Question about Canon EOS 50D Digital Camera
How to change the fuse on canon camera
Wont turn on
My camera wont turn on i belive it a fuse were is the fuse on camera is it a easy job
No fuses in a camera. Check the battery first to determine if it is fully charged. THen check the contact points on the battery and in the camera. ALSO....be sure you are putting the battery in correctly.
Oct 03, 2014 | Cameras
Canon sx120is fell while taking photos it went off with the lens retracted and it wont turn on
that is definitely the problem with the len,the len is stucked can not change freely.change the len or send to the camera repair center.
http://www.skiliwah.cn/
http://www.digitalcamera-parts.net/
e-mail:e-8090team@hotmail.com
Oct 12, 2011 | Canon PowerShot SX120 IS Digital Camera
Camera wont turn on
If you bought the camera in January, it's still under warranty for a year. When you get home call 1-800-OK-CANON to arrange warranty repair. They're usually very good about it, and will try to make things right.
May 29, 2009 | Canon PowerShot SD950 IS Digital Camera
Canon G10 wont turn on
Try removing the card first and then trying to power up the camera. Cameras often fail to turn on/off when a card goes faulty. Next I would try pushing the playback button, it also acts as a power button but starts the camera in playback mode. If this works it could indicate a problem with the power switch circuit itself. If there is still no sign of life I would suspect a fuse to have blown. They are internally located and very small, you would need to have a service centre try replace it for you. Good Luck!
Apr 13, 2009 | Canon PowerShot G10 Digital Camera
Cannon Digital Rebel xt died will not turn on , recharged nothing
I think you have a faulty fuse (there are three in total) inside the camera. The fuse might have blown because of bent pin for the memory cards or a faulty cf card. In wich case, you have to repair it yourself, there are pages on the web that describe what you have to do (search for fuse and 350d), or send it to a canon service center ( they will change the complete motherboard because the fuses are soldered to the mainboard and they won't change them)
Sorry budddy
Jan 22, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Canon Powershot PD630 will not turn on!
Hi
Either the fuse has blown or there is another problem with the main PCB or possibly the battery door indicator switch.
Open the battery door, by the memory card slot is a tiny switch; is the black tab for the switch still there or is it broken off and missing? Is it jammed down? Try holding the switch down with a pencil and press the power button... does it work?
If it doesnt seem to be the switch, it's probably the fuse. If you can solder well you can probably replace it yourself, and I will get the fuses tracked down and listed in the store so they are available to anyone who needs them.. they are cheap!
We are a digital camera repair business, if we can help please let us know! Good luck from Darntoothysam com
Thomas
Darntoothysam com
Oct 29, 2008 | Canon PowerShot SD630 Digital ELPH / IXUS...
My canon zr400 wont turn on
ITs most likely a fuse, unfortunately you can change it or its a son of a gun to change. You can check by removing the motherboard, locate the fuse, they are micro fuses, it either has the letter H or K etched on it, there could be anywhere from 1-5 of those fuses. Check for continuity if that s the problem than replace it, if you cant find a replacement micro fuse than solder over the fuse for continuity...that should make the camcorder power on, but beware once you solder over the fuse- there will be no more current protection for the camcorder. If the fuse is not the problem than it could be a loose circuit...
Feb 22, 2008 | Canon ZR400 Mini DV Digital Camcorder
300D doesn't turn on at all.
Here are some simple things to try first for a camera that won't power on. They won't work for every case, but they're worth a try:
http://camerarepair.blogspot.com/2007/11/simple-fix-for-dead-cameras-that-wont.html
Jan 02, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Canon EOS 50D Digital Camera Logo
74 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
