Question about Rockford Fosgate Punch P5002 Car Audio Amplifier
Amp arc i would love somebody's help with the trouble i'm having with my punch 5002 amplifier. when i hook it up it gets power but won't get any sound. wait it gets better. i checked all the connections and wiring, which is all good. i then pulled the speaker wire out of the sub. while removing them i got very brief sound. that prpted me to check the sub connections and the speaker connections on the amp. as far as i can tell, there is nothing wrong there either. if i try to hook up the ground speaker wire while the amp has power it arcs. why is it doing this!!!!! tell me!!! please!!! thanks, ruff
  • j doggy dawg Aug 29, 2007
    whats up guys? i would really appreciate some help here. do you think there is something wrong with the speaker terminals, or could it be the amp ground?
    Genius:
  • 1,139 Answers
What you need to do is first ground your amplifier securely then make sure all connections are fastened. don't remove the speaker connection and listen for sound. If there is no sound power down the unit, and send it to a repair shop because it sound like you may have damaged some components in the unit. But in order to come to this point you have to make sure you ground the unit properly and then make sure all of your connections are secure. Contact me once this is done and you are ready to do some tests.
Posted on Sep 03, 2007
I just bought a punch 500 a2 amp. i hook up my ground, then try to hook up the power cable and it sparks. my punch 250 was hooked up minutes prior to this so i know my wiring is good. what the heck is the...
The spark could be from the capacitors in the amplifier charging. Make sure the main fuse from your battery is still good and also check all the fuses on the amplifier. Verify all the wiring is correct and make sure none of the wires from inside the positive cable are poking out and touching the vehicle or amplifier chassis. If you have a 1k ohm resistor, you can put it in series with the amplifier power line to slowly charge the capacitors. You can do that by following the directions from the link below. After doing all that, remove the 1k resistor, hook it all up and try it again. If it still doesn't work, make sure your remote wire coming from the head unit has a voltage on it when the head unit is on. You can get a cheap volt meter from a hardware store or wal-mart.
http://www.ehow.com/how_7203337_charge-capacitor-car-stereo-system.html
May 21, 2011 | Rockford Fosgate Punch 500a2 Car Audio...
I have a rockford fosgate punch P325.1 subwoofer mono amp that blows a fuse every time i start the car. I have a second pioneer amp but that works with no problems. How can i fix this?
Is it the correct size fuse ? Is it the power fuse or remote ? Either way check your connections going into the amp . Try this hook your other amp to the set of wires for the rockford if that amp has a problem its a wireing problem if not chances are its an interal problem on the rockford . Hope this helps !
Aug 19, 2010 | Rockford Fosgate Punch P325.1 Subwoofer...
When i hook up the sub to the amp there's no sound
check the wires and the gain and volume nobs on the amp
Dec 20, 2009 | Rockford Fosgate Punch 501S Car Audio...
Adcom GFA-5002 is dead no lights, no anything
Check the Fuse. Unplug the AC first. If you replace the fuse and it blows again, disconnect all speakers, replace the fuse and turn on. If the fuse does not blow, chances are it is a speaker problem, Adcom builds some very solid product, I would suggest pulling the outdoor speakers and testing them.
Depending on what you are using, some outdoor speakers should never be taken out of the living room. If you still have an issue post a comment and I will help some more.
Jun 24, 2009 | Adcom GFA-5002 Amplifier
Is it enough to power to 12 volge=ahagen 12oowatss dual 4 ohms
your Volfenhag 12" subs are rated at 1200 watts they are only 600 watts rms and the Rockford punch p4004 is only 200 watts rms so the answer is yes it will work but if you get a amplifier that pushes out 500 - 600 watts rms you will love the sound from subs
there is nothing wrong with the Rockford amp it just wont pound out the bass as hard but the good news is you will never blow the subs with it
when buying amps or subs make sure to look at rms rating that is the true power they actually have ie. (sub box says 1200 watt you think powerful but if you divide it in 1/2 you actually get 600 watts rms) don't get me wrong that's a nice rating. for a sub but you will want to match that number with the amps rms rating or lower. The RMS is what makes the car pound the higher the RMS the better
hope this helps
Mar 05, 2009 | Rockford Fosgate Punch P4004 Car Audio...
Rockford fosgate punch 700s gets very hot
Disconnect the speaker wires from speaker terminals on the amp and turn the amp on (turn the head unit on). Set the volume to zero on the head unit.
Does the amp get hot?
If it does, either the bias is set to high or the amp has other problems. If it does not, you may have the speakers wired to the wrong ohm load.
Nov 03, 2008 | Rockford Fosgate Punch 700S Car Audio...
Will not power
Yeah my guess without seeing it is that you did fry your amp. You really need to hook up two fuses inline on your power feed; one no farther than 18" from you battery and one inline at you amp.
Jun 25, 2008 | Rockford Fosgate Punch 301S Car Audio...
Hooked my punch Punch P450.4 up to speakers and ran rca cables to front and it wont work
Hi Jon,  you need to hook the Remote wire up to the Radios  Blue remote wire.  The car battery power stays on all the time.  The blue Remote wire watches to see when the radio turns on, and signal the amp to turn on as well.
Dec 12, 2006 | Rockford Fosgate Punch P450.4 60W x 4 Car...
Rockford Fosgate Punch P5002 Car Audio Amplifier Logo
78 people viewed this question
Top Rockford Fosgate Car Audio & Video Experts
seankane89
Level 1 Expert
hoyzee1
Robert Rankin
Are you a Rockford Fosgate Car Audio and Video Expert? Answer questions, earn points and help others
