Freon capacity for a/c model MN SCU10A48A - Heating & Cooling
Freon capacity for model lghc2342lf0
Hi david sitler, thank you for your inquiry!
I see you are looking for the capacity of freon on the inside of your Frigidaire refrigerator, LGHC2342LF0. The freon capacity is very rare to locate for an refrigerator. I would recommend speaking with a professional to properly allow them to diagnose your appliance. Hope this is helpful. -Matt
Sep 19, 2014 | Frigidaire Refrigerators
Where can I find the Freon capacity?
why??? capacity is very small on fridges say 3-8 ounces for most
Aug 30, 2014 | Refrigerators
Freon capacity chart
there is a decal under the hood somewhere that has the capacity of the system on it. it depends on if you have rear air as this will take more Freon. most are about 1.5lbs with front only a/c.
Aug 21, 2014 | Cars & Trucks
What is the freon capacity of my 1999 Buick century?
most cars have it printed on decal the body under hood it will say 134-a capacity 2.3lb ,when adding Freon allways follow detailed instructions .if system has been emptied you may have to use Freon with oil in it
Aug 06, 2014 | 1999 Buick Century
FREON CAPACITY OF 2007 PONTIAC TORRENT AWD?
The specs for freon capacity is located on a label either on the underneath side of the hood or on the upper tie bar, IN PLAIN SIGHT FOR ALL TO SEE!!!
Jul 26, 2014 | 2007 Pontiac Torrent AWD
Freon capacity for 1998 ****** 37 ft ticonderoga rv
There should be a decal under the hood showing type of refrigerant and capacity for the system.
Jun 12, 2014 | RVs
What is the Freon capacity on my 2002 Saturn SC1. It has a 1.9 liters engine, 4 cylinders.
THE ACTUAL FREON CAPACITY IS UNIMPORTANT. WHAT IS IMPORTANT IS THE PRESSURES WHEN THE SYSTEM IS RUNNING. THE LOW SIDE SHOULD BE 25-35 PSI, THE HIGH SIDE APPROX 250 PSI. THE HIGHER THE AMBIENT TEMP, THE HIGHER THE HI SIDE PRESURE. USE PROPER TOOLS TO CORRECTLY EVACUATE AND CHARGE THE SYSTEM. AVOID OVERCHARGING AS TOO MUCH FREON IS WORSE THAN NOT ENOUGH.
Apr 01, 2013 | Cars & Trucks
Freon capacity for gmc suburbun
3.8 Lbs of R-134 , if the vehicle has rear air, that 3 12 oz cans and an a 6 oz can of 134 with oil for lubrication of system
Jul 27, 2010 | 1999 GMC Suburban
Heating & Cooling Logo
35 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
