ANY, the printer will pull media from tray 1 first if media is loaded in the tray. A size other than ANY: The printer does not pull from tray 1 unless the type or size of the print job matches the type or size loaded in this tray.
So set both the paper size and type on tray one to "ANY" and you should be good to go.
I hope this helps, if so please rate my solution.
I have the full service manual available for instant download for $6.95 if you are interested.
Buddy
buddy@ccl-la.com
Corporate Computer
WWW.CCL-LA.COM
Posted on Jul 10, 2009
DosHog
  • 168 Answers
SOURCE: 13.01.00 paper jam tray 2
The pickup rollers are worn out. Replace them and your problem will be gone. While you are sourcing them, use some alcohol. This may give them a little more life.
Posted on Jul 23, 2009
HP LaserJet 4250n Printerclearing paper path Questions
If this continually displays then either you have an actual paper jam in the printer that you have not found yet or a flag is broken/sensor has failed. Make sure you check the paper path that runs from the tray behind the MP tray assembly.There is a sensor in there that can be damaged.
Dec 02, 2015 | HP LJ 4250 Printer
HP M4345xs MFP Unable to load paper from tray 2
Hello Robert,
The normal cause of not being able to pull paper from tray 2 is worn out paper pickup rollers. You can pull out the paper tray and look inside the opening the opening to see the rollers on the right hand side. Here is a picture of the rollers.
The end of the roller has a little clip to press to release the rollers from the shaft. If you remove them and check the surface you will probably find then to be smooth, they should have a surface like a fingerprint to grab the paper. The rollers come in a kit called RK-4250 that included the rollers for tray 1 and tray 2. The RK-4250 is available here: http://www.ccl-la.com/catalog/product_info.php?products_id=302 Replacing the rollers should bring the printer back to full use. Be sure that when you replace the rollers that you puch them back on the shaft until they click into place.
I hope this helps you get your printer going,
BuddyMc
Mar 28, 2013 | HP LaserJet M4345 MultiFunction Printer
HP 4250 SKEWING PAPER
Yes, it is possible to be the problem. Most of the time you would replace the whole fixing unit, it could also be the paper feed rollers in the paper tray or the manual feed tray. Good Luck
Sep 04, 2012 | HP LJ 4250 Printer
I have a hp laserjet 4250 printer it had a paper jam in tray 2 i have cleared the jam but it keeps saying i still have the jam in tray 2
There is still paper stuck in the printer. try lifting the printer off of tray 2 to inspect it or here it is straight from the service manual...
Jams in tray 2
Table 7-10 Causes of tray 2 jams
Cause Solution
The feed or separation rollers are dirty, worn, or damaged. Clean the rollers. If they are dirty after cleaning, or if they are
worn or damaged, replace the rollers.
The pickup roller is worn or damaged. Replace the pickup roller.
The tray 2 paper pickup assembly drive gears are damaged
or the assembly is defective.
Check the drive gears in the paper pickup drive assembly.
Replace the pickup drive assembly if the gears are
damaged. See Paper-pickup drive assembly.
The tray 2 pickup solenoid (SL101) is damaged. 1 Disconnect the connector for the tray pickup solenoid
from the dc controller PCA (location J92).
2 Measure the resistance between the cable connectors.
3 If the measured resistance is not approximately
160 ohms for the HP LaserJet 4200/4300, or 110 ohms
for the HP LaserJet 4250/4350, replace the tray 2
pickup solenoid.
The tray 2 lifter-drive assembly or the stack position
sensor (PS107) is defective.
Replace the lifter-drive assembly. See Tray 2 lifter-drive
assembly and/or Printer switches and sensors.
The dc controller PCA is defective. Replace the dc controller PCA. See Dc controller PCA.
Dirty, worn, or deformed pick-up roller, cassette separation
roller, and cassette feed roller.
Clean the rollers if they are dirty. Replace any worn or
deformed rollers. The cassette separation roller and the
cassette feed rollare are to be replaced together.
Damaged gears in the cassette pick-up drive unit. Move the gears in the cassette pick up drive unit. If the
gears are not rotating correctly, or are damaged or worn,
replace the cassette pick-up drive unit.
Dec 25, 2010 | HP LaserJet 4250 Printer
Error 60.20 hplaserjet 4250
Issue
After powering up the printer, a 60.2 error is displayed on the control panel. Even after power cycling the printer, the error does not clear. This error indicates that tray 2, and the lifter-motor for tray 2, are not functioning.
Follow the steps in the Solutions section before changing the lifter and DC Controller PCA.
Solution
Complete the following steps, testing the printer after each step to determine if the issue has been resolved:
  1. Turn the printer off and then power it back on again.
  2. If the error persists, turn the printer off.
  3. Verify that the tray 2 lifter wire-harness is fully seated in its connector on the DC controller PCA. Test the printer.
  4. Check the tension of the spring in the lifter. If the tension is not correct, replace the spring (RC1-0198-000CN). Test the printer.
  5. Replace the tray 2 lifter-driver assembly. Test the printer.
  6. Replace the DC controller PCA. Test the printer.
Jun 07, 2009 | HP LaserJet 4250dtn Printer
Paper jam on a laserjet 4250
Is the paper tray set to the proper size? and are the tray guides snug against the paper?
Apr 14, 2009 | HP Office Equipment & Supplies
HP 4250 down (paper jam without paper)
hi,
the fuser of that unit is in the back, you can saw it by sliding out the back cover. you can pull it by unlocking the 2 lock on side of it..
try to locate the sensor of the fuser assembly.and also try to see if they pick up very well both tray 1 and tray 2..
hope it would help you..
Aug 05, 2008 | HP 4250 Monochrome LaserJet Printer
HP 4250 DN
Change the tray one behavior from the front panels paper handling menu. from there you can tell tray 1 to print first if paper is present or default to tray 2.
factory settings are to print from tray 2.
are you keeping paper in both trays??
Mar 28, 2008 | HP LaserJet 4250n Printer
Hp 4250 paper jam erro
Feb 12, 2008 | HP LaserJet 4250dtn Printer
605 people viewed this question
jasbo
jasbo
