Question about Garden
Excell EXHA2425 Pressure washer pump cover removal
How to remove the pump cover in order to get to the pump?
  • 104 Answers
SOURCE: no pump pressure
Sounds like the diaphragm in the pump unit has failed, the engine and the pump are two seperate things the engine only operates the pump but if the diaphragm is leaking or broken you wont get any pressure
Posted on May 23, 2009
SOURCE: Karcher K 2400 HH Pressure Washer no pressure
http://www.landanorthwest.com/documents/instructional/spill_valve_instructions.pdf
Posted on Jun 05, 2009
SOURCE: Honda excell pressure washer does not have pressure
if the machine is running on suction, ie sucking out of a barrel there may be an air leak on the suction hose or pump. it will pull air easier than pulling water .
put the machine under mains water pressure, hose pipe straight from tap to pump.
check all around the pump and inlet pipes for leaks.
if water leaking this needs rectifiying for it to work on suction.
run the pressure washer while on mains pressure with the hose on, does this make a difference?
if not then probably the unloader is stuck in the pump head. remove unloader , clean and replace it
parts breakdowns are available on the internet for your machine.
possibly valves stuck, or the valve springs have broken, seen this quite few times on these machines. if so replace springs .
These sort of machines do not last very long anyway, about 50 hours use if your lucky.
Posted on Jul 22, 2009
  • 583 Answers
SOURCE: excell vr2500 pressure washer ,no pressure
check the water filter ---high pressurehose must have bbackpressure to develop pressure so disconecting it wont acheive ,much ,if you have agood water supply ,oil in the pump--- adjust pressure by srewing the brass fitting that the pressure hose attachesto, down that is clock wise a couple of turns or so and see if that makes a difference if not seals in the pumpmay be gone tha t should show by water in the oil
Posted on Jul 30, 2009
  • 68 Answers
SOURCE: I want to remove the 4gpm pump on my pressure washer.
HI, It sounds like it is just stuck on the keyway as these can be very tight. You need to force the pump of evenly on either side and should come of if patient.
Posted on Feb 08, 2010
Testimonial: "I'm sure the answer is correct. Over time my use of harsh chemicals no doubt corroded the key-way."
Need to remove pump on LG WM2701H washer
To get to the pump you need to remove the top plate, control panel and front cover in that order. for the front cover open the lid at the bottom left side and remove screws.
May 01, 2014 | LG WM-2277HW Front Load Washer
How to clean pump from fisher & pkal smart drive 708
FIRST - remove plug from wall, then open lid and remove the rubber bungs that the front of the lid sits on, under them is 2 screws, remove them. Lift the complete upper plastic portion and rotate back against the wall. Remove the screw from inside the agitator and remove the agitator completly. Remove the bowl top cover by unclipping it from around the outer edge all the way round, note the spring position for refitting, lift out the bowl top cover and set aside. Remove bowl, can be tricky but it should lift right out. With the bowl removed, remove the large phillips screw from the plastic cover over the pump, with the screw removed, the pump cover will pull out (up) and the pump can be cleaned out.
Make sure that you clean out the channels that the water flows through around the pump impellor. refit the pump cover, ensure the rubber ring is in correct position, and secure with the screw. Reassemble in reverse order.
Test the pump for operation before doing a full load.
Mar 02, 2011 | Fisher and Paykel Fisher & Paykel Washer
To replace the fuel filter?
Hello aperez657: My name is Roger and I will help you. The vehicle has only one fuel filter. The filter is part of the fuel pump assembly. To replace the filter you will need to remove the fuel pump from the fuel tank.You can remove the pump with out dropping the fuel tank. It is a chore though. (1) You need to disconnect the battery. (2) Remove the front seats.(3) Remove the front scuff plates.(4) Remove the rear scuff plates.(5) Remove the lower console cover.(6) Loosen the park brake lever bolts.(7) Partially peel back the carpeting until the service hole covering appears. (8) Remove the following in this order. (1) Service hole cover (2) Electrical connector (3) Disconnect plastic fuel lines (4) Remove fuel pump bolts. Reverse procedures to reinstall the pump.
Feb 02, 2011 | 2001 Mazda MPV
How to replace a waterpump on a 2001 olds alero 2.4 cam
Water pump is driven by timing chain idler and is mounted on the rear of the timing chain housing. Disconnect the neg. battery cable. Drain cooling system. Disconnect oxygen sensor connector.
Remove upper exhaust manifould heat sheild. Remove exhaust manifold brace. Remove lower exhaust manifold heat sheild. Loosen manifold to exhaust manifold spring loaded nuts. Remove radiator outlet pipe to water pump coverbolts. Disconnect exhaust pipe from manifold.
