Washing Machines
Problem for Washing Machines
Generic problem for all Washing Machines
Washing machine repair
By dbelk on Aug 28, 2007
washing machine will not spin motor runs
Same Problem
Jan 28, 2009
-   Frigidaire front load washer will not spin e20 on display -   tneverhart66
Jan 07, 2009
-   My washer is front loading and will wash and agitate but will not spin at all. -   mholtok
Jan 05, 2009
-   washing machine wont spin or agitate-   jaswander
Jul 12, 2008
-   My washer fills up but will not spin at all. I have replaced the the door control. It still doesn't spin. Model#FTF530F50 Frigidaire front loader.
Thanks,
Jaime-   JCjam
Jun 10, 2008
-   My washer sounds like it's spinning, however the drum is not moving. What is the problem?-   Marla M
Solution #1
posted on Aug 28, 2007
Somewhat Helpful)
gittos73
Rank: Guru
Rating: 87%, 300 votes
without knowing the make there are 3 parts that could be at fault
1)has the motor got carbon brushes these u will find by looking for a wire going to each sides off the motor which go into a plastic covering that surrounds the carbons if these are lower than8ml in length than they need replacing if these r ok than2)its your motor if the motor does not have carbon brushes then the washer will have a module which tells the motor how much power to use its about 4in in length 2in in heigth and will be a circuit board let me know what make it is m8
Was this helpful?
Yes
No
Solution #2
posted on Feb 23, 2009
Not Rated)
suskin
Rank: Apprentice
Rating: 0%, 0 votes
Need to remove the drum from a top load roper washer. Do I need a spanner wrench?
Was this helpful?
Yes
No
Solution #3
posted on Oct 16, 2007
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Sounds like the motor to transmission coupling is broke. Pretty easy to fix.
UNPLUG THE WASHER!!!
Standing in front of the washer, you'll see two screws on either side of the control panel... remove these then flip the control panel over. Now, toward the right side, you'll see a wire harness that plugs into the top of the top panel, disconnect this. Now, on either side of the top panel, you'll see two brass colored clips. Take a screwdriver and poke it into the hole, use it as a pry bar. Pry the handle of the screwdriver toward the wall behind the washer, the clip will pop out. Now tilt the entire cabinet of the washer toward you to about a 45 degree angle then lift it out of there and set it aside out of the way for now.
OK, now we're into the guts of the washer... Look below and in the center, you'll see the drain pump (it has 2 big hoses attached). Behind that, you'll see the motor... that's what you'll be taking off.
On the right side of the motor, you'll see the electrical connections. Remove the long white one from the motor. (CAUTION!!! THIS NEXT STEP MUST BE DONE, OTHERWISE PERSONAL INJURY MAY RESULT!!!) You'll see a black round thing mounted to the motor on the right hand side, this is the capacitor. It has 2 red wires on it. (It's basically a 120 volt battery that is just waiting for you to touch it so it can shock you, badly) THIS MUST BE DISCHARGED (voltage drained off) BEFORE CONTINUING. Remove the 2 wires using insulated needle nose pliers. Now, discharge the cap by touching both terminals of the cap at the same time with your needle nose pliers. This will discharge the capacitor so it's safe to handle.
Now, above and below the motor, you'll see 2 clips mounted on it, remove the screws that keep these clips in place then (with a flat head screwdriver) pry the clips off the motor. The motor and pump will drop out of there. Rotate the whole thing off to the left (with the hoses still attached to the pump).
Now you can see the broken coupling (compare the old one and the new one). Pry the old pieces off the motor shaft and the transmission shaft and throw 'em away. Install the new coupling (notice the semi-triangular shape of the inside of the plastic coupling? I use my screwdriver handle... poke the handle into the coupling, place the coupling squarely on the shaft, then tap [don't BANG] it home with a hammer) and rebuild in the reverse order of dis-assembly!
Popular Solutions for Washing Machines
Questions and Unsolved Problems for Washing Machines
Answer
need to purchase a new front load washer to replace my 7 year old frigidaire
Answer
Whirlpool Cabrio WTW6300 worth the $$?
Answer
my washer will not compleat a wash cycle it stops and sud flashes and want drain what can i do
Answer
water temp is set on hot, but it still fills up with cold water.
Answer
I have a maytag front load and the softener is not dispensing. Always some left in the dispenser
12 Other Users Have The Same Problem - Continued
Comment by montanag, posted on May 02, 2008
I have a HAIER XQJ50-31B l put the washing maching on when l went out l have done this loads of times before no problem, when l came back the machine was finnished or so l thought. The agitor l can hear it moving but the drum that it sits in that usually spins is not spinning. l looked under the machine and the belt works its not broken, what can l do. thanks
Comment by Guest, posted on Apr 05, 2008
My washing machine agitates and drains but will not spin.
Comment by Guest, posted on Mar 27, 2008
Clothes are soaking wet at end of the cycle. It drains but doesn't spin (sometimes or maybe not that good or fast?) The machine will spin, sometimes it won't. I think it's getting worse. Wife said there was a smell in the beginning, but gone now. With the lid open, she presses the switch and starts spinning the tub herself. It starts to spin but seems it doesn't spin fast as before problem began. In the past, she says it even locked up and would have to turn it back to turn it forward to get it started. What could it be? I test it without a load and it spins every time. Hmmm....
Comment by Guest, posted on Jan 16, 2008
i have the same problem on rinse and spin but washing it only gos one way
Comment by alexcat, posted on Dec 30, 2007
After the wash cycle completes it stops and buzzes like it's trying to rinse and spin but it does not. It just buzzes, stops, buzzes, stops. I have unplugged for 1/2 hour and replugged but it does not want to do anything beyond agitate in the wash cycle. No rinsing, no spinning. I was washing a set of king sized sheets and a few pieces of underwear on the regular cycle. I removed everything, but no luck. It will fill, but that's all. It's only 6 months old. When this first happened I thought I smelled something. Rubber? Of course it is the New Year's Holiday weekend and cannot get any service reps to call me.
Comment by jersey gerry, posted on Dec 19, 2007
The motor does not always kick in, but if one releases it, it runs normal, it is beyond my experience to determine the problem
Comment by JJTJ, posted on Dec 05, 2007
sounds like it will spin or aggiatate but doesn't spin not even freely..
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Washing Machines:
Top Washing Machine Experts
Rank: Guru Guru
Solutions: 14889
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more Washing Machine Experts
Top Washer & Dryer Repair
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
