Question about Craftsman 675 Torque 190cc 21" RearBag Push Lawn Mower ()
Craftsman 675 series limited edition key start push mower
Will not turn over
rycgl
  • 1545 Answers
SOURCE: I Have a Craftsman 675 Series
There is one thing fairly easy you can try. You take the aluminum bowl (bottom) off the carburetor. There will be a brass bolt with a washer holding it on. When you do this the carb will leak gas so you should drain the fuel first or stick something under the carb to collect it. There will also be a gasket between the bowl and carb body. Don't mess it up. The bowl should be cleaned and have no residue or dirt or water in it..the brass bolt is the big concern here though. Inspect it closely ...tiny holes in the smooth part above the threads...and bottom...make sure they are clear. Use carb cleaner Dont enlarge any of the holes...clean with toothpicks, no metal....this is the main jet to the carb. Try it.
Posted on Jun 11, 2010
2strokeguy
  • 183 Answers
SOURCE: My craftsman 675 push mower
I have 2 possibilities.
The easy fix...it is possible that your fuel tank is forming a vacuum and causing the engine to run out of gas. this is usually caused by a fuel cap that has lost its "insides" which allows the cap to seal against the tank, instead of venting.
The harder fix...if it is taking 20+ minutes before it will restart, it is probably overheating the ignition module. Make sure that the oil level and quality are good. Low oil, or old, thin oil doesn't cool as well and will allow the engine to overheat. An overheated ignition module will most likely need to be replaced.
Posted on Sep 26, 2010
rycgl
  • 1545 Answers
SOURCE: where is the carburetor on
The carburetor would be located BEHIND the air filter housing and air inlet tube. The air filter housing should have a removable (by screw or clip) cover.
Posted on Apr 13, 2011
#1 Taper
  • 1041 Answers
SOURCE: Craftsman 675 Torque 190cc 21"
If your carburetor has sat for a few months with fuel in it, the fuel may have gone bad. Fuel turns to turpentine after a while and leaves light yellow deposits behind. These deposits will keep your carb. from working properly.You need to dip the carb. in carburetor dip for a few hours to get rid of the deposits. You can also take the carb. to your local parts store where they may do it for free.
You may also have to replace the gasket and needle valve too if it has been sitting. So basically, you need to do a carburetor rebuild.
If the float sounds like it has liquid in it, you will need to replace it too.
Good Luck!
Jim
Posted on Aug 13, 2011
  • 2503 Answers
SOURCE: Craftsman Briggs and Stratton 675 series Mower fuse location
Is battery powered, did you try calling sears tech center for further info ?
i have found them to be very helpfull with mower problems.
Posted on Sep 12, 2012
Craftmans 6.75 gold series will not start
How long since it ran last? Is it getting spark? Seem like it has good compression?
Jun 25, 2014 | Craftsman 675 Torque 190cc 21" Briggs ...
Where is primer on craftsman platinum push mower
It may not have one. Some mowers auto choke using spring tension on the choke plate in the carb. They open the choke when the engine speeds up after starting.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/david_29ad5d1dd86564b0
Apr 23, 2014 | Craftsman 675 Series 190cc 22" Briggs ...
MY B&S 675 PUSH MOWER STARTS,RUNS ROUGH FOR 5-10 MINS. DIES WON'T RE-START
See if by chance there is water in the gas tank. If not, the coil may be the problem after it gets hot.
Aug 26, 2013 | Craftsman 675 Torque 190cc 21" Briggs ...
Where is the choke
Many Briggs engine have a primer rather than a choke, the 675 series has a choke that is worked by an air vain, the choke is always closed when the engine is stopped, once the engine starts air pressure from the flywheel pushes the air vain which in turn opens the choke to allow the engine to run normally, there is also a version with a bi thermal switch on the back of the muffler, as the muffler heats up the switch opens the choke.
Feb 12, 2013 | Craftsman 675 Series 190cc 22" Briggs ...
Sep 12, 2012 | Craftsman 675 Series 190cc 22" Briggs ...
Craftsman 675 series wont start
can you pull the rope and it doesn't start or is it stuck like the engine is locked up?check for spark also how old is the fuel gas is only good 30days from the pump for small engines
Jun 11, 2012 | Craftsman 675 Series 190cc 22" Briggs ...
Lawn mower 675 series 190 cc Briggs Stratton 22
did this happen after hitting a rock?and you sheeredthe flywheel key is the gas older than 30 days?drain and refill if still no good clean the carb
May 03, 2012 | Craftsman 675 Series 190cc 22" Briggs ...
Where is the carburetor on the Craftsman 675 Series 190cc 22" cut self-propelled lawn mower?
Apr 13, 2011 | Craftsman 675 Series 190cc 22" Briggs ...
Craftsman 675 Torque 190cc 21" RearBag Push Lawn Mower () Logo
278 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