Pull down on the exhaust pipe to disconnect it from exhaust manifold bolts. Disconnect outlet pipe from oil pan and transaxle. If equipped with manual tranaxle, remove exhaust maifold brace. Leave lower radiator hose attached and pull down on radiator out look pipe to disengauge from water pump. Leave outlet pipe hanging.
Lower vehicle. Remove exhaustmanifold to cylinder head nuts. Remove exhaust manifold to cylinder head nuts. Remove manifould. Remove timing chain front cover. Remove timing chain tensioner. Remove bolts bolts securing water pump cover to cylinder block. Remove water pump to timing chain housing nuts. Remove water pump attaching nuts. Remove water pump and cover assembly. Separate componets as necessary.
WHEN INSTALLING WATER PUMP MAKE SURE YOU FOLLOW THE TIGHTENING SEQUENCES THAT AFFECT SEALING. My frist one I messed up and broke the pump so becarful.
Installation
If cover was separated from body during removal, join this componets with a new gasket and hand tighten bolts. Apply bearing grease to splines of water pump drive. Set body and assemble into position.
Install and hand tighten bolts securing cover to cylinder block. Install and hand tighten bolts securing cover to cylinder block. Installand hand tighten nuts securing body to timing chain housing. Lubracate outlet pipe "O" ring with antifreeze. (I use RTV) Connect outlet pipe. Install and hand tighten bolts. Tighten bolts and nuts to specification in the following sequence. I'll ad the torque spec. at the end but this is where if you tighten out of order something will break.
pump assembly to timing chain housing nuts.
pump cover to pump body bolts
pump cover to cylinder block bolts (Bottom Bolt First)
outlet pipe to cover bolts
To complete installation reverse removel procedure.
Torque specs are 19 in. or 26mm all except water pump cover bolts which are 124 in or 14Nm
I never torque the bolts just make sure there done in the right order.
Oct 19, 2010 | Oldsmobile Alero Cars & Trucks
How do you chace a oil pump on a honda goldwing 1200 cc
There are two oil pumps; the Main Oil Pump and the Scavenger Oil Pump. I will list the procedure for both pumps.
Main Oil Pump
1) Put the bike up on the center stand
2) Remove the engine front cover
3) Remove the collar and O-ring seals from the oil pump cover
4) Remove the bolts and Phillips screws holding the oil pump cover on and remove the cover
5) Remove the dowel pins from the oil pump body
6) Remove the inner and outer rotors
7) Remove the drive pin and washer from the drive shaft and remove the oil pump body from the cylinder block - The drive shaft will remain in the cylinder block. (Do not lose the locating dowel in the cylinder block).
8) Clean all parts before replacing the new oil pump
9) Install in reverse order
NOTE: If it is necessary to remove the oil pump drive shaft, the cylinder block will have to be disassembled. Also it is a good idea to coat all parts with oil prior to installing the new pump.
Scavenger Oil Pump
1) Remove the engine from the frame
2) Remove the engine read cover
3) Remove the clutch outer housing
4) Remove the bolts holding the oil pump to the cylinder block and remove the pump
NOTE: Both of these pumps can be rebuilt with fairly easy and it's considerably less expensive to do so.
Sep 21, 2010 | 1984 Honda GL 1200 Aspencade Gold Wing
Change oil pump from engine
THE 3.0 ENGINE YOU HAVE TO REMOVE THE UPPER INTAKE MANIFOLD .REMOVE VALVE COVERS REMOVE ACESSORY DRIVE BELT.REMOVE THE POWER STEERING PUMP.REMOVE ALTERNATOR REMOVE WATER PUMP .REMOVE AC COMPRESSOR AND BRACKET .REMOVE CRANKSHAFT PULLEY REMOVE OIL PAN REMOVE OIL PUMP SCREEN AND THE TUBE REMOVE FRONT COVER REMOVE TIMING CHAINS REMOVE CRANKSHAFT TIMING GEARS REMOVE OIL PUMP.WHEN INSTALLING NEW OIL PUMP AND OIL PUMP SCREEN AND TUBE TORQUE BOTH 89 INCH POUNDS. THE 3.9 ENGINE REMOVE THE CRANKSHAFT PULLEY REMOVE FRONT COVER REMOVE THE PRIMARY TIMING CHAINS REMOVE OIL PUMP MOUNTING BOLTS REMOVE OIL PUMP.INSTALLING NEW OIL PUMP TORQUE BOLTS TO 53 INCH POUNDS. WARNING YOU NEED A REPAIR MANUAL IN ORDER TO RELINE TIMING MARKS ON CAMSHAFTS AND CRANKSHAFT.
