Question about Garden
Sears edger 3.5 hp.mod#536.797461 gas runs out of the air filter
  • 3 Answers
SOURCE: Briggs & Stratton Engine Won't Stay Running
Make sure none of the hoses are cracked or loose fitting
Posted on Aug 03, 2008
  • 69 Answers
SOURCE: craftsman edger won't start
Does it have a primer bulb? If so, make sure the bulb is not cracked. Also, make sure the fuel lines are not cracked and the fuel supply line reaches the bottom of the tank. Fuel lines, as silly as it sounds, degrade when exposed to gas for long periods of time. If they are cracked it will draw more air than fuel and not allow the engine to run. You can buy replacement fuel line/primer bulb kits for under $10 at practically any hardware store.
Posted on May 27, 2009
  • 376 Answers
SOURCE: Craftsman Edger 536-797520 is leaking gas from the air filter
The needle valve is sticking open. The carb needs cleaning and diaphragm replaced. Probably best taken to a shop unless you have experience with diaphragm carburetors. Dwain
  • 95 Answers
SOURCE: Briggs & Stratton 3.5 HP engine won't start
You will have to remove the fuel bowl from bottom of carburetor and clean the varnish out of the carburetor.Take note that the screw on the bottom of the carburetor is a fuel metering jet,there are small passages in it that may need to be cleaned out with a small wire,be careful not to enlarge the holes in it,they are important for fuel metering correctly.You may have to soak it in carb cleaner. Be sure to use good carb cleaner. The brand name Berkebile 2+2 is the best followed by Gumout.
Posted on Jul 31, 2009
bbreton
  • 437 Answers
SOURCE: THIS GAS EDGER HAS A PRIMER BULB. I PUSH IT THE
The jet in the carburetor is clogged if it is a 4 cycle unit or the diaphragms are stiff if in a 2 cycle unit. It is burning the primed fuel but can not draw any more fuel to burn to stay running.
HTH
Good Day
Posted on Nov 20, 2009
Why is gas leaking from the air filter
This is a carb flooding issue, there will be a rubber tipped needle in the carb, if this is not seating properly fuel will leak through the air filter, you need to go into the carb, check the metering lever height and replace the needle, unfortunatly it is not possible to replace the needle seat so if it continues to leak after fitting a new needle it will be a replacment carb.
Jun 01, 2013 | Garden
My mtd 3 hp edger wont start ,
does it have spark remove the plug hold nit near the head and pull the rope is there spark?
Apr 26, 2012 | Garden
Looking for the part number of the air filter on craftman edger model # 53685648
On the Sears Parts Direct, they show no air filter. I would recommend taking the filter to a small engine shop so they can match it up or just go to Home Depot and match it up with one of their filters they may have in the lawn and garden. Lowes has a small engine section too, most of their stuff is Briggs and Tecumseh. Here is your parts diagram, with no air filter shown.
http://www.searspartsdirect.com/partsdirect/part-model/Craftsman-Parts/Edger-Parts/Model-53685648/0247/1503400?sid=PDVertical
Aug 13, 2011 | Craftsman Gas Mini - Tiller/Edger
I have a 1999 sears edger # 536-796525 model but wonder what Make engine is it? Bought it used so no manual and no engine name on it, small about 3 HP. Spark plug on top of old fashioned looking motor...
That is a sufficient amount of oil. Even the more modern horizontal crank engines have no dipstick and are checked that way. Anywhere in the threaded area and up is considered sufficient. It is great fun trying to find a manual from just 11 short years ago! The sites have manuals for almost all their current equipment, no luck finding yours yet. I am including a parts breakdown with diagrams, pricing and availability for your convenience from Sears. The manual is no longer available (part #73)
http://www.searspartsdirect.com/partsdirect/part-model/Craftsman-Parts/Edger-Parts/Model-536796525/0247/1503400?pathTaken=
Mouse over the images to get detailed parts list.
Nov 29, 2010 | Craftsman Gas Mini - Tiller/Edger
My yard machine Edger 3.5 hp wont stay runing if i put ges in the air filter hole it runs for a few sec. if I put my hand completly over the hole on the air filter it will run on low idle but as soon as i...
remove the gas can carefully the pulsa primer carburetor sits on top. Once you remove the tank open the cap and pour out the gas. THen carefully unscrew the five screws holding the carb on. Carefully lift the carb up leaving the gasket in place and clean the small 4 chambered bowl with starter fliud. Replace all parts put gas in it, push the primer until you see gas squirt into carb then pull the handle.
Sep 03, 2010 | Yard Machines Red Edger
My 3.8 hp Sears Craftsman gas edger starts but stops after a couple of minutes. It's clean and fairly new.
Have you tried cleaning the carb? If not then buy some carb cleaner and spray it into the carb. Also check your air filter and make sure it is clean.
Aug 31, 2010 | Garden
I have a 3 gal. air compressor mod. 921.153101, what type of oil does this unit take use?
I am sure that Sears has there own oil they would prefer you use, If not a quality brand of SAE 30 is commonly used in these compressors.
Aug 25, 2010 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Weed wacker wont start
You do know my neighbor took her sears craftsman edger in and got a new one after a year. TAKE IT BACK!!!!!!!!
Jun 09, 2009 | Craftsman 25cc Gas Line Trimmer
Aug 03, 2008 | Troy Bilt 17 Inch 29 Cc Gas Powered...
Garden Logo
141 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
