Question about Kobo Vox K080-KBO-B Reader
Where is serial number on Kobo ereader? - Kobo Vox K080-KBO-B Reader
3 Suggested Answers
Justintechno
  • 36 Answers
SOURCE: my screen on my kobo
You will most likely need to buy a new one. I looked online for a replacement screen and I could not find one.
Posted on Jul 28, 2011
SOURCE: kobo ereader fell on floor just have a blank screen
the lcd backlight called a CCFL tube much like the stip lights
has becomes disjointed or has cracked
if the screen survived uncracked then its worth getting it looked at by someone who knows LCDCCFL and where to gain a replacement
Posted on Dec 21, 2014
My Kobo Aura is not recharging. The charging unit seems "dead". Can the charger be replaced?
it can
Kobo Aura / Aura HD compatible Advanced Rapid Wall AC Charger ...
https://www.amazon.ca/Kobo-compatible-Advanced-Rapid-Charger/.../B00GNB08JS
Gomadic Powerful High Wattage wall charger for home or travel use. Customized circuit design is based on the latest in power regulation and is tailored to the ...
Kobo Aura One Charger, BoxWave® [Wall Charger Direct] Wall Plug ...
https://www.amazon.ca/Kobo-Charger-BoxWave®-Direct-Touch/dp/B01MA3NLF8 Pwr+ 6.7 Ft 2A AC Adapter Rapid Charger for Kobo VOX eReader; Kobo Arc 7 10 HD; Kobo Touch Glo Mini Aura Hd Ebook Tablet.... ... HQRP Micro USB Charger / AC Adapter for Kobo Arc / Arc 7 / Arc 7HD / Arc 10HD / Mini / Glo / Touch / Aura / Aura HD / Vox.... ... Pwr+ 6.7 Ft 2A AC Adapter Rapid ...
Kobo eReader Glo USB Cable - Micro USB: Amazon.ca: Cell Phones ...
https://www.amazon.ca/Kobo-eReader-Glo-USB-Cable/dp/B00AXZVE48 Rating: 4.7 - ‎11 reviews
Kobo eReader Glo USB Cable - Micro USB: Amazon.ca: Cell Phones & Accessories. ... Cable for Kobo eReader Kobo Mini, Kobo Touch, Kobo Aura & Aura HD... ... Pwr+ 6.7 Ft 2A AC Adapter Rapid Charger for Kobo VOX eReader; Kobo Arc ...
Chargers & Cables - Electronics: 146 products available ' chapters ...
https://www.chapters.indigo.ca/en-ca/electronics/chargers-cables/500151-cat.html Results 1 - 24 of 146 - Shop Online at Chapters.Indigo.ca for a wide selection of chargers & cables products, 146 items available. Enjoy free shipping on orders ...
kobo aura charger Google Search
Sep 24, 2017 | Tablets & eReaders
Kobo frozen. Willl not respond to touching button
Performing a basic reset A basic reset will force your eReader to restart properly. In many cases, this is enough to restore your eReader to normal.
  1. If possible, turn off your eReader.
  2. Locate the small hole on the bottom of your eReader.
  3. Unfold a paperclip and slide an end into the hole.
  4. Press gently until you feel a click. Your eReader should restart.
Performing a factory reset If a basic reset doesn't work, you can perform a factory reset to restore your eReader to its original settings. After a factory reset, you'll have to set up and sync your eReader again.
If you perform a factory reset on your eReader, you'll:
  • Remove all books from your eReader. Any books you purchased from Kobo can be re-downloaded from the Kobo Cloud after a factory reset.
  • Lose any bookmarks and annotations you made in your books since you last synced your eReader.
  • Sign out of your account on your eReader.
  • Reset all of your settings and preferences.
  • Return your eReader to its original settings.
  1. If possible, back up any books or documents that you added to your eReader using Adobe Digital Editions, or that you manually added using your computer. You do not need to back up any books you bought from Kobo. Any books you purchased from Kobo can be re-downloaded from the Kobo Cloud after a factory reset.
  2. Go to your Home screen.
  3. Tap the ios-menu.svg Menu icon at the top of the screen.
    The Quick Settings panel will appear.