Apr 22, 2010 | 1997 Lincoln Continental
I need to replace the oil pump in my 2004 vw tdi sport
WELL ALL YOU HAVE TO DO IS.REMOVE OIL PAN.THEN MOUNTING BOLTS.AND LOWER THE PUMP FROM THE ENGINE.BOTTOM COVER AND DISASSEMBLE THE PUMP.THE PRESSURE RELIEF VALVE IS IN THE BOTTOM COVER.AFTER REASSEMBLING THE PUMP PRIME IT WITH OIL.AND INSTALL IT IN REVERSE ORDER OF REMOVAL OBSERVE THE FOLLOWING VALUES.OIL PUMP BOTTOM COVER BOLTS 84 INCH LBS.OIL PUMP SUCTION FOOT BOLTS 84 INCH LBS.OIL PUMP RETAINING BOLTS 18 FT LBS.
Apr 20, 2010 | 2004 Volkswagen Jetta
Change water pump on 1999 Century Buick
GM Century/Lumina/Grand Prix/Intrigue 1997-2000 Water Pump - REMOVAL & INSTALLATION
3.1L and 3.4L (VIN E) Engines
  1. Disconnect the negative battery cable.
  2. Partially drain the cooling system into a suitable container.
  3. Remove the drive belt guard.
  4. Loosen the water pump pulley bolts before removing the drive belt. This should help keep the pulley from turning as the bolts are loosened.
  5. Remove the drive belt. Please see .
  6. Remove the water pump pulley bolts and remove the pulley.
  7. Remove the water pump bolts and separate the pump from the engine front cover.
To install:
Fig. Exploded view of the water pump and front cover arrangement-3.1L and 3.4L (VIN E) engines
  1. Clean all parts well. Use care when scraping gasket material from the front cover and the pump. Do not gouge aluminum parts. Clean the bolt threads well. The torque specification is low and if the bolt threads are dirty, an accurate torque is not possible and leaks are likely to develop.
  2. Using a new gasket, install the water pump to the front cover. Install the cleaned and lightly lubricated water pump bolts. Torque to 89 inch lbs. (10 Nm).
  3. Install the water pump pulley and bolts and torque to 18 ft. lbs. (25 Nm).
  4. Install the remaining components in the reverse order of the removal process. When refilling the cooling system, use the proper mix of DEX-COOL® and water. Check for leaks.
3.4L (VIN X) Engine
  3. Remove the coolant recovery reservoir.
  4. Remove the drive belt. Please see .
  5. Remove the pulley bolts and separate the pulley from the water pump.
  6. Remove the water pump bolts and remove the pump from the engine.
Fig. Exploded view of the water pump mounting-3.4L (VIN X) engine
To install:
  3. Install the water pump pulley and bolts and finger-tighten the bolts.
  4. Install the drive belt, then torque the pulley bolts to 18 ft. lbs. (25 Nm).
  5. Install the remaining components in the reverse order of the removal process. When refilling the cooling system, use the proper mix of DEX-COOL® and water. Check for leaks.
Hope this help (remember comment and rated this).
Apr 04, 2010 | 1998 Buick Century
Where is the oil sending unit on a 2002 Chevy Suburban V 8 engine?
Your oil pump is located under your oil pan. You need to remove the pan in order to access it. There is one bolt holding it in place, remove that bolt and then remove the oil pump. This is if you have a 4.3 liter motor.
If you have a 4.8, 5.3 or 6.0 liter motor it is considerably more difficult. If you need step by step instructions let me know, but to answer your question it is located behind the front cover of the engine. You need to remove the front cover exposing the timing chain and the oil pan in order to remove the pump on these motors. Let me know if you need further help.
Nov 04, 2009 | Chevrolet Chevy Cars & Trucks
We have a Dodge Ram 50 1987 pickup and need to change the fuel pump. The engine states that it is a Mitsubishi 2.6 engine. When we have ordered the fuel pump for the truck, we received something different...
Sometimes the new fuel pump will look different than the new on but It'll work. If your not been involved in car repair in the past them your not working on a car to learn on. Your smart and can follow directions and have someone to help you (think) then you may be able to do the job. In order to remove the existing pump the valve cover needs to be removed. The push rod arm on the pump is quite long and is hard ti direct to the place the old one was in without the valve cover off as the old gasket is leaking anyway it's a good time to change the gasket and a good parts man selling the pump should say and you need this valve cover gasket to. the pump has to studs with nuts holding it on and the air cleaner the valve cover and anything in the way of getting it off needs to be removed too. once the nuts are removed from the pump the studs may have to be removed too in order to get enought room to twist the pump enought to get the long arm out of the head as it runs on the cam in the middle of the head and the head is quite wide. 166168360.jpg 1031338635.jpg 166168360.jpg 1031338635.jpg
Oct 20, 2009 | 1987 Dodge Ram 50
Garden Logo
66 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
