Question about Bias SoundSoap Pro 2 for PC, Mac
Soundsoap 2 serial - Bias SoundSoap Pro 2 for PC, Mac
My Cadillac 2004 cts dashboard lights come on but it want crank I need help
Your best bet would be to take your vehicle to the dealer ! You have no idea of the complexity involved in the starting of this vehicle ! The computer contols and serial data network etc....
Serial Data Power Mode
On vehicles that have several control modules connected by serial data circuits, one module is the power mode master (PMM). On this vehicle the PMM is the DIM. The PMM receives 2 signals from the ignition switch.
To determine the correct power mode the PMM uses the following circuits:
• Accessory voltage
• Run/Crank voltage
Table 1: 2-Wire Ignition Switch Table
The body control system consists of the following 2 modules:
• The Dash Integration Module (DIM)
• The Rear Integration Module (RIM)
Each of the 2 body control modules integrate a number of functional systems. Each module is connected to the class 2 serial data circuit, many of the control signals are implemented by class 2 messages.
Serial Data Messages
The modules that depend exclusively on serial data messages for power modes stay in the state dictated by the last valid PMM message until they can check for the engine run flag status on the serial data circuits. If the PMM fails, the modules monitor the serial data circuit for the engine run flag serial data. If the engine run flag serial data is True, indicating that the engine is running, the modules fail-safe to RUN. In this state the modules and their subsystems can support all operator requirements. If the engine run flag serial data is False, indicating that the engine is not running, the modules fail-safe to OFF-AWAKE. In this state the modules are constantly checking for a change status message on the serial data circuits and can respond to both local inputs and serial data inputs from other modules on the vehicle.
Discrete Ignition Signals
Those modules that have discrete ignition signal inputs also remain in the state dictated by the last valid PMM message received on the serial data circuits. They then check the state of their discrete ignition input to determine the current valid state. If the discrete ignition input is active, battery positive voltage, the modules will fail-safe to the RUN power mode. If the discrete ignition input is not active, open or 0 voltage, the modules will fail-safe to OFF-AWAKE. In this state the modules are constantly checking for a change status message on the serial data circuits and can respond to both local inputs and serial data inputs from other modules on the vehicle.
Honestly ,there is nothing you can do ! The dealer has the factory scan tool an service info. to diagnose this quickly . The only thing you would be able to do is guess as to what the problem is ,and it would be wrong .
Jun 05, 2017 | Cadillac Cars & Trucks
G 600
what is the brand and model of this phone. You didn't say about that.
basicly do you have the drivers and software installed?
Jun 10, 2008 | Cell Phones
What does u3101 class two short to battery mean
The code is U1301 not 3101 ! This is a code for the class 2 serial data bus , the modules on this vehicle all communicate , share information on this data bus ! If you don't know anything about multiplexing or data bus communications you need to take this to a pro who does !
Modules connected to the class 2 serial data circuit monitor for serial data communications during normal vehicle operation. Operating information and commands are exchanged among the modules. In addition to this, Node Alive (State of Health) messages are transmitted by each module on the class 2 serial data circuit about once every two seconds. When the module detects no messages and a high voltage on the class 2 serial data circuit for approximately three seconds, U1301 is set and the setting of all other class 2 serial communication DTCs is inhibited.
Feb 24, 2015 | Cars & Trucks
Spider 2 serial number
We don't deal with Serial number here. why don't you try some other website.
Aug 14, 2012 | ColorVision Spyder 2
No serial number for crysis 2,i can't plat it
Title: serial no of crysis2
At first check cd key in your DVD of Crysis 2. Just load the DVD and open it and find the "readme.txt". Hope so you get the cd key.
Otherwise within DVD any crack or key generator is present then open it and generate the key.
Or
You can download the serial key from the following link
http://www.filestube.com/c/crysis+2+serial+key
May 06, 2011 | Computers & Internet
Keycode for ford audio systems 3000 traffic 2 channel serial no.M127764 part no.97FP-18K876-LA...pls!!!!
Keycode for ford audio systems 3000 traffic 2 channel serial no.M016669 part no.97FP-18K876-NA...pls!!!!
Apr 06, 2011 | Car Audio & Video
Wat is the serial code ?
This is the link that will provide the serial information that you are requesting.
http://www.serialshack.com/serial/sims-2-season-mac-serial-number.html
Mar 27, 2011 | Sims 2 for Mac
Hello people I've a problem with my samsung sgh g600 I can not connect to the pc it does not connect her help me please
this worked for me ......
Unplug usb cable from phone
Type *#52828378# into phone
and this comes up
1 Trace setting
2 OTA type setting
3 Serial test
4 TFS reset
select 3 serial test
and this comes up
1 PPP UP
2 Serial download
3 Run TCK
Select 2 Serial download
The phone will reboot and once its rebooted connect usb cable and pc studio will work.
THANKS
Jun 29, 2010 | Nokia 6233 Cellular Phone
What ton is good man ckl 49 il where is the model number onthe furnace
ok ready for this? To find the tonnage look at the serial # Tonnage is related to 12's If there, on the serial # there is say 0062490 the tonnage is 24 or two tons 24 divided by 12 equals 2 Say the serial # contains 0063090 then the tonnage is 2 1/2 because of the 30 hopefully you see what I am saying the number in the serial # if it can be divided by 12 or 6 this is the tonnage. If you will send me the serial number I will tell you the tonnage. The serial number is on the outside unit at the copper connections where the electrical lines go in.
Good luck on your repairs hope this helped send me a note online here and if you need I will give you tonnage if you send the model # and serial number with your response> I will check online around 1500 hours on 1/9/10 central time. Remember to look for the numbers that are divisible by either 12 or 6 on the serial number
Dave
Jan 08, 2010 | Goodman CKL60AR60 Air Conditioner
Bias SoundSoap Pro 2 for PC, Mac Logo
49 people viewed this question
Top Bias Computers & Internet Experts
David Payne
David Payne
Are you a Bias Computer and Internet Expert? Answer questions, earn points and help others
