Question about EdgeStar Portable Air Conditioner Heater
Why doesn't the water fill up at all - EdgeStar Portable Air Conditioner Heater
How to move around brandt wm 550
see this causes and fix it. God bless you
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem: It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer. It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Sep 22, 2012 | Washing Machines
Sears washer dryer commbo model 417.94712400 didn't stop filling with water and water went everywhere
Generally you could have two problems. Number one may be a sticking water solonoid that doesn't want to close after the fill cycle has stopped. Number two, if the machine has not started to agitate the clothes that means the timer has not reached that part of the cycle and is stuck in the fill mode. My guess is number two would be more likley, the timers **** out nowand then. Hope that helps
Sep 06, 2012 | Washing Machines
Beko WMP652W washing machine will start cycle but get stuck at end of wash, doesnt go onto rinse or spin any help please?
see the next steps and use the common sense: God bless you
Aug 01, 2012 | Washing Machines
My washer fills and doesn't stop. I try to advance it to the spin cycle but none of the cycles work. I changed the lid switch because it wouldn't fill at all. Now it fills and nothing else. Tested...
The fill switch is bad. That's the only "safety" on the washer that will shut the water off after reaching desired depth. To test it, run your machine on the various water levels. For example, start out on the low setting. If the water doesn't shut off after the tub is half full, then it's the fill switch inside the unit next to the tub.
Sep 13, 2011 | Washing Machines
No ice, water does not fill ice maker, but water flow is OK.
if Ice maker cycles and you get no water into it you have a clogged/frozen fill tube. If a broken line the water would go on your floor every 15 min. None of those indicates your refrig valve is bad. Dual solenoid water side works Ice doesn't.
Aug 13, 2011 | Maytag MSD2756GES Side by Side...
As soon as it gets to the rinse cycle it doesn't fill up water, what can i do?
If the only time that it won't fill with water is the rinse cycle is is probably either in the timer or control board.
Have you tested it on all the the setting to determine what works and what doesn't? Will it work on permanent press but not delicate; that type of troubleshooting.
Jul 16, 2011 | Washing Machines
Washing machine doesn't fill with hot or clod water.
If your washing machine will not fill, only hot or cold will fill or is slow tofill then read these tips. I have covered many of the things that can happen inthese tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Jul 05, 2011 | Maytag Washing Machines
Icemaker doesn't work....It doesn't fill with water???
Check your water supply ,make sure valves are open. make sure ice maker arm is in down position
Jun 22, 2011 | KitchenAid Architect 25.3 Cu. Ft....
Will not fill with water but works on spin cycle
If your washer won't fill with water, but works in the spin cycle then the washer is sensing that water is in the tub. If there isn't water in the tub, then it is probably a sensor. If there is water but the spin cycle doesn't get it out, then look at the pump or control board.
Jun 08, 2011 | Maytag Washing Machines
The drum doesn;t turn during wash or spin cycle
Kindly remove the back panel of the unit and check whether the belt is properly fixed if it is ok means check the wire connection if everything is fine. kindly check the motor humming sound once the water is filled if you find the humming sound means kindly replace the motor
May 18, 2010 | Whirlpool LHW0050PQ Front Load Washer
EdgeStar Portable Air Conditioner Heater Logo
13 people viewed this question
Top EdgeStar Heating & Cooling Experts
Donni Steen
John Tripp
John Tripp
James Coghill
Are you an EdgeStar Heating and Cooling Expert? Answer questions, earn points and help others
