Question about Refrigerators
Kenmore coldspot refrigerator 50262990
What is the water filter replacement for this model?
peyton32034
  • 410 Answers
SOURCE: Kenmore refrigerator light does not work
there is a tab in the bottom of the light socket that can get bent so that it wont touch the base of the new bulb. unplug your refrig and use a small screw driver and bend the tab back out a little bit so that it will contact the new bulb...
Posted on Dec 12, 2007
  • 172 Answers
SOURCE: Kenmore Coldspot w/Ice Maker Not Making Ice
hi LOP7,
In most cases you can easily solve this problem.
step one would be to make sure your freezer is getting cold enough. If you have icecream in your freezer is it frozen solid or is it soft. Most icemakers cycle around 0 degrees and if your freezer is not getting to 0 then it will not cycle and it will not make ice.
Step two would be to make sure you icemake is cycling. To do this simply lift the little shut off arm on your icemaker and wait about an hour then go back to the icemaker and drop the arm down. The icemaker should start going through a cycle. You should notice the arm slowly begin to raise and the ice dispencer fingers will begin to turn. Then you will hear it call for water. You may hear a humm.
If the freezer is cold enough and the icemaker is cycling that only leaves the inlet valve. replace the valve and enjoy the ice.
If the freezer is cold enought and the icemaker does not cycle, then you have a bad icemaker. Simply replace the icemaker and viola.
Third if the freezer is not cold enought 0 defrees. Then you may have a defrost problem. In this case post more info and I will be happy to help. Good luck mca0824@aol.com
Posted on Apr 30, 2008
SOURCE: Water filter stuck on my Kenmore Fridge
I had the same problem. I coudn't get the knob to turn. I ended up taking the front grill off so I could get a better grip on the knob. Once I did that I still have to put a lot of pressure on the knob to turn it but that did the trick. When I got it turned a quarter turn then it was easy to pull the filter out. Hope this helps!
Posted on Jan 11, 2009
SOURCE: getting water
I have Kenmore Coldspot refreidgerator and am having a problem with water pooling inside the fridge at the bottom underneath the drawers (mostly the left side). Where is the water coming from and it formed a thin ice.
Thanks
Posted on Dec 22, 2009
SOURCE: kenmore side by side refrigerator
there is valve for each right at the water inlet, your valve is stuck or your coil is bad......get a new valve.
Kenmore coldspot 52582201- water filter part number
found it try here...
https://www.repairclinic.com/Shop-For-Parts/a4b6i183d605447/Model-10652582201-Kenmore-Refrigerator-Water-Filter-Parts
Jan 24, 2018 | Kenmore Refrigerators
Where is water filter located on kenmore coldspot model #52212100
contact sears parts to get a owner manual but filters are usually locate in line before the unit.
www.searspartsdirect.com
Sep 14, 2014 | Kenmore Refrigerators
Kenmore coldspot model: 106.74932400
Your fridge dose not have a water filter.
Aug 04, 2013 | Kenmore Refrigerators
Kenmore coldspot- 106 Model 9537654
The Kenmore Model 106.9537654 does not appear to have a water filter. Thanks Sea Breeze
Here is a PDF of the parts=> 106.9537654 Parts
Jul 15, 2013 | Kenmore Refrigerators
Kenmore Coldspot Model 51572200 is leaking water all over the floor
On the bottom rear of the refrigerator as you are looking at it from behind the left side where the water is feeding into there should be a double valve. 1 is for the water and the other to the icemaker. Many times that valve won't shut off, however the switch that dispenses the water is evidentially bad and needs to be checked if it is stuck open.
Jun 03, 2017 | Kenmore Side by Side Refrigerator
I have a leak inside my Kenmore Coldspot Model # 106 72104100. It is not coming from the icemaker.
If the water filter is old the seals will leak into the evaporative tray overflowing it. Replace the filter or give it a turn to bypass.
Jan 26, 2011 | Kenmore Refrigerators
What is the part number for the water filter for a Kenmore Coldspot refrigerator model 106.54209300?
The part number is 4392922 for the water filter. You can purchase this water filter at the below link for $ 34.49
http://www.freshwatersystems.com/p-3051-whirlpool-kitchenaid-deluxe-filter-4396510.aspx
FreshWaterSystems
1.877.335.3339
May 17, 2009 | Refrigerators
How often do I change the water filter
i cant even find a filter on your machine, if there is one, there will be a model number on the filter itself as well as re-order information.Once a yr , you shhould change
Dec 07, 2008 | Refrigerators
Refrigerators Logo
49 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
