I have a ar-5631 sharp copier with a h3-10 trouble code.
  • 190 Answers
SOURCE: error code Sharp AR-M 257
The F2-04 error code you are getting is that you are using the wrong toner.It may be form sharp,but it toner chips is different.Only the chips swapping at the toner back can help you.
Posted on Jan 27, 2009
  • 126 Answers
SOURCE: Sharp AR-5127 H2-00 code reset
Sharp Fuser
H2-0 Fusing unit temperature error
H4-0 The fusing unit doesn't heat up.
***ALWAYS DISCONNECT POWER WHEN WORKING ON MACHINE***
You have to reset fuser errors with simulation 14. Push P * C * then 14 then Start (the button you use to make copies) and it should reset the code. If not then replace the fuser.
SM 5-1 should turn the lamp on. If lamp blinks on and off it is the thermistor, if it does not it is the lamp, but check the contacts on the lamp/fuser -- they have been known to erode.
Also check thermal fuse, if defective replace.
Posted on Feb 01, 2009
mickspaceNET
  • 115 Answers
SOURCE: Lost key operator code for Sharp Copier AR-M207.
The default is 00000
Simulation 22 - 07 will display the Key operator code.
Perform the following procedure to enter the simulation mode.
"#" key -> “*“ (star) key -> "C" key -> “*“ (star) key (do this in quick sequence order, the display should change, then enter below)
Main code {22} ->
(Green Copy Button) Start key ->
Sub code {07} ->
(Green Copy Button)Start key
Press the "CA" button to go back to Copy mode.
Posted on Feb 06, 2009
007tech
  • 95 Answers
SOURCE: Sharp Copier AR -407 Error code H3-00
H3-00 means there was a problem in the fuser unit of the copier - a temperature problem. The correct temperature is not reached within a certain time.
It could be a thermostat or thermistor problem - both monitor temperature. you could remove the fuser unit and make sure these items are clean - no build up on them. there should be a center and side thermistor.
You can reset the error code in SIM mode by pressing the following keys one after the other "P" "interupt" "C" "interupt" then 14 and start/copy key. confirm if required. make sure the copier is restarted afterwards.
If the error persists then you may need new thermistors.
Hope this helps.
Posted on Apr 12, 2009
007tech
  • 95 Answers
SOURCE: sharp copier ar-bc320 error code??
the DK message means it is time to replace the black drum unit. the drum unit is called an ARC26DU. open the front cover. remove the toner cartridge/s by lifting the green lever and pulling the toner out. Open the left side door. look at where you just pulled out the toner and there is one screw (facing you) holding each drum in place - loosen the screw and pull the drum unit out towards you....slide in the new drum unit.
to reset drum counter go into SIM mode by pressing the following keys one after the other "P" "*" "C" "*" then 24 and start/copy key then 7 then select the color drum you are replacing and confirm reset. make sure copier restarts afterwards
DO NOT refill these toner cartridges (even if you can find someone to do it) The toner cartridges for these machines have generally had ongoing problems as far as longevity and quality - refilling them will only make it worse.
Posted on Apr 23, 2009
SC L6-10 ON 5631
i have problem in my photo copier sharp ar203e the problem is op what mean?
Mar 22, 2013 | Sharp AR-M450N Copier
Sharp AZAr-5631
please see the counter of your copier.if is over 50000 change developer.black lines occures when sharger unit above the drum unit is unclean.
May 15, 2010 | Office Equipment & Supplies
Ar 5631 showing maintenance required error
Press the :
( #/P ) key --> ( * ) key --> ( clear ) key --> ( * ) key
reset the maintenance counter: 24 start --> 4 start
Apr 07, 2009 | Sharp AR-5316 Advanced Digital Imager...
95 people viewed this question
jasbo
jasbo
