Question about Xerox Phaser 7400DN Laser Printer
Usb is not detecting xerox phaser 7400
Usb not recognition my pc
  • 3 Answers
My copier is not able to operate because of Dept ID and password. So, can you suggest ways to remove the Dept ID and Password?
Posted on Jul 17, 2013
  • 208 Answers
SOURCE: Tranfer Unit
  1. Open the Top Cover on the printer.
    CAUTION: Do not leave the Top Cover open for more than 10 minutes without covering the Imaging Units as damage could result. Use the dark bag that came with the Imaging Unit or opaque paper as a cover.
  2. Remove all four Imaging Units (which includes removing the Toner (Dry Ink) Cartridges attached to the Imaging Units). To avoid Toner spills, hold the Imaging Unit in an upright position.
    CAUTION: Do not use warm water or cleaning solvents to remove Toner (Dry Ink) from your skin or clothing. This will set the Toner and make it difficult to remove. If any Toner gets on your skin or clothing, use a brush to remove the Toner, blow it off, or wash it off with cold water and mild soap. Do not attempt to use a standard shop vacuum or home vacuum to clean Toner spills in or near the machine. Shop and home vacuums are not equipped with correct filtration and will contaminate your environment.
  3. Raise the two gold colored latches (front and rear of printer) to unlock the Transfer Unit.
  4. Grasp both gold colored handles (center and right) to lift the Transfer Unit out of printer.
To install a new Transfer Unit:
  1. Remove the new Transfer Unit from its packaging or shipping materials.
  2. Grasp the two handles on the new Transfer Unit and place the left end into the frame alignment sockets.
  3. Lower the right end of the Transfer Unit down until it lays flat in the printer.
  4. Press down on both latches to secure the Transfer Unit into position.
  5. Make sure the Transfer Unit is latched into position. Lift up on the right handle to see if the Transfer Unit lifts up. If the unit does not lift it is latched correctly.
  6. Re-install the Imaging Units and Toner (Dry Ink) Cartridges.
  7. Lower the Top Cover.
  8. Dispose of the old Transfer Unit as normal office
Posted on Dec 04, 2007
  • 2072 Answers
SOURCE: xerox phaser 7400
Remove the tray, first look for a piece of paper that has come out of the tray inside the tray area.
Make sure the rolllers are snapped into place. The easiest way to verify that is to remove another tray and compare them.
Look to see if all the switches and actuators are in place.
Make sure you hear the tray up motor running when you close the tray.
Also inspect the paper tray itself for broken items. Compare it to another tray.
Posted on Feb 04, 2008
SOURCE: PRINTER ERROR
There is a tiny little magnet that falls off and/or has reportedly been put on backwards (fell off is what happened to me) on the auger assembly. It's near the black auger chute on the end of a shaft. It's tiny--a little bigger than a grain of rice. I had to replace the auger shaft assembly but if you can find the magnet, you can super glue it back on.
Posted on Jan 17, 2009
  • 110 Answers
SOURCE: Phaser 7400 LCD is blank. How can that be fixed?
Once the LCD is gone blank that means you have to change the control panel. it's not difficult to change, all you have to do is remove the covers that are behind the the control panel. Once you have removed the white covers you can now unscrew the metal hinges. Then you have to insert a flat head in the small cracks behind the control panel that opens the control pane blue covers. Now you disconnect the data cable that connects from the control panel to the machine and that's it. Hope this helps
Posted on Nov 02, 2009
  • 110 Answers
SOURCE: Xerox Phaser 7400 displaying error code u60
Job Offset Home Position Sensor does not detect home position for the Job Offset Assembly.
Check the following for evidence of fault or
damage:
■ Home Position Sensor Actuator
■ SNS Harness
Is there any damage or misalignment?
parts that need to be changed if still no fixed.
Rear Sensor Board
Job Offset Assembly,
hope this helps.
Posted on Dec 17, 2009
I have a phaser 7400dx and the color alignment is off, I've heared people talk about that it is set in the main board and can be fixed. I was wondering how it is fixed?
Below is the link to 7400 documentation, the user guide on this page provides good info on color and image misregistration problems and some potential fixes ...
http://www.support.xerox.com/support/phaser-7400/documentation/enus.html
Alos, if it is a problem wioth your main PWB you may want to contact your Xerox service technician for assistance ......
I hope this helps.
Mar 09, 2015 | Xerox Phaser 7400/DX Laser Printer
Can I print to the edge with Phaser 7400
No this is phisically impossible, try a larger sheet of paper and cut it
Mar 17, 2013 | Xerox Phaser 7400DN Laser Printer
Xerox phaser 7400
You can download the Xerox printer drivers from theirsupport WEB site. Please click on this link and select your model printer todownload :-http://www.support.xerox.com/support/enus.html
Feb 24, 2012 | Xerox Phaser 7400/DXF Laser Printer
On power up the xerox phaser 7400 displayed.
HI there check the fuse on the xerox machine and let me know its ok or not.
Jan 24, 2011 | Xerox Phaser 7400/N Printer
Getter "Report fault 917" on my Phaser 7400. How can I fix?
I am getting a report fault 917 error on the phaser 7400
Sep 23, 2010 | Xerox Phaser 7400/DXF Laser Printer
What is error code 941 on a Xerox Phaser 7400?
www.support.xerox.com -phaser 7400- support -fault code-941 says cyan or magenta toner failure, but the solution says to
1. remove & reinsert the cyan or magenta imaging units.
2. replace imaging units .
check out the site to see if helpful
Jul 01, 2010 | Xerox Phaser 7400DN Laser Printer
Xerox Phaser 7400 displaying error code u60. Even after rebooting.
damage:
■ SNS Harness
Rear Sensor Board
hope this helps.
Dec 17, 2009 | Xerox Phaser 7400/N Printer
Xerox Phaser 7400 printing
Reinstall the latest print drivers. This issue has been resolved previously
Apr 22, 2008 | Xerox Phaser 7400/DXF Laser Printer
Xerox Phaser 7400DN Laser Printer Logo
50 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
