Question about LG Flatron L1710S 17" LCD Monitor
Red Dot and OUT OF RANGE problem
1).The monitor when in display has a red dot on its upper left so does the dot spread or do i need a replacement i just got the monitor yesterday. 2). I have linux redhat 9 on my disk the initial booting up runs normally but when the desktop screen tries to appear i get a blue box saying OUT OF RANGE 67.8 kHz/85 Hz pls help
    Novelist:
  • 153 Answers
You might be able to take back the monitor since you just bought it, but manufacturers generally have a specified number of bad pixels for which they deem the panel to be functioning acceptably and they will only replace it if the number of bad pixels exceeds that limit.
Redhat 9 is rather old and I don't remember if this will work, but just in case get to a prompt and type 'setup' as root. If it is there you will have several choices of what to set up. Choose X configuration. If your monitor is not in the list, select one of the generic LCD monitors that match the native resolution of your monitor.
You could also tweak /etc/X11/xorg.conf to a resolution that will work but I doubt you want to tackle that.
Posted on Apr 22, 2009
What are the advantages of holographic sight?
The biggest advantage of Holographic Sight over red dot is that prevents parallax distortion.
That is if your eyes are not properly aligned with sights in a red dot sight you will not hit what you are aiming with your sight, as you will not be looking parallel to the barrel of the weapon. This problem increases with the range of the target.
Holographic Sights, however, uses laser to produce a holographic reticle, which is not very prone to parallax errors.
However, there must be something which keeps Red dot in demand.
May 31, 2018 | Optics
I'm sure this will sound stupid, I just bought a rifle with a Tasco red dot scope on it and have no idea how to activate the scope. Any help would greatly be appreciated. Thanks
No, that doesn't sound stupid. It's always a good idea to get all the information before using firearms and their accessories, and I'm happy to help:
The large knob on top of the scope is the rheostat, which is used to turn on the red dot, and adjust the brightness. It can be adjusted from "1" (dimmest) to "11" (brightest). You'll have to be looking straight down the scope to see the red dot, since it is only visible when you're aiming. If you turn on the scope to the brightest setting, and you look through like you are aiming, and the red dot is still not there (or very dim) then you probably need to replace the battery. It uses a 3 Volt coin-style lithium battery, type 2032. Unscrew the battery compartment on top of the rheostat and put the new battery "+" side up. Then replace the battery cover, and you should be good to go. Turn off the scope when you're done to save the batteries.
Since you bought the rifle with the scope already installed, it's probably already sighted in, or pretty close to being sighted in. Adjusting the windage and elevation on the red dot scope works just like other rifle scopes. The knob on top moves the point of impact up/down, and the knob on the side moves left/right. For this model, each click of adjustment moves the point fo impact by 1/2" at 100 yds, 1/4" at 50 yds, or 1/8" at 25 yds.
Be safe, and have fun!
Jan 24, 2011 | Tasco 1x30 Red Dot Sight BKRD3022
I need diagram to wire defy 600s hob and oven , can you help please
Hi Gary The hob connectors have colour coded plug ins. They are starting from right to left the red connector is for the front right plate, the white is for the back right plate, the blue is for the the back left plate and the black is for the front left plate. Now I am not sure of the config in your country but another way to look at this is that The red dot 2000 W (large plate) is connected to the black harness and the red dot 1500 W is connected to the blue harness. The std large plate 1500 W is connected to the white harness and the red harness is for the 1000W small plate. The wiring onto the actual plates should be accrording to the colour codes as follows: The harnesses are all 4 wires and are colour coded blue white ( wiring block 1) , yellow white(block 2), white ( wiring block 3) and the red white block 4. The actual plates are numbered from left to right as 1,2,4,3. But my wiring write up takes it as standard 1 to 4 so do mot worry about the numbers on the plates as some plates have no numbers. Hope this helps.
Nov 09, 2010 | Stoves 1100ESIDLa Electric Kitchen Range
Red dot
if the red dot occurs in a constant patter across the image there is damage to the magenta drum and it will need cleaning or replacing the yellow streaks lead to the yellow drum or dev unit needing cleaning or replacing.
Jul 21, 2010 | Canon imageRUNNER C3200 Copier
I need help I don't know what color wires go to what wires on my sterio deck
I have a radio wire connector on a 1994 Toyota Camary and the color don' match your list, here is my list.
2 reds, one silver dot, one double silver dot.
2 blacks, same as above,
2 greens, same as above.
2 whites, same as above.
2 browns, same as above,
1 white w/green stripe, two silver dots
1 black w/red stripe, one silver dot.
1 yellow, two silver dots.
1 blue, two silver dots.
the numbers on the connector are A02 16 14 11264 9 8.
I'm clueless which wire are which.
Oct 30, 2009 | 1994 Toyota Camry
Need manual to set redt dot scope. don't know how
can you be more specific, what is the name and, model number of your optic kit, is it leapers?
Oct 19, 2009 | Tasco Red Dot 1 x 30mm Rifle Scope 5 MOA...
TI 84 plus calculator, flashing dot in upper left hand corner
When you turn the calculator on, its screen is cleared, save for a small square on the top left corner. This is the cursor and it is blinking: The calculator is waiting for you to order it to perform some calculation.
Try this simple operation
[1] [+] [1] [ENTER]. The calculator will display the result one line down justified to the right.
Hope it helps.
Aug 26, 2009 | Texas Instruments TI-84 Plus Calculator
I have a canon AE-1. Cant get the red dots to line up to remove the lens. The red dot on the lens itself will not move, am I missing something? Colleen
To remove the lens, depress the the small chrome button on the lens (below the red dot) and turn the lens assembly anticlockwise. Once the red dot aligns itself with tthe red dot below the Canon Logo, you can remove the lens.
Aug 12, 2009 | Cameras
Red dot
That dot represent lit (stuck) red sub-pixel and if it only one that is not considerable as failure due to dead pixel warranty but you can try to solve this problem with software called screen fix. It possible that during exploitation that red dot dissapear.
Good luck
Jul 01, 2006 | Samsung SyncMaster 510N 15" LCD Monitor
LG Flatron L1710S 17" LCD Monitor Logo
143 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
