Question about Coffee Makers & Espresso Machines
Delonghi cf208 red light flashing
The machine just blowing air out but it aint cold and the red light keeps flashing and there no water in the container
SOURCE: Delonghi EAM 3400 keeps saying "Empty Grounds Container"
I think the microswitch that sensors the front door is not activated. Try to find it and "give it a massage" The machine resets the counter for the grounds container every time the door switch is activated.
Rgds
Michael
Posted on Jan 17, 2009
  • 3 Answers
SOURCE: water container full but low indication on
I think the water level is read by a magnetic pick up driven by a black floater located 3/4 way towards the back of the water tank.
Make sure this floater can move up and down in its pocket: you can see it through the walls so just shake the tank to see it move, and check that it floats up when you fill water
Posted on Apr 18, 2009
SOURCE: milk container won't fit onto front of machine
We had the same problem & worked out that it's because the actual milk container is too cold & has contracted from being in a cold part of the fridge. We moved the milk container to the door of the fridge ( it's a little warmer than the rest of the fridge) & it slotted in perfectly the next morning!
Posted on Aug 17, 2009
mnwarfield10
  • 452 Answers
SOURCE: Help! The warning light regarding
motor no good may be pcb needs testing...
Posted on Mar 04, 2011
wentlanv
  • 710 Answers
SOURCE: Delonghi Magnifica Rapid Cappuccino machine.
Hi Alan,
This posting is back on the unsolved boards again. I cannot see what anyone else has told you and I don't know what you have tried. So, I'm starting fresh....
If your control panel is not reading that you have inserted the container, then one of several things could be wrong.
I imagine you have already checked and cleaned all the parts involved and made sure that the lids are sealing and the container is seated properly. Clean around the door to be sure it closes securely.
If all of these things are in proper order, then it could be that the control panel has gone bad. Is there a reset button somewhere on your machine? Have you tried to go through the descaling/cleaning procedure and restart the machine?
If none of this works, I would suggest contacting DeLonghi to talk to a technician. Here is a contact page I got from the internet: http://www.delonghiusa.com/index.php?texts&pid=3
You may have already found the contact site, but if all else has been checked and found to be ok, I think that is your only recourse now.
Hope this helps. If it does, I'd appreciate a 4 thumbs up. Thanks,
Handie Andie
Posted on May 05, 2011
Why won't the red blinking light go off on my primo water cooler?
If the cooler or the water are not getting cold I would check for a high pressure reset if they are getting cold the compressor would working fine, you could also try flushing it, is there a pattern to the flash that may indicate a code................good luck! mine has developed a leak and does not heat less that 6 mo old pretty disapointing.
Jul 20, 2014 | Unknown Primo Deluxe Stainless Steel...
Bosch WTL5200SN/04 condense Tumble Dryer
you have to open the cover to check it seem the water tube is dissconnected or there is an blockage in the tube.
Jul 07, 2008 | Bosch Axxis WTA 3510 Electric Dryer
Primo water cooler red light blinking
What do I do with my Primo water dispenser whenever the red light keeps flashing I have a full bottle of water in there but it just keeps flashing I can turn it off and turn it back on or I can push the button in the door and it'll go off within the next 20 minutes it will come back on and the water's cold and then the water goes to lukewarm
Nov 25, 2013 | Unknown Primo Deluxe Stainless Steel...
Air conditioner shudders, stops blowing cold, then resets every 5 mins
Cleaned the filter this AM and closed the door but now a red
light keeps flashing.
Jul 19, 2013 | Sharp Cv-p12lx 11500 Btu Portable Air...
Sunbeam cafe series EM 6910 coffee machine little red light keeps flashing
That's the low water warning, triggered by a black float with a magnet inside, in the water container.
The magnet inside the float in the water tank loses its magnetism with age.
Buy a replacement on eBay for a few bucks.
You cannot repair it, but the machine will continue to work fine without it - you just won't get a signal when your water is about to run out.
Nov 17, 2012 | Sunbeam Cafe EM6910
Intertherm mmha070
Hi, did he bypass the high limit to see if it was bad? Sounds like you are getting false codes and you have a problem in your module or main board, which ever you have. The way it is acting, saying the high limit is open but the tech says its not, I would change the board.
Shastalaker7
Nov 14, 2011 | Intertherm P3RA-048K Air Conditioner
The milk doesnt heat up or froth but the button flashes red
We had the same problem with burn marks on the bottom and flashing red light etc. Now we just rinse the container out with cold water each time we use it - do not dry, just leave it wet and then add your milk. Heats up perfectly each time. The water lubricates the base of the container, preventing burning. Nice hot coffee every time now. Hope this works for you too!
Apr 20, 2011 | Nespresso Aeroccino Automatic Milk Frother
Saeco Italia SUP021 YR green lights and red water light flashing
You can't manually reset. The machine will have to do it. I had the same problem, two green flashing lights with one red (water) all 3 would just keep flashing and not turn solid. No coffee can be made or hot water. I could not pump prime. The problem was the steam wand was blocked with old milk residue. It needs unblocking or you will never pump prime. I could not unscrew the steam wand...so I let it sink in a glass full of hot water for a few minutes and then turned the water knob counter clockwise to push out the softened residue. After that, everything was good. When water started flowing out of the steam wand, the red light turned off and the green lights turned solid. The obvious answer to why you can't pump prime is there is a blockage somewhere and best to start with the steam wand. --Mabada
Sep 14, 2009 | Starbucks Saeco Italia Digital Barista...
Red descale light is on
I use distilled white vinegar, but you can use specialized coffee cleaners with this model:
Descaling
Descaling 11
Descale your Tassimo machine every three months to keep it
operating at full potential.
Descaling products are widely available from stores selling coffeemakers and espresso
machines. Only use a product intended for descaling. Mix the descaling product
directly in the water container, following the instructions provided on the descaling
packaging. Replace the water container on the machine.
2 Place a large cup or mug on the cup stand, insert the cleaning disc, bar code down,
and close the brew mechanism. When the AUTO light illuminates, press and release
the start/stop button. The brew cycle will fill the machine with descaling solution. Empty
the cup and let the machine stand for 15 minutes.
3 Open the brew mechanism and close it again, leaving the cleaning disc in place.
When the AUTO light illuminates, press and release the start/stop button. When the
machine stops running, empty the cup, and let the machine stand for 15 minutes.
Repeat this step two more times for maximum descaling effectiveness. Discard the
remaining descaling agent from the water container, rinse it thoroughly and refill
with fresh, cold water.
4 Open and close the brew mechanism again, leaving the cleaning disc in place.
When the AUTO light illuminates, press and hold the start/stop button to flush water
through the machine. The MANUAL light will flash. When the cup is full, release the
start/stop button, empty the cup, and replace it on the cup stand.
5 Repeat step 4, flushing clean water through the machine in the same manner and
emptying the cup as it fills. To ensure that all the descaling solution is completely rinsed
away, flush two full water containers through the machine before using it again.
Mar 26, 2009 | Braun Tassimo Coffee Maker
Hotpoint tdc62p changed thermostats as blowing out cold air,
Make sure that all filters are properly cleaned, and that the air inlet and outlet vents are clear. Make sure water container is empty.
The best way to clean the filter at the bottom is to run cold water through it, this will clear out all the lint.. Make sure you have the correct stats ( there are many for the hotpoint range) and that you have them in the correct position on the heater back plate.
Plz rate this solution.
thanks.
Dec 16, 2008 | Hotpoint TDC32 Electric Dryer
Coffee Makers & Espresso Machines Logo
70 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
