Question about Nordic Track Exercise & Fitness
Replace control board
Works, but walked into the room and heard a clicking....
    Top Expert:
  • Nordic Track Master
  • 12,223 Answers
See this The most likely cause of the problem is a worn treadmill belt and deck.
Most of the time its caused from not lubricating between the treadmill belt and deck. This causes friction and the surfaces wear putting greater stress on the electronics. The treadmill is shutting down to protect the electronics. You should stop using the treadmill and have a technician check it.
If it sounds like metal rotating on metal then it could be roller bearings or motor bearings. Its best to have the treadmill work carried out by a technician in the workshop. Most of the time the bearings will have to be pressed out and the new ones pressed in
God bless youreplace control board - 8d7fefa3-581c-4fc8-b04d-348b3e584661.gif
Posted on Jul 17, 2013
Bauhn ATV50FHD3 no picture has sound no lights at back. I heard tv going on and off several times went to tv picture black only sound hubby testing his remote control power switch has he killed my tv
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement.
Nov 26, 2015 | Televison & Video
It just doesn't turn on now. Was working fine.
Motor control board has probably died. May have been due to a worn walking belt so if you replace the motor control board, make sure you dont need to replace the walking belt.
Oct 28, 2015 | Exercise & Fitness
I have a Kenmore Elite Front load washing machine, the control panel has no lights going to it
Perhaps a good spraying with contct cleaner will FIX it at least for awhile .
Dec 31, 2014 | Kenmore Washing Machines
No audio
The main board has an issue and will need replacement. You should be able to get a replacement main board from www.tvrepairworld.com
Mar 03, 2012 | Samsung LN40B630 40 in. LCD TV
Proform tredmill---stops after a couple of steps--will start back up after getting off---motor control board?
Inspect the walking board and belt first.Feel the tecture at the outer edge of the belt, then feel the center. If it feel fuzzy, the walking belt is worn.
Check the walking board for damage, deep scratches, excessive friction will cause an over current shutdown of the controller.
If the walking belt and board are good, lubricate the walking board and belt and try again.
Does the motor spark allot when running?? This will also cause over current.
Have you tightened the belt (too tight??)
After covering these suggestions, if the same problem is apparent, change the motor controller..
Dec 16, 2010 | Proform 755cs Treadmill Motor Control...
The overhead lights on my Liftmaster Garage Door opener stopped working. I have read many other posts similar to this.... so, please read my specific question at the end of this post. I replaced both...
I just ran into the same problem on my Liftmaster 2265R. Identical symptoms, but I haven't attempted any remedies with the bulb sockets yet. I shot an e-mail off to Chamberlain's tech support people. I'll post again if I get an answer from them or discover a solution. Please do the same if you find something. Thanks.
Rob
Oct 17, 2010 | Sears Craftsman LiftMaster Chamberlain...
No power working fine walk out of room come back
If you want to repair, you will have to take it apart. The fault is the power supply. after you take it apart look for cap with the tops bluging. if you want post an picture of the power supply board..
Feb 23, 2010 | Proview Computers & Internet
Kenmore electric range: oven & broiler will not work.
All your oven features are controlled by the Electronic Range Control (ERC) board. This is your clock/timer assembly. Unfortunately, most do not have fuses and are not serviceable. You will probably need to replace the board. The following link explains how:
http://www.fixya.com/support/r3727366-replacing_control_kitchen_range
Replacement circuit boards can be purchased on line at any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
Prices vary between these sites, so shop and compare. For the model number you have listed, the part number for a new board is 316207511.
NOTE: The overlay, which is the plastic template with the numbers and letters preprinted on it, does not come with the new board. It has to be purchased seperately. However, if the current overly is still in good shape, it can be peeled off the old circuit board and reused. The part number (if required) is 316220841.
If you have questions about this repair, please post back and let me know. I hope this helps you.
Jan 21, 2010 | Kitchen Ranges
Have a wd2500js drive that the comp won't recognize and am looking for the drive board to swap so i can tell if it is the drive or board....where can i get that board?
Am I a guess the Board that you are Referring to is a New Motherboard. I have never heard of a Drive Board.
Are you Build a New Computer?
If not and you are just adding a New Drive to a Working Computer, Your Drive may not be Initialized yet. Please attach the Drive to your Computer, Start you Computer, Click on Start, RIGHT CLICK on My Computer, LEFT CLICK on Manage.
Toward the Bottom of this window you will see Disk Management. When you click on this, the Initialization Process will Start. Just walk through the Prompts. When completed, your Computer will recognize the New Drive.
Dec 22, 2009 | Western Digital WD2500JS 250GB SATA2...
Exercise & Fitness Logo
62 people viewed this question
Top Nordic Track Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Electro Med Services...
Paul Sikkema
Paul Sikkema
Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
