Question about Epson Stylus CX4700 All-In-One InkJet Printer
All lights flashing on / off together. LED says E.
Status monitor says communication error
2 Suggested Answers
SOURCE: Epson Status Monitor 3 :
Check all connections and make sure all devices are on. If the power was turned off during printing, cancel the print job. If the error does not clear, see your printer documentation.
Posted on Feb 24, 2011
My 73" mitsubishi dlp WD-73827 turns off and has a red status light blinking. I have replaced the bulb and the heat sensor... any answer to what else could be the problem?
It is helpful to have the sequence of the blinking red light. This may help:
MODELS: WD-52627 / 52628 / 62627 / 62628 / 62827 / 62927 / 73727 / 73827 / 73927
Page 43
3. Error Code Operational Check
Note: The TV must be in "Shut Down" and not have been switched Off, to perform the Error Code Operational
Check. When the TV is switched Off, the code automatically resets to "12" No Error.
Pressing the front panel "DEVICE" and "MENU" buttons at the same time, and holding for 5 seconds,
activates the Error Code Mode. The LED flashes denoting a two digit Error Code, or indicating no problem
has occured since the last Initalization.
Note: The front panel buttons must be used, NOT those on the Remote Control.
• The number of flashes indicates the value of the MSD (tens digit) of the Error Code.
• The flashing then pauses for approximately 1/2 second.
• The LED then flashes indicating the value of the LSD (ones digit) of the Error Code.
• The Error Code is repeated a total of 5 times.
Example: If the Error Code is "23", the LED will flash two times, pause, and then flash three times.
4. Error Codes
The Error Code designations indicating malfunction, or no malfunction, are listed below:
POWER
LED
STATUS
LED
LAMP
LED
Power
Status Condition
Off Yellow Off Low
Power Excess heat. Check Lamp Filter
Off or On Off Yellow No
change
120w usage time over 7000 Hrs.
150W usage time over 3500 Hrs.
Off Off Blinks
Yellow
Low
Power Lamp Cover open
Off Blinks
Yellow Off " Filter Cover Open
Off Off Red Stby Lamp did not turn On
Off Blinks
Red Off Low
Power Fan Stopped
Off Red Off " Circuit failure (short or DVI
connector unplugged)
Abnormal LED Indications
Error Codes "DEVICE" & "MENU"
Error Codes Description
12 No error detected
22 Recovery from Reset
32 Lamp cover is Open
34 Lamp abnormality
35 DM Fan failed (Chassis Fan)
36 Exhaust or Lamp Ballast Fan failed
37 DMD Engine Fan failed
38 Lamp temperature abnormally high. Remove Lamp to check filter.
39 DMD temperature abnormally high
41 Short is detected (Standby Power Supplies)
42 Lamp Fan failed
44 DVI cable between Format and Engine disconnected
46 DMD Temp. Sensor not detected (check DT connector))
47 DM Temperature too high
48 Engine power supply short detected
51 Speaker Drive circuit short detected
52 HDD excess temperature (V30+ & V31 only)
55 HDD Fan Stopped (V30+ & V31 onlyt)
Jul 18, 2014 | Mitsubishi WD Televison & Video
Dell backlight indicators
A computer monitor has a front-mounted LED that displays its current status and flashes in the event of an error. When an error occurs, the flashing may be accompanied by an error message on the screen. If the screen does not display an error message, the problem most likely falls into one of four common categories.
Unsupported Display Mode A video card has the ability to send output to the monitor at many display resolutions and refresh rates. However, no single monitor is capable of supporting every possible display mode. When the video card sends an unsupported display mode to the monitor, the monitor shuts off to prevent damage and blinks, or displays an error message. Standby Mode b> When a monitor detects no video signal from the computer, it assumes that you have turned the computer off and enters standby mode to reduce power consumption. Dell and HP monitors display an amber light when in standby mode. The status light on an Apple monitor blinks slowly. Incorrect Power Supply Some monitors such as certain Apple Cinema and Studio displays use external power adapters. Because different power adapters may have similar connectors, these monitors are designed to detect when an incorrect power supply is connected and blink the status LED rather than attempting to turn on. In the case of an Apple display, the LED blinks in an alternating short and long pattern. b> Backlight Failure b> A flat panel LCD display has an LED or fluorescent backlight that illuminates the pixels and makes it possible to see the contents of the screen. If the backlight fails and requires replacement, the monitor is unable to display any information. In some cases, you may be able to resolve this issue by turning the monitor and computer off, disconnecting and reseating all cables. If the monitor still has a backlight issue, it requires professional service.
Jan 14, 2013 | Computers & Internet
Why is the Status Light on my Mitsubishi XL8U flashing red? My projector is still working but the status light flashes red.
With out knowing the state of the power LED, my best guess is the Status light is solid red and telling you to purchase a replacement lamp before the current one dies. Attached is a chart that will show you the errors possible depending on the LED statuses:
Mar 11, 2011 | Mitsubishi Lamp For Mitsubishi XL8U...
There is a yellow light flashing which i think is stopping my printer from working.it is the symbol furtherst to the right out of the 4 symbols any ideas
The rightmost LED is the Error light. How fast is it flashing?
If the light is flashing 1 long flash every 4 seconds (no other lights flashing), then either the image drum needs to be changed or the toner is low.
If the flash is one blink a second, then you have a paper problem or a cover open.
If you installed the OKI software with the driver, you can use the Printer Status monitor to identify the problem and order the consumables if you have a slow blink error. (Open the printer control panel (Start >Programs > Status monitor) and Maximize the window to see the Printer status.
You can find the manual for the OKI B4100 here: http://my.okidata.com/PP-B4100.nsf?opendatabase . View all manuals on the right. If that link doesn't work, see the support site: http://my.okidata.com/Home.nsf/Welcome?OpenFrameSet and select the B4100 in the Color/Mono Page Printer drop down menu.
I hope this helps.
Feb 14, 2011 | OKI B4100 Laser Printer
OKI c3200n "COMMUNICATION ERROR"
try switch off, unplug, hold up and down & reset button at the back, swith on
Jan 30, 2009 | OKI C3200n Led Printer
Mitsubishi WD-62525 Red Status Light After Cap Replacement
which caps did you replace? As the normal repair for the first generation dlp is to replace the (4) 1000 uf caps. the (2) 2200 uf caps and the (2) 3300uf caps on the power pwb when you get the 34 error code.
Sep 09, 2008 | Mitsubishi WD-52525 52" Rear Projection...
A steady red light: there is a short on the DVI cable from FMT to DMD disconnected
Sep 09, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Static Warning light
Hi Angela,
The Red LED has the following function;
On all the time (not flashing) - Lid is open.
On and flashing - An error has occured. ('out of dye film', 'card jam', etc).
The error would normally be reported on the PC screen via the status monitor. If the status monitor is not running you will not get any error messages. To get the status monitor running again, it's easiest just to re-install the driver. The drivers can be downloaded from Magicard's web site The latest driver for the Rio 2 / Tango 2 (V6.01) is also compatible with the Rio 1 / Tango 1 printers. Download the driver from here;
http://www.ultramagicard.com/support/technical-support/?R=&L=&id=&lang=1&printerID=7&supportOption=1
IMPORTANT: When you run the driver installation setup program, the printer should be switched off. Also, you will be given the following choice;
'Add a printer' or 'update driver files'. Select 'update driver files'. The PC will then ask you to restart. The installation will continue after the reboot. Select your communication type (either USB - recommended, or LPT). You will be prompted to switch on and connect the printer. If USB the port name will be 'NUSB01'. Follow the rest of the instructions to the end of the installation. You will be asked to choose the model at the end.
You should now have a working status monitor. Let me know what the error says on the PC screen if you get one when the printer initialises.
I hope this helps.
Jan 16, 2008 | Magicard Rio Card Printer
Both Ink & Paper lights flashing!
Hi JayBirde Do the lights flash Together (not alternate) and is it a quick flash (0.1 second on 0.1 second off)? If so, check the Status Monitor for a message. If it says Fatal Error or General Error, then you have a task on your hands! If the lights flash alternate (0.5 second on 0.5 second off) then this indicates a maintenence error and the status monitor should say parts inside your printer have reached the end of their life - or something similar. This much easier to fix with an R220 Rescue Kit from www.TheServiceManualShop.com - use their search to look for R220 Rescue. If you can't find it, just drop them a line and they will create one for you. Delivery is via instant download so no waiting around to get your machine fixed. If you have a general or Fatal error it means the printers head can not move using the norm,al amount of force - i.e. something is in the way. You can check a few things: Ensure their is nothing in the path of the print head - paper, foam from the pad, head lock not retracting, toy soldier on manouvers in the mechanism etc Chech the encoder strip ( a grey-ish looking plastic strip, near the drive belt for the print head) is clean and attached. Check the lid for the ink cart cover is full closed.
Oct 28, 2006 | Epson Stylus Photo R220 InkJet Printer
Epson Stylus CX4700 All-In-One InkJet Printer Logo
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
