Question about American Standard Home
How to replace diverter valve in Qurtro R437SS
3 Suggested Answers
heatman101
  • 43501 Answers
SOURCE: how to replace diverter valve model 7901 bissell pro heat steam
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
g,hk
Posted on Sep 30, 2010
ercupa190
  • 12223 Answers
SOURCE: How can I replace a diverter valve?
go and download www.fitness.manualsonline.com or www. retrevo.com
God bless you
Posted on Jun 22, 2012
How do you replace the diverter
You have probably replaced your diverter valve by now. I purchased a new valve for about $14.00. It took me about 30 minutes of swearing under the sink to replace it. See instructions on the Price Pfister web site. See the video about cleaning the diverter valve.
Aug 06, 2014 | Price Pfister Plumbing
Water pumps out instead of recirculating?
It's not your wires faulty.
Is the valve installed the right way.
When diverter valve is powered will pump water over bowl.
Your motor controller board may be faulty,
And need diverter driver parts replaced.
Set you machine to Traditional wash only to bypass
Eco active filling that users diverter valve.
Jul 08, 2013 | Fisher and Paykel GWL11 Top Load Washer
Pumps out instead of recirculating
Jul 08, 2013 | Fisher and Paykel Fisher Paykel Intuitive...
Error code 52
51. (00110011) Phase 5 ECO - Recirculation Fault
The product has detected that it is losing water during recirculation.
Primary Source - Diverter Valve Wiring
Action - Check diverter valve harness is correctly fastened to diverter valve. Check flying lead
in motor controller, and connection to valve next to drain pump.
Secondary Source - Diverter Valve
Action - Check diverter valve resistance. If open circuit (nominal is 1500 ohms) replace
diverter valve. During recirculation, check that water is being recirculated back into the bowl,
and that no water is coming out of drain hose. If there is some water coming from the drain
hose, then the diverter valve could be faulty, or it could be jammed with a foreign object.
Replace diverter valve.
Tertiary Source - Motor Controller
Action - The diverter valve drive circuit may be at fault. If the primary and secondary checks
pass inspection then replace the Motor Controller.
52. (00110100) Phase 5 ECO - Recirculation Fault
See fault code 51.
Apr 02, 2013 | Fisher and Paykel GWL11 Top Load Washer
I replaced a spider gasket on my PAC FAB 2# Multiport valve and when I put it back together the sequence is off. Filter mark is actually the waste port and waste is actually the Filter port.... how do you...
There should be a screw hole in the valve lid that has a flat edge on one side (outside edge). The valve body has a matching flat edge that aligns with it.
In the event the handle was removed from the lid and diverter to replace the diverter o-rings it is not uncommon for people to put the handle back on the diverter 180 degrees of where it should be. The pointer on the handle should be aligned above the open port of the diverter. This is true of all multiport valves except the Hayward four way valve.
Dec 06, 2012 | Pentair Pac-Fab 2" DE Filter Multiport...
I washed a rug and now the machine is not draining the water.
The drain pump has been block and it requires cleaning including the diverter valve. Disconnect power then lay the machine on its front on a cushioned surface to access the drain pump and the diverter valve at the bottom of the tub. Remove the inlet and outlet hoses of the drain pump and the diverter valve and clear any debris that is blocking the flow of water and preventing it from draining out. Check the impeller of the drain pump and make sure it is not blocked, restricted or damaged.
Also check the diverter valve for the same condition as the pump described above. The diverter valve is where the drain pump and the recirculation pump inlet hoses are attached from. Make sure it is in the drain position while the drain pump is working. Replace the drain pump and/or the diverter valve if deemed necessary.
Jun 18, 2011 | Fisher and Paykel GWL11 Top Load Washer
I am getting service code 37, what does that mean and how can I fix it?
It's error code 37 and it means pump blocked error. Either the drain hose is clogged or kinked, the diverter valve has failed, or the pump itself is restricted or not working at all. Check to make sure that the drain hose is clear then disconnect power and lay the machine on its front on a cushioned surface to access the drain pump and the diverter valve. Remove the pump's inlet and outlet hoses then check and clear them from any debris that may prevent water from draining out. Check the impeller for any damage or restriction. Make sure the impeller is not frozen or blocked.
Check the diverter valve for the same condition as the pump described above. The diverter valve is where the drain pump and the recirculation pump inlet hoses are attached from. Make sure the diverter valve is in the drain position while the drain pump is working. Replace the drain pump and/or the diverter valve if deemed necessary.
Dec 30, 2010 | Fisher and Paykel IWL12 Top Load Washer
What does fault code 51 mean?
Error code 51 usually means a faulty diverter valve. Try and run a wash cycle, and observe the drain hose. If water comes out, the diverter valve should be fine, if no water comes out you should take your diverter valve out and check for debris, or continue to read through the following possibilities of why your washing machine is acting up, and the actions to take.
1. Diverter valve
Action - Check diverter valve continuity. If open circuit, replace diverter valve.
2. Motor Controller Board (drive circuitry blown).
Action - Replace Motor Controller Board
3. Diverter valve harness/connectors.
Action - Replace wiring harness
Jul 13, 2010 | Fisher and Paykel GWL11 Top Load Washer
Home Logo
99 people viewed this question
Top American Standard Home Experts
Donni Steen
Mike
john h
Are you an American Standard Home Expert? Answer questions, earn points and help others
