On the Archos:
In the settings menu from the front screen, set your Archos to 'PC Hard Drive' instead of Windows Media Player. If it doesn't show as an external hard drive when you plug it into your pc, do this....
On the pc:
Go to Start\run, type diskmgmt.msc and click ok to take you into Disk Management. Your Archos should show as a drive in here and you can associate your new drive with a drive letter.
If you cannot see your Archos in this windowafter you've set it to 'PC Hard Drive' on the Archos, then you may have a dodgy usb cable.
You should be on firmware version 2.1.04 (WMDRMPD:10.1) If connected to your computeer or on WiFi then :-
Main Screen
Menu
Settings
Firmware + Plugins
and click on....Online Firmware Update
This version of the firmware does allow some videos. Unfortunately if the videos come up with blank screen with a red F9 in the middle this signifies a version of FlashPlayer not yet supported. We just have to wait and see if Archos are still going to support the 605 with more firmware updates or if their hands fare too ull with the new Archos 5 Android.
This may work but it may not my Archos use to do something like that too. What you do is when it comes on press the on but again but not hard or long enough for it to shut down and tap the screen do this reaptedly untill you see the red light start to flas reaptedly really quickly without stop then it will stop and flash two or three more times untill you see your screen come up oh nd next time dont full shutdown just suspend it it is easier and it doesnt take up battery life either.
then i upgraded to Archos 605 Wifi (20GB-160GB) OS v 2.1.04 heres the link for 2.0.10 http://update.archos.com/5/a605/a605_r2.0.10/firmware_a605.aos and heres the link for 2.1.04 http://update.archos.com/5/a605/a605_r2.1.04/firmware_a605.aos
This can happen to any external drive on a pc. If the Archos is set to PC Hard Drive mode, then plug it into you PC and click Start, click Run, type compmgmt.msc, and then click OK. In the console tree, click Disk Management. You can now allocate a drive letter to the Archos. If you cannot see your Archos in this window, then you may have a dodgey usb cable.
A couple things to note. First. Make sure the files are the right format. second, make sure they are in the music folder. third... sometimes it won't read them. you can still play them here's how:
Go on your archos go to music, than at the bottom click on hard drive.... you can play everything there.... i recommend not synching it... but dragging and dropping them in by hand... i like doing things basic...
after reseting my archos 605 my touch screen has stoped functioning properly i youch 1 part of the screen and it keep going to my menu bar i hit video it will open the menu bar or any part of the screen i touch it opens the menu bar
I was having a similar problem where my 160 gb Archos 605 would not hold a charge even after two days of being plugged in through an AC wall adapter. It worked fine for 5 months without a problem, but then all of the sudden it would not hold a charge even if the LED light was blinking green.
One thing that I found that makes it now hold a charge now is by letting is by plugging it in to a computer. I don't know why, but for some reason, now when I charge it through a computer usb as opposed to the wall adapter, it charges and holds a chrage for over 3 hours. So, maybe try to just let the thing charge through a computer.
Contact Archos support and they can provide you the file to repair your disk. Once you have the file stored on your computer, you will then hook up your Archos via USB and copy the file they provide you to the root of the Archos. The direction I got when trying to fix my pop/hissing "If you power on the unit by pressing and holding the TV/LCD button and power button simultaneously the unit will boot into a recovery screen. Once in this screen choose "Repair Disk" and follow the on screen instructions.
When prompted, please place the following file into the 'root directory' of the unit:
