Question about Measuring Tools & Sensors
18 hp kawasaki fh531v twins engine - Measuring Tools & Sensors
  • 33 Answers
SOURCE: 18hp kawasaki FH531V engine on ride on mower slows down
check the air filter and the fuel filter
Posted on Jan 07, 2009
  • 246 Answers
SOURCE: Kawasaki FH531V
Hello:
You can View this Engine in a Breakdown Form at the Following Site Addy. This will also show you the Part Numbers and you can Purchase Parts from the Site as well.
http://www.emerichsales.com/pages/parts/viewbybrand/default.aspx
Hope this Helps.
Good Luck
Respectfully
John
Posted on May 10, 2009
  • 225 Answers
SOURCE: carburetor adjustment
have you checked the air filter,if that is clean I think I would replace the carb, diaphram.
Posted on Jun 21, 2009
  • 5 Answers
SOURCE: I have no spark on the road side of my 1997 18
not quite sure if you have spark at all or just on one cyl,either way it is unlikely that your main coil is bad but look for a wire on that side of the mower that may be shorted to ground and if it is it may have sorted out your trigger coil. It is a very small electronic box about 5/16 thick by 1"x 11/2", light in color. A quote I was given by a kawasaki expert was that nine and a hlf times of ten it is the trigger coil.spendy little buggers too.
Posted on Sep 24, 2009
cmcduncand
  • 714 Answers
SOURCE: my Briggs 18 hp v-twin is starved for fuel. It
A more likely cause is a clogged jet in the carb.
Remove disassemble and clean Carb, the High speed idle jet is clogged.
If you had a fuel pump problem it would not run even in the Choke mode.
This tends to happen when an engine sets for long periods of time with out a fuel inhibitor id is even more likely to happen if you use fuel with ethanol.
Hope this tip helps.
r/David
Posted on Jan 23, 2010
18 hp v twin Kawasaki won't idle acts like chock is on, not getting full rpm, new carb new fuel pump new air filter runs same without air filter
have u adjusted the carb ? motor with lot of hrs the compression air intake wont be the same as a newer motor like the carb is. feul lines n pump not getting dirt build up from tank?
Apr 17, 2017 | kawasaki Motorcycles
Can I swap the motor from a Husqvarna YTH 180 and put it in a Husqvarna YTH 1848 HP?
The 1848 uses an 18 HP Twin cylinder engine. Mine is a Kawasaki but a similar 18 - 21 HP Kholer will also work. Can't see a problem
Nov 06, 2014 | Husqvarna Garden
Looking for engine Number on 18 HP Vtwin
If there's no tag/tab with the #s on the engine, go to the unit it came off of and the tag for them would be under the seat with model and serial numbers. and year of mfg.
Jun 19, 2014 | 18 HP V-TWIN GX610 V-Twin OHV Horizontal...
18 hp Briggs blowing oil into the air filter
Sounds like your valves are sticking, possibly bent w/piston damage.
Dec 14, 2012 | Briggs & Stratton Briggs Stratton Vanguard...
Engine runs fine til hot.
I think one of the intake valves, or a valve pushrod, is bent or warped. When the engine heats up, the metal expands and the valve starts sticking open. That would cause compression to be lost in one cylinder, reducing available power so things drag when you engage the blades. This would also causes air/fuel to be blown back through the intake. I think you'll need to take it to a small engine mechanic. Good luck! Please rate my solution if helpful, thanks.
Jul 11, 2010 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Briggs & Stratton 18 hp v-twin engine surges while running.
I put a new carburator kit in a Briggs & Stratton 18 HP Twin. But did not replaced the needle nor the new seat that came with kit, because I did not know how to remove it and did not to damage it. now the gas over flows
Jul 12, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Kawasaki FH531V
Hello:
Hope this Helps.
Good Luck
Respectfully
John
May 10, 2009 | Husqvarna 23 Hp 48" Deck Yard Tractor
Measuring Tools & Sensors Logo
41 people viewed this question
Top Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Measuring Tool and Sensor Expert? Answer questions, earn points and help others