  4. Tap Settings.
  5. Tap Device information.
  6. Tap Factory Reset under Advanced.
  7. Performing a factory reset If a basic reset doesn't work, you can perform a factory reset to restore your eReader to its original settings. After a factory reset, you'll have to set up and sync your eReader again.
    4. Tap Settings.
kobo com help Resetting your Kobo Glo HD
Jun 30, 2016 | Kobo eReader
My kobo is frozen on starting sync won't turn on or off
Note: If your Kobo device has been physically damaged, it is no longer covered by Kobo's limited warranty. On a Kobo eReader, a physically damaged screen will look like it's been shattered, or you may see vertical or horizontal lines on the screen with a frozen image. If you haven't dropped or damaged your Kobo eReader, but are experiencing issues, try the steps below in the order suggested.
  • Turn your eReader off and then on again.
  • If your screen is frozen, slide the power button to the right and hold it for 10 seconds. Your eReader should turn off.
  • Turn your eReader off and charge it for at least four hours. Note: Your computer should be turned on while you are charging your Kobo eReader.
  • If your eReader isn't charging, try using a different Micro USB cable or a different USB port on your computer. Note: If your eReader's battery is completely drained it can take up to 15 minutes before it reacts to being plugged into power.
  • If you're having trouble while reading a book on your Kobo Aura H2O, Kobo Aura, Kobo Aura HD, Kobo Glo, or Kobo Mini: tap the centre of the screen to bring up the Reading Menu, tap the > Home icon to return to your Home screen, then open your book again.
  • If you're having trouble while reading a book on your Kobo Touch: press the Home button and open your book again.
  • Try a basic reset.
  • If you're still having issues, consider a factory reset.
  • If you're unable to reset your device, please contact Kobo Customer Care
Mar 14, 2015 | Kobo 6" eReader Touch Edition
Kobo plugged into computer but nothing happens when I press connect
Do you have the proper device driver installed on the computer?
:Other info I found online, but have not looked into:
Open the Hardware and Devices troubleshooter
http://windows.microsoft.com/en-us/windows7/Open-the-Hardware-and-Devices-troubleshooter
In addition you can also check if the device manufacturer have driver for the device.
For additional help, please see:
Kobo Help Forums/Frequently Asked Questions - Kobo eReader
http://kobo.zendesk.com/forums/165796-frequently-asked-questions-kobo-ereader
Need help with your Kobo eReader?
http://koboereader.com/FAQ
Feb 24, 2015 | Kobo 6" eReader Touch Edition
Kobo ereader problems
Unfortunately, the batteries on Kobo were not designed to be replaced. If the batteries will no longer accept a charge, it is time for a new e-reader.
Aug 14, 2014 | Kobo 6" eReader Touch Edition
How to find my mac address on my kobo touch ereader?
that is the mac address.. remove the period (.) and add colon (:) after every 2 characters
Aug 06, 2014 | Kobo 6" eReader Touch Edition
Where do I find the KOBO desktop
The Kobo eReader is a portable device that lets you read digitized books.
Downloading the eReader is physically impossible.
However, Kobo Desktop is available on the Kobo website.
This application will let you read and buy Kobo eBooks with a computer.
Use the desktop application for transferring purchased eBooks to your eReader.
The download and installation will not take more than two or three minutes.
Open an Internet browser.
Type "kobobooks.com/desktop" in the browser's Address bar, then press the "Enter" key to load the page.
Click the "Download App!" button and the download begins.
Double click the "Kobosetup" file, when the download completes, to launch the Kobo Setup screen.
Click the "Yes" button after the User Account Control dialog box appears.
Click the "Install" button after the Windows Security dialog box appears.
Click the "Next" button after the Kobo Setup installation completes.
Click the "Finish" button to exit the Kobo Setup screen.
http://kobobooks.com/desktop
May 12, 2013 | Computers & Internet
Kobo Vox K080-KBO-B Reader Logo
766 people viewed this question
Top Kobo Cameras Experts
Are you a Kobo Camera Expert? Answer questions, earn points and help others
